2005-06 Jeep OPDA_CPS_Distributor Failure - Page 167 - JeepForum.com
 10Likes
post #2491 of 5534 Old 12-16-2011, 06:58 PM Thread Starter
willydigger
Originally Posted by efm-7 View Post
So I pulled my OPDA from my 2005 TJ with 165,000kms on it, I have two extremes to share:
We have concluded that binding and gear wear are not related, though binding will contribute. The fact that yours spun freely corroborates that fact. The FogMod, although a great solution to binding, may not help with gear wear. It did for me and a few other, though my mileage is still relatively low.
Regarding the oil, that is very strange. If the seal failed I would expect more oil. There have been some instances of black sludge flecks which I attributed to a seal failure and oil sludge. Your pic looks like fresh new oil. Very odd.
willydigger is offline
post #2492 of 5534 Old 12-16-2011, 07:06 PM
efm-7
I will report back when I take it apart. For the gear wear, I guess I will have to try different oils or ZDDP additives.
efm-7 is offline
post #2493 of 5534 Old 12-16-2011, 07:57 PM
efm-7
Is cam replacement an immediate need? :S
efm-7 is offline
post #2494 of 5534 Old 12-16-2011, 09:45 PM
rnorma1
The video demonstrates how to put in the same one that was just removed. I'm installing a new one.
It was super easy to turn the engine once I got the rear wheel up anyways. The only annoying thing was running back and forth from the wheel to the engine since I was doing this alone :P
Rolling the car forward is not an option for me since I dont have much space to work on this. There's maybe 4 feet left once the jeep is in the garage, and it's too cold and rainy outside
I put a new one in mine as well but I just matched the marks from the old one and it worked fine.
Whatever the case, good luck with it!!
rnorma1 is offline
post #2495 of 5534 Old 12-18-2011, 02:57 PM
RockyMnt1
I just pulled my OPDA for inspection:
- 3779 miles since the install of a new Fogmodded OPDA
- Using Areoshell MS33 grease
- OPDA spun freely upon removal
- there were discolorations on the upper (toward the flywheel) portion of the shaft, but the shaft surface felt smooth. I removed the darkened areas with a few swipes of emory cloth.
- I changed out the grease zerk from a short shank to a long shank and recharged the OPDA with more Areoshell MS 33.
- I just switched from M1 High milage to M1 TDT oil.
- the gear looked to be in good shape and the wear looked symetrical.
- no problem with the removal or reinstall, allthough getting the OPDA clamp back on took some time.
- oil pump tang looked normal (No wear)
- many thanks to Willy and Fog for all of the effort/info.
- I am going to try to upload my first pics of the assembly:
RockyMnt1 is offline
post #2496 of 5534 Old 12-18-2011, 04:07 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Looks good! Especially the gear. How was the old one when you replaced it?
Rubi4MyMrs is offline
post #2497 of 5534 Old 12-19-2011, 11:48 AM Thread Starter
willydigger
I agree. The gear looks like mine does. Whether it's FogMod or ZDDP, I'm very pleased with the results.
post #2498 of 5534 Old 12-19-2011, 12:27 PM
locosdj
I like your idea. What if we drilled a small hole at a 45 angle through the upper bushing to ensure oil is delivered from the bath.
locosdj is offline
post #2499 of 5534 Old 12-19-2011, 01:07 PM Thread Starter
willydigger
I assume you're referring to the oil bath. A 45 isn't necessary and adds to the difficulty. Draining back to the reservoir that feeds to the bushing is effective enough. Considering it wicks out, the majority of the bushing is lubricated. A hole straight down it good enough.
post #2500 of 5534 Old 12-19-2011, 06:42 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Drilling the bushing like that or like I posted in #2400 earlier this month would save some work on an un-modded unit because you could skip the mods to the lower part of the housing. No drilling, tapping, removing the plug or cleaning the reservoir. That is if you are going to the oil bath & sealing the top section of the housing.
post #2501 of 5534 Old 12-19-2011, 07:12 PM
efm-7
Did you post a diagram? Because if you did, it's not showing up for me
efm-7 is offline
post #2502 of 5534 Old 12-19-2011, 07:34 PM
Bigbob
Bigbob's Avatar
Maybe a stupid question:
If you drilled the hole (like in the oil bath method) and removed the oil seal do you think enough oil would get up there like a a standard "old School" distributor to keep things lubed? I guess the housing would fill with oil if things worked wonderful and then drain down via the hole when the engine is shut off. Of course you'd want the housing sealed pretty good to keep contaminated oil draining back down into the engine.
Second stupid question:
Considering a healthy engine with little wear--is the crankcase under a slight vacuum from the PVC hose or is it canceled out?
Vacuum hose to the sealed OPDA housing to help suck oil up from the pinion gear area?
(No, I don't take drugs)
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is online now
post #2503 of 5534 Old 12-19-2011, 08:49 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
No, but borrowing from your diagram it would go like this
post #2504 of 5534 Old 12-19-2011, 09:33 PM
efm-7
Ah okay. Hmm, I think i'd still feel a lot more comfortable with the hole being lower. That way as the oil level gets low, it won't have as many "disconnects" with the oil supply during regular movement of the vehicle.
I don't think drilling, tapping, cleaning the factory reservoir is that big of a deal though. But I may only be saying this because it looks like a small job compared to a CAM REPLACEMENT which I may be looking at now
efm-7 is offline
post #2505 of 5534 Old 12-19-2011, 10:05 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Not a big deal for me either but I already had all the tools needed for the job but I realize not all do & several have questioned where to get them & even you had trouble sourcing the parts needed which lead to a variation on the original mod. This is just a potential variation for those who need a simpler way, being mindful that it will require sealing the top part of the housing to contain the oil.
FarFire70
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
