2005-06 Jeep OPDA_CPS_Distributor Failure - Page 201 - JeepForum.com
 6Likes
post #3001 of 5484 Old 04-17-2012, 12:34 PM
Bigbob
Bigbob's Avatar
Originally Posted by LRod View Post
I don't have a seal on it yet, just regulating the flow with the valve. Where did you pick up the seal you used?
Could a machine shop cut an "O" ring groove in the upper end of the shaft and get a good seal? I only have the one OPDA other wise I'd try the "O" ring repair.
I was going to do the o-ring on the shaft. Not sure if it'd work or not.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #3002 of 5484 Old 04-17-2012, 01:25 PM
LRod
Maybe not? too much friction over time. I've regulated the flow to a point where it doesen't spill, but it drips a few drops overnight. I don't know how much it's lubricating but I can see that the shaft is oiled. Keep in touch.
LRod is offline
post #3003 of 5484 Old 04-17-2012, 03:55 PM Thread Starter
willydigger
I've got some interesting news. I was in the process of doing a FogMod. One of the steps is to remove the factory grease. Today was warm 75-80F and when I removed the grease it was separated a bit. It was unusually oily. I took a good look at the upper bushing and noticed there was oil residue, which is very atypical. I decided, before drilling the hole through the bushing, to put some air pressure in the factory hole to see if the oily grease was able to somehow pass through the bushing. It did.
willydigger is offline
post #3004 of 5484 Old 04-17-2012, 04:04 PM
Bigbob
Bigbob's Avatar
Wow, that is interesting. The only possible way in the world the design would work is if it had a porous bushing, witch it appears it does.
But being so many bushings have worn or failed due to no lubrication I still call the factory OPDA a failed design.
6 Speed, Hardtop
Bigbob is offline
post #3005 of 5484 Old 04-17-2012, 04:13 PM
BioTex
Bronze pilot bushings that go into the end of the crankshaft/transmission input shaft, are meant to be soaked in oil overnight prior to installation. They do soak up oil and will last a lot longer than if installed dry.
Wonder if the factory used a porous bronze???
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline
post #3006 of 5484 Old 04-17-2012, 04:19 PM
LRod
Any possibility of something like this working?
http://www.daemar.com/bushings_solid-metal_64.htm
LRod is offline
post #3007 of 5484 Old 04-17-2012, 04:29 PM Thread Starter
willydigger
I remembered in the first thread Fog mentioned a channel that allowed the air to escape during his test. I think this is what he saw.
I think it is a porous bushing and I think it is poor. The grease needs to be hot. Granted it won't take long to get hot, but it's not hot at startup where there is no lubrication (laughing monkey) and any lube allowed to pass through the bushing is trapped in the upper bushing area, leading to that dark black sludge that we've seen from time to time. This sludge likely causing start up binding.
Is it also possible that the lubrication is not long lasting explaining the shaft and bushing deterioration causing catastrophic damage?
Thinking out of my ***, but I would suspect the oil cup (and variant of oil applications) are even better now. The oil will be able to seep through the bushing all the time. I still feel better about the hole in the bushing, but now I think the entire bushing will seep the oil. In addition, the oil visibly drains out the top of the bushing, so nothing is getting trapped and hardening.
I also thing this may make the original FogMod with grease moot. The only difference is the Aeroshell grease has a lower cold parameter so that hopefully it is still relative fluid at low temperatures.
post #3008 of 5484 Old 04-17-2012, 07:45 PM
Bigbob
Bigbob's Avatar
A poor design is a poor design. Engineers think too hard.
I'd still drill a hole. The porous bushing ain't too porous maybe? Besides, even with a hole the bushing can still seep oil.
6 Speed, Hardtop
Bigbob is offline
post #3009 of 5484 Old 04-18-2012, 09:42 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Willy, that is interesting. Back when I first disassembled my OPDA I removed the plug & found the “grease” everyone has. I did the same as you & blew air into the reservoir. Believe it or not I saw the same thing you saw. I stopped to get a better light to really see what was happening. With better light I again pressurized the reservoir. This time I didn’t get anything so I discounted it. Maybe the reason it didn’t repeat was because I had pushed all the available “grease” through the bushing. (?) I did find an oil film on my shaft but attributed it to the tech giving it a shot of oil when the E05 TBS was done. Now I have to wonder.
One time I asked if the grease was supposed to get to the shaft by osmosis. Maybe that is exactly how it is to work. That said, the lack of lube on all these dry shafts says it’s not a good method.
The only one I know of that has removed a top bushing is Tkki. If he is following this maybe he can take a closer look now that we have seen this & give us a report. Also a couple guys have cut one in half. Maybe they can pop the halves out & examine them. You would have to see the back side (O.D.) to tell because I would think that once the bushing surface starts to gall as most we have seen have done, the “porous” surface would be damaged to the point no lube would pass. I’m guessing the one in your video was a new unit, right?
BTW: GREAT VIDEO!!
Rubi4MyMrs is offline
post #3010 of 5484 Old 04-18-2012, 09:45 PM
keithert
keithert's Avatar
How can the grease go through the bushing? Wouldn't the bushing have to be made like swiss cheese for oil to pass through it?
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #3011 of 5484 Old 04-18-2012, 09:52 PM
surfcat2000
bushing
in the good old days before roller pilot shaft bearings. when we would install a bronze bushing in the end of a crankshaft we would put one finger over the end then fill it with oil and squeeze down on it with the other finger till oil came out the pores That way we pre oiled it. Jeff
surfcat2000 is offline
post #3012 of 5484 Old 04-18-2012, 11:41 PM
locosdj
My 06 Rubi has 3000+ miles with the oil bath and hole drilled through the bushing with ZR-1 oil. Absolutely no signs of wear. The only problem I have is dealing with the set screws in the OPDA dripping oil. Will fix the drips with weld next oil change.
locosdj is offline
post #3013 of 5484 Old 04-19-2012, 02:28 PM
Bigbob
Bigbob's Avatar
JB Weld should fix them. And if you ever got to remove them a little heat will work. Do you have a vent on the cover? I think engine air pressure can work itself past the seal and pressureize the housing. I'm going to drill a small hole in my cover for now until I find a proper vent.
I'm thinking of one of these for McMaster Carr, propably a 1/8" NPT size.
http://www.mcmaster.com/#9833K19
6 Speed, Hardtop
Bigbob is offline
post #3014 of 5484 Old 04-19-2012, 06:29 PM Thread Starter
willydigger
Just a quick follow up on the porous bushing. I think Rubi4MyMrs confirmed this already, but I received another OPDA and did the air test. Again it was bubbling out oil.
post #3015 of 5484 Old 04-19-2012, 06:31 PM Thread Starter
willydigger
...Do you have a vent on the cover? I think engine air pressure can work itself past the seal and pressurize the housing. I'm going to drill a small hole in my cover for now until I find a proper vent.
I'm thinking of one of these for McMaster Carr, probably a 1/8" NPT size.
Can't hurt and a cheap safeguard.
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
