2005-06 Jeep OPDA_CPS_Distributor Failure - Page 21 - JeepForum.com
 7Likes
post #301 of 5510 Old 01-29-2011, 02:14 PM
pslamp32
Originally Posted by TheFog View Post
A normal OPDA gear will have a small 1/8" shiny wear spot in the middle of each tooth. The mark should be in the middle and the same spot on all teeth. There should be no striations or dept to the wear mark.
FOG
How bad does this look? 05 X with 72,000 miles...
pslamp32 is offline
post #302 of 5510 Old 01-29-2011, 10:24 PM
Phil05LJ
I'll make an effort to persuade NHTSA to investigate this problem for the potential safety hazard it poses. I'll keep you posted. I urge anyone that has experienced this problem to file a complaint on NHTSA's website.
Phil05LJ is offline
post #303 of 5510 Old 01-30-2011, 08:26 AM
Bigbob
Bigbob's Avatar
That is great, but I don't see where this is a safety hazard. I went through the Ram 9.25 rear axle failed LSD deal and spoke with 2 people I know who actually had this issue make them loose control of the truck and go off the road. Nationwide many complaints went to NHTSA and no action was ever taken. Many of these failed 9.25 rear ends are still on the road just waiting to come apart. Just like the OPDA it was a simple fix and Chrysler never showed interest to take care of it.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #304 of 5510 Old 01-30-2011, 10:46 AM
Zetto
Zetto's Avatar
I will be installing the FogMod shortly. I plan to take pictures through the process and will have them up this afternoon.
Zetto is offline
post #305 of 5510 Old 01-30-2011, 11:15 AM
07AMF
Going to attemp to do the mod. Do I have to drill through the bushing when drilling for the grease port?
Thanks
07AMF is offline
post #306 of 5510 Old 01-30-2011, 11:32 AM
ChaseB
I've seen worse. At 72,000 miles I don't think that is horrible. To me it looks as if that would be the original gear. Was your Jeep ever serviced under the E05 Service Bulletin? If not, the dealership will replace your gear.
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #307 of 5510 Old 01-30-2011, 11:44 AM
pslamp32
Never serviced before, at least according to CARFAX. I looked up my VIN at JEEP site and no mention of recall for my Jeep. Odd...
pslamp32 is offline
post #308 of 5510 Old 01-30-2011, 11:46 AM
Jeffro06
Jeffro06's Avatar
There is no recall, just a service bulletin.
Jeffro06 is offline
post #309 of 5510 Old 01-30-2011, 11:50 AM
ChaseB
I received a print out from the service manager at my local dealership after I purchased my Jeep. It lists "Recall E05 - Oil Pump Drive Gear" performed December 14, 2005. I believe there was an actual recall on the gears. It also listed one open recall before I had it fixed which was the transmission cup plug bracket. Both were listed under the recall section.
1984 CJ-7 Renegade
ChaseB is offline
post #310 of 5510 Old 01-30-2011, 12:02 PM
Jeffro06
Jeffro06's Avatar
Go figure, both the Chrysler rep and the dealership told me it was just a service bulletin. Just adds to the lack of good info coming from both areas.
Jeffro06 is offline
post #311 of 5510 Old 01-30-2011, 12:21 PM
chutta
Well I got the guts up and inspected mine. The internal gear does show wear pretty much top to bottom. Whether there are striations in it, my eyes can not tell. The OPDA showed just maybe a 5/16" oval pattern toward the bottom with no striations, like just the finish worn off, at least buying plenty of time til parts come out. I meant to get pix, but I got nervous when the drive spun on me when trying to feel out the point to mark when the gear lets loose inside. I got it right anyway, no retiming
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #312 of 5510 Old 01-30-2011, 12:22 PM
ChaseB
I don't think I was supposed to get a copy of what he gave me, I'll snap a pic of the paper in a bit and post it. So many inconsistencies both with dealerships and Chrysler.
1984 CJ-7 Renegade
ChaseB is offline
post #313 of 5510 Old 01-30-2011, 12:29 PM
grnberet2b
I'm willing to bet that their system has to record things as a recall if free replacement parts are given, not that it really is a recall. If it was a recall, it would be posted on the NTSB website afaik
grnberet2b is offline
post #314 of 5510 Old 01-30-2011, 12:30 PM
ChaseB
Originally Posted by grnberet2b View Post
I'm willing to be that their system has to record things as a recall if free replacement parts are given, not that it really is a recall. If it was a recall, it would be posted on the NTSB website afaik
That makes sense! The gears were to be replaced at no charge to the owner.
1984 CJ-7 Renegade
ChaseB is offline
post #315 of 5510 Old 01-30-2011, 12:58 PM
pslamp32
Just thought I'd post what a Jeep mechanic told me about taking the OPDA in and out. I did mine and everything seems perfect but...
"Now, how ya gonna sync it back up? It ain't drop in and run..."
"As long as you mark it and drop it back in the same tooth like a distributor, why would it matter?"
"On a distributor type setup that would be fine, of course. But 99 and new 4.0's actually sync the cam and crank sensors together for fuel trim. They must be within 2 degrees on 99-04 and .5 degrees on 05-06. Its not easily attained without the proper scan tool."
"You guys be careful removing these to "inspect". They do drop back in a bolt down, but they will not be properly in sync and will not perform correctly."
"If some of you didn't know, I'm a 13 year lead tech at Asheville's Jeep/Chrysler/Dodge dealer. I'm not just spewing interweb junk here."
pslamp32 is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
