2005-06 Jeep OPDA_CPS_Distributor Failure - Page 203 - JeepForum.com
 10Likes
post #3031 of 5527 Old 04-23-2012, 08:46 PM
chevy2169
This thread makes me paranoid. I have almost 45k on my 06 and haven't had a problem. Is this something that happens to every 05-06 or is it just certain ones? Should I be worried about it even if the laughing monkey hasn't happened? And if so should I take steps to prevent it? Seems like a lot of time, work, and money.
I think I may try the 5w-40 diesel motor oil on my next oil change after doing some reading on here. Anyone else seen good results from this?
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dip****s.
chevy2169 is offline
post #3032 of 5527 Old 04-23-2012, 09:19 PM
flying_bosun
It happens to many, not most, not all, but many. No need to worry, if you do an inspection of the gears and shaft as described in the first dozen posts here. Laughing monkey doesn't set in slowly; for me, it was just there one morning. Choose one of the mods described, too. Choose a good oil as discussed, as well, not a diesel oil. IMO. Not too much time to handle.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3033 of 5527 Old 04-24-2012, 06:38 AM
pwmac
Flying_bosen is correct.
You will never know if you have an opda issue until you pull the thing and look.
I saw one rig with trashed OPDA at 8500 miles and mine at 18k was perfect. If you read the first page you should note that the opda will be bad with no laughing monkey. There is very little or in my case no expense for the Fog mod. I just found the stuff required in my collection of auto repair items. The local Ace hardware store has the necessary tools. Please re read the oil recommendations. 10w30 Valvoline VR1 is my recommendation for you. If not in stock at your local store have them order it. Or get it cheaper off the Internet. If you do your own research on oils you can find the zink content of various oils. Choose one with the correct viscosity and around 1400ppm of zink.
PaulW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #3034 of 5527 Old 04-24-2012, 07:01 AM Thread Starter
willydigger
chevy, pick a nice day, review the TDC video or the sharpie video on the first page. Check it first. Some have no problems and some do. I won't get into most/all/many since we don't know, but let's just say there are enough incidents to warrant a 3000 post thread where you rarely hear anything from other model years.
Chances are you will have wear. If so it looks like modifying the existing OPDA or starting over with a new OPDA and modifying are your options.
The oil cup or oil bath design are relatively easy to complete and will offer substantial improvement over the grease design.
Also to clarify, Mobil 1 5w40 Turbo Truck Diesel is a mixed fleet oil suitable for gasoline and diesel vehicles. It is not a traditional diesel oil. I've been using it for over a year with no problems. That or VR1 are the most popular oil, however there are some Shell Rotella brands that are suitable too.
The first page will have current info, videos, pics, and a summary of a lot of the stuff we've discussed over all these pages.
It's good to be concerned about it. I was completely freaked when I found out (granted I had laughing monkey), but over times I've realized it's very manageable it you take easy proactive steps.
willydigger is offline
post #3035 of 5527 Old 04-24-2012, 08:15 AM
aballas
I keep seeing this over and over and like chevy2169 I'm paranoid. I'm right in the date range 2005 TJ (12/2004 build date.)
My TJ has 82000 miles on it, and I'm almost scared to pull the OPDA and look. It's running fine. I don't want to screw up a good thing, but I feel like I'm driving a time bomb.
aballas is offline
post #3036 of 5527 Old 04-24-2012, 08:21 AM Thread Starter
willydigger
It will take 20 minutes to check and then you'll know. All the info is on the first page.
post #3037 of 5527 Old 04-24-2012, 08:30 AM
Fingers302
That's like saying youre worried you may have cancer and not getting tested because you feel fine. Just pull it and see. Then you can fix it or rest easy. Either way, its all for the best.
Fingers
06 LJ Rubicon, not stock
83 CJ 7, all stock
84 CJ7, dang near stock - Daily Driver!
Fingers302 is offline
post #3038 of 5527 Old 04-24-2012, 09:13 AM
flying_bosun
I've said in the past that it's like your jeep has herpes and needs treatment to prevent an control outbreaks, but cancer is far better. It runs in the family, you have genetic predisposition for it, the cause of onset is a mystery, it's completely treatable if diagnosed in time, and will spread and destroy your insides if you ignore it or refuse to to admit it can happen to you, too.
My jeep had to have a cam transplant because I ignored the symptoms and thought it was just a cold; now after a very expensive surgery, she's in complete remission and gets regular checkups and preventative treatments to be certain it stays in remission.
Be a loving partner and play doctor with your gal once in a while.
― Ron Paul
post #3039 of 5527 Old 04-24-2012, 09:46 AM
chevy2169
I'm going to pull it right now and take a look. If there is no scoring or damage to the shaft should I still consider doing a mod?
post #3040 of 5527 Old 04-24-2012, 09:51 AM
flying_bosun
Yes.
― Ron Paul
post #3041 of 5527 Old 04-24-2012, 09:57 AM
Fingers302
Again, why would you not mod it? There is no way lubrication can get to the upper bushing. Drill it, put a little tiny oil cup on there, and squirt a couple of drops of oil in every oil change. I'm sure Willydigger could help. He did mine. Ask him if you could ship him a new one for him to mod for you. Grease fitting or oil cup - how could this not be a good idea? Its great (and cheap) insurance.
Fingers
83 CJ 7, all stock
post #3042 of 5527 Old 04-24-2012, 10:47 AM
chevy2169
Jeep won't start. Everything went back together correctly. Marks were lined up adn everything. Turns over, just won't start.
post #3043 of 5527 Old 04-24-2012, 01:40 PM
lope
lope's Avatar
Did you plug the wires to the sensor back in? Ask me how I know this can happen!
lope is offline
post #3044 of 5527 Old 04-24-2012, 02:27 PM
msu33
Yep! I sent Willydigger a new OPDA, and he had the mod complete and ready to ship the same day he received it.
msu33 is offline
post #3045 of 5527 Old 04-24-2012, 03:33 PM
chevy2169
Yes. It wants to start just wont stay on.
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
