2005-06 Jeep OPDA_CPS_Distributor Failure - Page 209 - JeepForum.com
 7Likes
post #3121 of 5511 Old 05-01-2012, 10:37 AM
stripperguy
Here is a 3/4 section view of the OPDA with my intended components and modifications included. I have RFQ's for purchased parts, still need to produce detail drawings to get quotes for machined components. Short term will probably machine the 1st series of parts myself... not shown in the assembly is the thrust washer/bearing, drive gear, nor roll pin, no changes there at all.
Still need another week or two...
stripperguy is offline
post #3122 of 5511 Old 05-01-2012, 10:42 AM
flying_bosun
Yes, Virginia, there is a Santa Clause!
I'm so happy I could cry...
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3123 of 5511 Old 05-01-2012, 10:50 AM Thread Starter
willydigger
Looks very difficult to mod. I don't see an Average Joe pulling bushing and installing a sealed bearing.
What is the outer race of the bearing setting in?
Does the bearing prevent up/down travel of the shaft?
I look forward to seeing a completed prototype.
willydigger is offline
post #3124 of 5511 Old 05-01-2012, 10:54 AM
BioTex
1979 CJ7
Personally, I don't feel the gear wear is a result of too much friction at the upper bushing. I have pulled my OPDA with it at normal operating temp, and cold. It spins freely at both.
45K since new. I believe the wear is from the gears meshing together are not to the proper tolerances. Only other thing that would do it, would be if the metal was just too soft. Sure wish we had hardness test results. We could compare them to other cam/gear combinations.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3125 of 5511 Old 05-01-2012, 11:15 AM
ops5
ops5's Avatar
Who knows, but what do you blame the laughing monkey sound on if the shaft isn't binding?
ops5 is offline
post #3126 of 5511 Old 05-01-2012, 11:28 AM
BioTex
1979 CJ7
I'm not saying that they all spin freely! Obviously if a shaft is in a bind, then there will be more gear wear. What i'm saying is that how do you explain the gear wear if there is no shaft binding? There are two seperate issues at stake here. Yes, one may affect the other, but it doesn't have to.
Currently:
BioTex is offline
post #3127 of 5511 Old 05-01-2012, 11:29 AM
flying_bosun
There's often excessive gear wear without the monkey which is caused by binding. No binding means no monkey...
― Ron Paul
post #3128 of 5511 Old 05-01-2012, 11:34 AM
Fingers302
Originally Posted by Rubi4MyMrs View Post
Are you sure O'reilly can't get it for you? I just saw it in one of their stores a couple days ago. I see it online on their site. I seem to remember it being higher price in the store. Here is a link:
http://www.oreillyauto.com/site/c/detail/VLV0/RACE1030/N0425.oap?ck=Search_N0425_-1_3067&pt=N0425&ppt=C0162
Says "currently unavailable" on their website.
Found it here! http://www.jegs.com/p/Valvoline-Raci...61749/10002/-1 for $5.99
Fingers
06 LJ Rubicon, not stock
83 CJ 7, all stock
84 CJ7, dang near stock - Daily Driver!
Fingers302 is offline
post #3129 of 5511 Old 05-01-2012, 01:35 PM
ops5
ops5's Avatar
Yep, you are both right. The whole thing is a mess
I've been following this thread for a while, and I still haven't gotten up the nerve to pull mine and check it. I did buy a new unit to mod, but i'm not sure which mod to do yet, grease or oil. I want to see what this new mod looks like.
ops5 is offline
post #3130 of 5511 Old 05-01-2012, 01:54 PM
flying_bosun
Get the nerve, buddy. Take it from a cam loss victim, head in the sand ain't gonna save ya and it doesn't appear to matter which mod you choose (or at least it didn't).
― Ron Paul
post #3131 of 5511 Old 05-01-2012, 02:01 PM
BioTex
1979 CJ7
I am starting to lean more and more to the grease zirk since it was found out that the bushings are porous.
Currently:
BioTex is offline
post #3132 of 5511 Old 05-01-2012, 02:09 PM
ops5
ops5's Avatar
Yeah, i know I need to check it. I'm really worried more about putting it back in, although the recent method shown turning the crankbolt with a wrench does seem to make it easy. I'll have to look at it again and just do it.
I thought the general consensus lately was the oil cup was better than grease?
ops5 is offline
post #3133 of 5511 Old 05-01-2012, 02:32 PM Thread Starter
willydigger
Oil cup is better than grease. Grease is better than factory. A porous bushing and oil are a perfect match.
Getting up the courage to do it yourself is very difficult. It is very simple. I think of it like riding a bike. Once you're up and on it, it is very simple. Pulling the OPDA is the same way. There is no trick or special training. If you can watch a video and follow directions you can pull it.
post #3134 of 5511 Old 05-01-2012, 02:55 PM
LRod
Great Job, look forward to the prototype!
LRod is offline
post #3135 of 5511 Old 05-01-2012, 02:59 PM
55willystruck
Finally getting around to putting the engine back together. Just got a case of the turbo diesel truck stuff as it was all that was in stock local. Well two cases actually since there's only 6 to a case, but that means bigger discount which was nice.
So is there an exact parts list to do the oil cup with everything needed specifically to do the mod? I have the new cam and all new parts going in along with plenty of lube from Comp and the recommended bottle of break-in additive, think I have everything else covered to finally put it together, just need to know exactly what I need to buy to mod the OPDG (new) as well as the old for a backup and what exactly to make this "oil cup".
Thanks,
Best of Luck,
Mike
55willystruck is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
