2005-06 Jeep OPDA_CPS_Distributor Failure - Page 206 - JeepForum.com
 10Likes
post #3076 of 5527 Old 04-26-2012, 04:08 PM
jkp
Remove your belt and check all the accessories, in particular, the idler and tensioner pulleys. My tensioner pulley went bad and it gave me the laughing monkey.
'92 Islander
'06 Rubicon
jkp is offline
post #3077 of 5527 Old 04-26-2012, 04:36 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
While the belt is off start the engine briefly to see if the noise is still there or gone.
Rubi4MyMrs is online now
post #3078 of 5527 Old 04-26-2012, 05:14 PM
lope
lope's Avatar
Originally Posted by stripperguy View Post
But besides all that, I have received a damaged OPDA courtesy of whatnow.
I have disassembled it and measured some key dimensions. It seems there is an easy way to permanently fix the upper bushing issue that still uses the OEM components or at least most of them. Once I get all the design drawings complete, I'll post the results here...
Look forward to seeing what you come up with.
lope is offline
post #3079 of 5527 Old 04-26-2012, 07:39 PM
RubiRedJeeper
Another angle for the OPDA problem
I have a 06 LJ with 21K miles. My OPDA gear is moderately worn. I removed the gear and noticed some discoloration on the gear where it contacts the thrust washer. Half of the top gear surface is bright and the other half is dull. I also noted that the gear's teeth wear marks are different on one side than the other. It seems the lower edge of the gear wear moves closer to the roll pin for one quadrant of the gear.
I looks like the gear is moving in an out as it is driven by the cam gear which explains the wear patterns.
I recall a Jeep Chief Engineer from a forum thread suggesting that there could be a tolerance problem with the OPDA. Could it be an alignment issue and a soft bushing causing the problem?
Does anyone else see these wear problems?
RubiRedJeeper is offline
post #3080 of 5527 Old 04-26-2012, 10:05 PM
lope
lope's Avatar
I just happen to have my old gear sitting here at my computer that I ruined when re-installing. It has the same wear on top where it contacts the thrust washer as you mention yours has (noticeably more wear on one side than the other), so I would say that's normal as this gear I mentioned was fine (before I messed it up anyway) and shouldn't be an issue.
As far as the other things you mention about tolerance and alignment, that's kinda' the million dollar question. Some of the gears just wear down quickly and/or unevenly while others don't and we're not sure why. Basically we've tried to address the lack of lube to the upper bushing and have tried higher zinc oils for the gear wear issue and it seems to be an improvement.
lope is offline
post #3081 of 5527 Old 04-26-2012, 10:34 PM
RubiRedJeeper
Thanks for the reply. Ok, the previous design (pre 2005) had more lubrication. Perhaps keeping the bushing well lubed is a long term cure for this design. A tolerance problem would explain why some people have problems and some don't. The wear pattern that I'm talking about suggests that the OPDA gear is moving in and out relative to the cam gear, like for instance if the shaft was a little bent. I want to see if the gear wear is common suggesting a root problem. Zinc oil won't help the top bushing unless you oil it. One more thing about the ZDDP is that is may be hazardous to your Catalytic converter.
post #3082 of 5527 Old 04-27-2012, 05:50 AM Thread Starter
willydigger
...Zinc oil won't help the top bushing unless you oil it. One more think about the ZDDP is that is may be hazardous to your Catalytic converter.
Oiling the top bushing was the origin of the FogMod and subsequent oil cup/bath modifications since. If you haven't already reviewed the first page take a minute (maybe longer ) to have a look. There are a lot of clever ideas and a ton of info.
The debate of ZDDP and the catalytic converter has been discussed several times. IMO a non-issue unless your burning oil and even then a cat is a relatively easier fix than tearing down an engine. I get a lot of satisfaction knowing I'm using a higher ZDDP oil.
I'm not so much worried about the wear. Wear will happen. I am more worried about the binding and potential for a more serious and abrupt engine problem.
willydigger is offline
post #3083 of 5527 Old 04-27-2012, 06:09 AM
Killedbybob
Killedbybob's Avatar
I have an 05 tj with 130000 miles. Do you think I have this problem?
Black 2005 TJ 4.0L Automatic l Dana 44 Rear l Viper 791XV l RB1 Nav System l Top Five Rack and Safari Basket l Cobra 75wx st l RE 3.5 Super Flex l 305x70xr16 Nitto Mud Grapplers l Sniper Fab Front Bumper l Sniper Fab Tube Fenders l Rockhard 4x4 Rear Swingaway Bumper l Shrockworks rocker guards l TW front and rear driveshafts l
Killedbybob is offline
post #3084 of 5527 Old 04-27-2012, 06:38 AM
RubiRedJeeper
Well, saving the engine is the whole point. The ZDDP will certainly help the prolong lifter/cam life and I have decided to use it myself. I'm just trying to get some more details on the wear patterns which can suggest the best fix.
post #3085 of 5527 Old 04-27-2012, 06:56 AM
BioTex
1979 CJ7
Yes, you definately have the problem, question is, just how bad yours is. Only one way to find out...
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3086 of 5527 Old 04-27-2012, 07:11 AM Thread Starter
willydigger
We haven't developed enough evidence to confirm anything. There have been a couple vendors (no free publicity! ) who have said they are doing something, but have yet to do anything. Maybe because we don't know the true cause of wear.
We do know that upper bushing/shaft will gall, and bind, and laugh, and fail. So for the time being we can address that. Maybe, this will solve/minimize the high wear issue too. Wishful thinking at this point.
There have been some reports with relatively low mileage that show smaller wear patterns (including mine) but at this point I put zero faith in it. If you plan to do the FogMod to fix the wear, I think at this point, that is a bad conclusion. The FogMod will help the upper bushing problem and that along with the relatively low cost of the mod is worth it for me.
post #3087 of 5527 Old 04-27-2012, 07:12 AM
keithert
keithert's Avatar
I find that I like my Jeep better since doing the oil cup mod. Knowing that the engine may now live to 200k miles like most 4.0's is a relief. On the other hand I still don't quite fully trust the engine. I wish I had bought the 04 that I looked at!
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #3088 of 5527 Old 04-27-2012, 07:16 AM Thread Starter
willydigger
130K is great with no laughing monkey. Like many have said, there is no harm in checking. You may find a gear on it's last leg, or you may be pleasantly surprised with a small wear pattern. Check it, it's free and you'll feel better about knowing. Also know, there is no lube to the upper bushing so there is still potential even if everything looks good.
We've confirmed recently that the upper bushing is porous allowing for some lubrication. Maybe your Jeep has a "good" OPDA. Check it and be sure.
All the info is on the first page of this thread.
post #3089 of 5527 Old 04-27-2012, 07:21 AM
chevy2169
MAy seem like a dumb question but I'm not sure of the answer. If an 05 or 06 engine does fail, can't you replace it with an earlier 4.0 from an 04 for example? Or is the ECU completely different?
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dip****s.
chevy2169 is offline
post #3090 of 5527 Old 04-27-2012, 07:24 AM
keithert
keithert's Avatar
The pre 05 has a completely different ECU so you can't just swap the parts. Plus if you are in an area with emissions testing I don't believe you can legally put an older engine into a vehicle.
keithert is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
