2005-06 Jeep OPDA_CPS_Distributor Failure - Page 166 - JeepForum.com
 10Likes
post #2476 of 5527 Old 12-15-2011, 04:05 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
pics? Did you get it back to 4 o'clock?
Rubi4MyMrs is offline
post #2477 of 5527 Old 12-15-2011, 05:32 PM
dionysius
Just in the nick of time! I received my new OPDA and installed it today. Lots of wear on the old one and very difficult to rotate by hand. New gasket wasn't with the new unit so I re-used the old one. Wasn't too difficult, had to turn the oil pump several times to get things to line up. Biggest PITA was the 1/2 inch hold down bolt. No luck finding a 6 point 1/2 inch wrench, used a ratcheting box end and it worked fine.
Thanks to all you super techs for this thread, saved my bacon. Dealer wanted $400.00 plus to do this. 25 minutes and I was done. My engine has less than 40K miles.
Denis
Enjoy every sandwich!
dionysius is offline
post #2478 of 5527 Old 12-15-2011, 08:06 PM
efm-7
Man, I'm having the hardest time getting the connector apart. I'm almost temped to chop it off and solder on a new connector if I could even find one.. Any tips?
efm-7 is offline
post #2479 of 5527 Old 12-15-2011, 08:09 PM
efm-7
Nevermind, I didn't pull the red thig far enough.. *bashes head*
efm-7 is offline
post #2480 of 5527 Old 12-16-2011, 04:07 AM
paulpa
I had the same problem,it will be alot easier next time.
paulpa is offline
post #2481 of 5527 Old 12-16-2011, 09:35 AM
efm-7
One thing I noticed was that there was chalk/grease crayon around the TDC mark on the pulley, perhaps evidence of OPDA replacement under previous ownership.
Hopefully I'll manage to get the notorious clamp bolt off tonight, should I buy a long-handled 1/2" wrench for this? Just so I can get more torque.
efm-7 is offline
post #2482 of 5527 Old 12-16-2011, 09:39 AM
LJTom
I bought my jeep used and the guy doesn't know if he had it fixed. Is there a simple way to check if the repair has been completed? Thanks! Tom
LJTom is offline
post #2483 of 5527 Old 12-16-2011, 09:40 AM
dionysius
If the dealership made the repair it will be in their database.
Denis
post #2484 of 5527 Old 12-16-2011, 09:56 AM
LJTom
The seller doesn't think they completed the repair. He beleives they had to order the parts. The dealership went out of business and on the last day they were open they put in the computer repair complete per my local dealer. Now what?
LJTom is offline
post #2485 of 5527 Old 12-16-2011, 10:01 AM
dionysius
Pull it and look at it. If it's hard to turn and the gear's worn bite the bullet and replace it.
Denis
post #2486 of 5527 Old 12-16-2011, 11:28 AM Thread Starter
willydigger
Follow the youtube video on the first page. You'll need a T25 torx (I think I said T20 in the video), a 1/2-6point wrench, and potentially a long flat head screw driver if the oil pump slot doesn't cooperate.
willydigger is offline
post #2487 of 5527 Old 12-16-2011, 01:07 PM
rnorma1
I'm having a hard time understanding all the TDC stuff. It's really not necessary to move the motor. Just follow the directions on that youtube video.
With a manual tranny, you can get the TDC hole to line up easily by putting it in 5th or 6th gear and rolling the jeep forward until you see the hole in the one wheel like up with the hole in the cup.
rnorma1 is offline
post #2488 of 5527 Old 12-16-2011, 01:39 PM
efm-7
The video demonstrates how to put in the same one that was just removed. I'm installing a new one.
It was super easy to turn the engine once I got the rear wheel up anyways. The only annoying thing was running back and forth from the wheel to the engine since I was doing this alone :P
Rolling the car forward is not an option for me since I dont have much space to work on this. There's maybe 4 feet left once the jeep is in the garage, and it's too cold and rainy outside
efm-7 is offline
post #2489 of 5527 Old 12-16-2011, 03:00 PM
BillR
BillR's Avatar
I replaced mine today with a Fog'd unit that Willy did for me. My old one was actually in great shape and spun as easily as the new one. The gear shows very little wear for having ~79K miles IMO.
I sure I knew why some have issues early, and others (like me) never do...
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #2490 of 5527 Old 12-16-2011, 06:52 PM
efm-7
So I pulled my OPDA (REV-B) from my 2005 TJ with 165,000kms on it, I have two extremes to share:
The bad:
MAJOR Gear wear:
The good:
Spun freely.. and get this. EVIDENCE OF OIL!!!
But ugh... I REAAAAALY don't want to replace the cam shaft, lifters, etc....
efm-7 is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
