2005-06 Jeep OPDA_CPS_Distributor Failure - Page 195 - JeepForum.com
 10Likes
post #2911 of 5527 Old 03-27-2012, 05:49 PM
JeepinAaron
2003 WJ
ok so i've obviously figured out which way not to rotate it, tiny bit the wrong way and the Jeep won't start, so now back the other way. I did develop a new question.
Is the crank pulley at the bottom of the engine? I don't see any marks anywhere to line up TDC if I needed to do that.
2003 WJ Laredo
http://www.jeepforum.com/forum/f22/2003-wj-off-road-minivan-2346505/#post22320625
JeepinAaron is offline
post #2912 of 5527 Old 03-27-2012, 06:10 PM
flying_bosun
crank pulley is the big one with serpentine belt in front. The timing mark can be very hard to find, especially with the belt on. You can see it in this pic, but it's been painted to make it easier to see (thanks, Rubi4mymrs). You will have an easier time finding it if you remove the belt.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #2913 of 5527 Old 03-27-2012, 06:40 PM
JeepinAaron
2003 WJ
Ok I got it lined back up so the check engine light went off. Now the ODPA is ticking bad, much worse than before. I don't see how taking it out and putting it back in changed it that much but oh well. I'm going to order a new one tomorrow.
There is lots of play in the target wheel when it is installed. Also I can slightly pull the target wheel up and down, is this normal?
2003 WJ Laredo
post #2914 of 5527 Old 03-27-2012, 07:02 PM
Heath
2014 JK Wrangler
You can take some of the up and down slack out.
2013 JKU Rubicon
Heath is offline
post #2915 of 5527 Old 03-27-2012, 07:06 PM
flying_bosun
How do you propose to do that?
― Ron Paul
post #2916 of 5527 Old 03-27-2012, 07:25 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Rubi4MyMrs is offline
post #2917 of 5527 Old 03-27-2012, 07:43 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
I can add that probably most of the rotational play you are getting is from the up & down movement. As the shaft goes up the gear rotates the shaft. If you hold the wheel down how much rotating play are you actually getting. That would come from the play within (between) the gears. A small amount would be normal but any wear on either gear would add to it. When the engine is running the shaft lifts up against the thrust washer & stays there as long as it is running so the up & down play shouldn’t be contributing to any excessive play from the shaft.
post #2918 of 5527 Old 03-29-2012, 08:08 PM
Brian86992
I had abnormal wear on the OPDA on my 2002 TJ's 4.0.
Because of the abnormality of the situation (being an earlier model) I created a separate thread which can be found here: http://www.jeepforum.com/forum/f9/op...002-a-1350053/
Protect the Constitution
4 linked DD on coilovers
Brian86992 is offline
post #2919 of 5527 Old 04-05-2012, 05:41 PM
stripperguy
I just picked up an '05 LJ insurance wreck with 42 k on the odometer, it runs flawlessly and is nice and quiet, no laughing monkeys.
Thought I got a great deal ($7,000-only needs an axle) and now I find this thread.
This scares the sh*t out of me!!
Has any looked into modifying the housing to accept a rolling element bearing?
Without taking it apart myself, could someone tell me the size of the shaft? If it's a common size, and there is room in the housing, maybe a sealed ball bearing could be a solution. (I'm a design engineer by trade))
I apologize in advance if this has already been considered, I only read every 10th page or so...
stripperguy is offline
post #2920 of 5527 Old 04-05-2012, 06:10 PM
lope
lope's Avatar
I don't remember the exact size but IIRC the shaft is a little over 1/2"-definitely an odd size. I think that's what's kept anyone from trying a sealed bearing so far.
lope is offline
post #2921 of 5527 Old 04-05-2012, 06:14 PM
stripperguy
Thanks for the quick response Mr. lope.
The most common bearings are sized by their inner diameters, usually metric. So maybe a 12 or 13 mm bore?
Anyone else? Even if the shaft is an oddball size, a small sleeve could be shrunk over the shaft to adapt to a common bearing ID.
post #2922 of 5527 Old 04-05-2012, 06:25 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Here is where I was when I looked into bearing &/or bronze bushings. #842 this thread. Bushing sizes: I.D. 0.533in/13.55mm
O.D. 0.765in/19.46mm
I searched all over. No bearings but can get blank bushing material including Oilite & make some. Still need lubrication though.
post #2923 of 5527 Old 04-05-2012, 06:25 PM
CoRubicon
I've got a new unused OPDA on my work bench torn apart for mods. Let me measure the shaft.
CoRubicon is offline
post #2924 of 5527 Old 04-05-2012, 06:39 PM
flying_bosun
Meh, don't let it scare you, just be aware and ready. I think so far the best option is to FogMod or add the oil bath (preferred). Other ideas are welcome and I'll even donate an OPDA, of you comeuppance with something that needs trial.
BTW, I measured the shaft at .530 inches (just under 13.5mm). That's on an OPDA with under 2k mi.
― Ron Paul
post #2925 of 5527 Old 04-05-2012, 06:53 PM
stripperguy
Be aware and be ready...yup, I'm planning on that!
I need to go back to the 1st page and study those cross sections some more. Even if there isn't room in the housing for a ball bearing, the housing can be modified. or just plain replaced!! Given enough time and money, almost any problem can be solved.
Thanks, guys.
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
