2005-06 Jeep OPDA_CPS_Distributor Failure - Page 17 - JeepForum.com
 10Likes
post #241 of 5527 Old 01-26-2011, 02:17 PM
jkp
Originally Posted by Zetto View Post
The BBB may also be able to pull in the NHSTA who can push for an official recall and fix.
Anyone with this problem should file a complaint at NHTSA themselves. Having your engine die and/or seize driving down the hwy is a safety issue.
https://www-odi.nhtsa.dot.gov/ivoq/
'92 Islander
'06 Rubicon
jkp is offline
post #242 of 5527 Old 01-26-2011, 03:17 PM
TJXTWO
I used a lawyer to lemon law an excursion about eight years ago. Ford ended up having to pay all legal costs and took the vehicle back. After the way I have been treated by Chrysler I have thought about contacting this guy. This was before I knew about the OPDA issue. I should shoot him an E-Mail and see what he has to say.
03 TJ Sport, 4.5" RE SuperFlex short arm lift, Tereflfex ST swaybar, 33" MTR's, Body Armor bumpers @ sliders, 5 speed manual... 06 TJ Rubicon, 4.5" RE long arm lift, Currie Antirock front and rear , OR Fab bumpers @ sliders, K@N intake, custom exhaust, 1" BL , 1" motor mount lift, 35" MTR's on Pro Comp Alloys, 6 speed manual.
TJXTWO is offline
post #243 of 5527 Old 01-26-2011, 03:20 PM
TJXTWO
[QUOTE=jkp;10860027]Anyone with this problem should file a complaint at NHTSA themselves. Having your engine die and/or seize driving down the hwy is a safety issue.
[URL]
We used the safety angle on Ford (loss of power on freeway) and they took the vehicle back very quickly. Before we mentioned it was a safety issue they kept trying to fix it.
TJXTWO is offline
post #244 of 5527 Old 01-26-2011, 03:34 PM
ChaseB
Nice, wouldn't hurt to ask his opinion on the matter.
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #245 of 5527 Old 01-26-2011, 04:19 PM
Jeffro06
Jeffro06's Avatar
I had the OPDA "repair" done today. I stopped in and snapped a couple of pictures.
There was some wear on the cam gear they replaced, not as bad as some I've seen on here, but wear just the same. The OPDA spun like top, no resistance on the shaft.
I picked it up this afternoon, it runs great, no issues. I didn't figure there would be. I had to pay for the "repair" in full ($149.00) and Chrysler is going to reimburse me once I send them of copy the bill and my reciept. They said I wouldn't have to pay anymore than 50%, but didn't rule out full reimbursement.
I don't know what more could have been done at this point, being as how the OPDA units are on major backorder, and even if you get one it's the same faulty product.
I'll stick with the TDT Mobil 1 and hope for the best I guess.
Jeffro06 is offline
post #246 of 5527 Old 01-26-2011, 04:24 PM
ChaseB
Wow, the wear on my gear is worse and my dealership said there wasn't anything wrong with the Jeep at all. Just goes to show you the level of ignorance we are dealing with concerning this issue. Hope it works out for you Jeffro. So did they replace the cam gear? Or the entire OPDA?
1984 CJ-7 Renegade
ChaseB is offline
post #247 of 5527 Old 01-26-2011, 04:27 PM
Jeffro06
Jeffro06's Avatar
Just the cam gear.
Jeffro06 is offline
post #248 of 5527 Old 01-26-2011, 04:57 PM
ChaseB
Originally Posted by Jeffro06 View Post
Just the cam gear.
I don't know what's going on here......the more I read the more I'm left wondering. Perhaps the issue isn't just the OPDAs, could be a problem with the cams too.....if that's the case I better start putting some money away.
Some interesting information on this page.
http://www.classicinlines.com/DizzyGear.asp
1984 CJ-7 Renegade
ChaseB is offline
post #249 of 5527 Old 01-26-2011, 05:11 PM
Jeffro06
Jeffro06's Avatar
Just to be clear it was the cam drive gear, on the OPDA, not the gear in the motor.
Jeffro06 is offline
post #250 of 5527 Old 01-26-2011, 05:12 PM
ChaseB
Okay, sorry I misunderstood you. That makes more sense, that's chrysler's fix for the problem...just keep blowing through gears
Your wear pattern on your OPDA doesn't look bad at all in my opinion compared to what I have seen.
1984 CJ-7 Renegade
ChaseB is offline
post #251 of 5527 Old 01-26-2011, 05:53 PM
Slacksuperstar
So what exactly is the failure rate for the OPDA on the 2006's mine currently has no pressure or noise issues with 50K on the clock I might pull it to check for wear.
Slacksuperstar is offline
post #252 of 5527 Old 01-26-2011, 06:59 PM
lope
lope's Avatar
Lope, do you have a date as to when they serviced your gear?
I believe it was replaced before it ever left the lot. I checked the service records on Jeep.com and there is no indication it was performed after being purchased by the original owner, so I can only conclude all of the miles on my jeep were put on with the replacement gear (53k).
That was a pretty interesting read you pointed us to Chase. I particularly found this interesting concerning new distributor gear "break in".
(from http://www.classicinlines.com/DizzyGear.asp)
"A distributor gear needs to be broke in, following exactly the same procedures as you would for a rebuilt motor (running the motor at 1500-2000 rpm for twenty minutes). During the distributor gear (or camshaft) break in period provide additional lubrication by coating the gears thoroughly with zinc or moly break-in lubricant. This should be applied to both the cam gear and the distributor gear prior to installation.
Some cam manufacturers recommend installing a new or reconditioned distributor gear whenever the camshaft is replaced. The reason for this is simple. The cam and distributor gear actually seat to one another during the break in period, similar to a cam lobe and lifter. Once this happens, the distributor gear may not seat properly to a new camshaft gear. It may also be beneficial to lap the gears prior to break in, as discussed later in this topic. Never use an old worn gear as this may cause premature failure in short order.
DO NOT use synthetic oils during the distributor gear break-in period. Subsequently, any suitable 30, 40, or multi-viscosity oil (i.e. 10W30) can be used. Always verify gear wear after a break-in period of several hours, looking for proper mesh, tooth alignment, and/or excessive wear. Many gear failures are due to improper (or lack of) distributor gear break in."
Also, it talked about proper end-play being a factor in improper gear wear.
lope is offline
post #253 of 5527 Old 01-26-2011, 07:06 PM
ChaseB
Yes, they had a lot of interesting points, making me wonder if I should just mod my existing unit???
1984 CJ-7 Renegade
ChaseB is offline
post #254 of 5527 Old 01-26-2011, 08:21 PM
Xlr8n
1967 JK Wrangler
Very good read. Thanks. Lot of info in the article that I've forgotten over the years.
Xlr8n is offline
post #255 of 5527 Old 01-26-2011, 09:17 PM
05LongJeep
SLACKSUPERSTAR- Check your OPDA soon. My 05 LJ has 50K on it and Mobil 1 for at least 1/2 of that. The tip of the gear tooth is razor sharp. Meaning that the gear is wearing into the back side/non-wear side of the tooth. If for no other reason, check it for the piece of mind. It is easy, Just follow the video.
Stock till its paid off 2008 Jeep Wrangler Unlimited 4dr. JK
Loved & Lost due to Faulty OPDA--2005 Jeep Wrangler Unlimited LJ. Rough Country 2.5" Lift w/Stearing Stab. R/C sway bar discos. 31x10.50, Hella Windshield Lights & A Never Ending List of Dreams
05LongJeep is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
