2005-06 Jeep OPDA_CPS_Distributor Failure - Page 157 - JeepForum.com
 7Likes
post #2341 of 5510 Old 12-01-2011, 08:22 AM Thread Starter
willydigger
Originally Posted by TJJP77 View Post
Exactly...which is why I sourced an OPDA gear from an '04 and earlier unit to replace mine. The '04 and earlier models rarely seem to have had the gear wear problem - that seems to have started with the '05+ parts.
I'm wondering if the crown gear has any wear issues? Maybe getting a pre-05 or crown gear would be a better option.
I'd like to have more data before making that claim though. I guess at this point it can't be any worse.
willydigger is offline
post #2342 of 5510 Old 12-01-2011, 09:29 AM
rubicon17
just pulled mine on a 05 rubi yesterday id post pics but not sure how to on a phone, gear looks good. only has normal wear signs but nothing out of the ordinary. engine has 10,590 miles. is there a part number for the 04 gear? also checked how it spins and it is nice and smooth. how often do you guys think i should check it for wear?
rubicon17 is offline
post #2343 of 5510 Old 12-01-2011, 10:46 AM
dustinweller
Dealer called and let me know that the parts have came in to replace my gear. I have asked that they hold on to my gear so I can check for what wear is evident and to also photo graph it incase of a major failure down the road. as soon as i figure out how to post a pic of it I will.... Greatly appreciate the amount of time everyone has put into this to come up with a fix. Just hope i dont need it.....
dustinweller is offline
post #2344 of 5510 Old 12-02-2011, 02:59 PM
rnorma1
Changed the oil in my 05 Unlimited today and pulled my OPDA for the first time since installing a new one modified with the "Fog Mod" about 5k miles ago or so. The Jeep has about 66k miles on it.
The gear on my original part had more wear than I would have liked but it didn't look like some of the really bad gears I've seen here. Still, not great though. Like everyone else, I was worried the wear pattern in the cam gear would wear through the new OPDA gear too fast.
I noticed some oil in the cup upon taking the cover off but I think it's from the aeroshell grease. The gear looked really good actually so I'm happy about that.
I took it all apart and the shaft had the dark staining at the top that everyone else seems to get but it was still smooth with no scoring.
I reassembled it, greased it up and put it back in and refilled with Mobil 1 5w-40 TD oil. I'll check it again next oil change.
On a side note, I've gotten really efficient at removing, disassembling, reassembling and reinstalling the part. I use the sharpie pen marker method and just reuse the original marks from when I put it in.
Overall, I am satisfied with this solution at this point. This problem came to light here on the forum directly after I bought my 05 and I was fit to be tied at that point. All this time later, it does seem like a problem that can be managed after all. I just really wish someone would come out with a plug and play replacement gear already.
rnorma1 is offline
post #2345 of 5510 Old 12-02-2011, 07:21 PM
TrailJ
So, I have an 06 LJ. I've half watched this issue and half had my head in the sand. Should I bother to go to the dealer our just order a new one? If I order one, where from and what is the current recommended mod? Also, I'm at 90k, so how can I see if PO has done anything for this? Thanks for any assist!
TrailJ is offline
post #2346 of 5510 Old 12-02-2011, 07:21 PM
Bigbob
Bigbob's Avatar
I just pulled mine a year after doing the Fog "grease" Mod last year. I greased it once during that time. Cold morning last week and the monkey was howlling. I am getting a new OPDA and doing the oil cup mod to it. I really think that is the way to go.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #2347 of 5510 Old 12-02-2011, 08:24 PM
BillR
BillR's Avatar
Why do you think the oil cup is better?
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #2348 of 5510 Old 12-02-2011, 08:42 PM
ff33
I would just pull it yourself and check, I was like you and avoiding the issue for about a year now and finally pulled and checked it, super easy to do thanks to the info in this thread. I "believe" if it there has been previous work done by the dealer the gear would have a second pin hole drilled in it, been awhile since I read this whole thing but I think I remember reading that at some point. Luckily my inspection went well, gear had mostly even wear but two of the teeth had longer wear patterns
then the rest which leads me to believe ill develop the problem eventually. It also had zero resistance while spinning and from what I can tell is the original OPDA, I'm at 72,000 miles and I'm just going to keep checking it regularly, already have the spare ready to go if/when I need it.
Edit: the first couple of pages of this thread will be able to tell you how to check it and where to order a new one.
2006 Rubicon LJ, auto, 2" lift, 1.25 bl, mml, tt, armor, winch, 33's, that's it for now.
ff33 is offline
post #2349 of 5510 Old 12-03-2011, 03:34 AM
paulpa
How many miles between greasing it,thank you
paulpa is offline
post #2350 of 5510 Old 12-03-2011, 07:16 AM
Slugger
Hate to hear this, correct me but I remember your Jeep as being low mileage, how many miles since you modded yours? Are you you saying that it needed greasing more often?
Slugger is offline
post #2351 of 5510 Old 12-03-2011, 07:20 AM Thread Starter
willydigger
I ran all last winter with the grease and had no issues. Remember that other stuff makes noise in the cold too. Fan shroud, belts, angry sparrows. I do think that oil would be better for the cold morning, but I have no personal experience confirming that. If the shaft is spinning freely than the grease is working. We have several update reports with the grease saying just that, but I can't say how many winters we've been through.
I run the oil now just to avoid the questions of frequency of greasing and how much to grease. Based on my observations I still recommend 1-2 times a year with 1 small pump. With the oil cup you look to see if it's low and add a little. Much simpler, but I don't know if I'm overlooking something.
I won't say one is better than the other. Provided you're using a quality grease, I think they both will work.
post #2352 of 5510 Old 12-03-2011, 09:20 AM
Bigbob
Bigbob's Avatar
For 75-100 years there has been distributor assemblies using oil as a lube. It's just natural.
Probably about 2000 miles, I drive very little.
I doubt it needs more grease, just a better lube method. Yes, low miles. I have about 4,000 miles on it since I modded it. 22,500 miles on the Jeep.
It was definitely the shaft howling. The noise only lasted a couple seconds each morning.
Here's why I like the oil over grease. After I cleaned mine, re-polished the shaft and reassembled it I noted the shaft spun pretty easy with just some light oil on it, free and easy. I greased it before putting it back in the Jeep and it spun hard. The temperature was about 60 degrees, not real cold. Grease will lube it, oil will lube it better.
6 Speed, Hardtop
Bigbob is offline
post #2353 of 5510 Old 12-03-2011, 03:32 PM Thread Starter
willydigger
I think the howling is due to a binding in the OPDA shaft. Normally this is a result of wear and/or sludge build up. If you had howling after 2000 miles I don't think it was wear or sludge. I think it was too much grease.
You only need a very little bit of grease. There should be no restrictions. For the OPDA's I've done, I've compared pre-grease resistance to post grease resistance and there should be no noticeable difference. This is one of the main problems with the grease method and why I recommend infrequent greasings with only a very small amount of grease.
What was the grease you used? I dealt with temps between 20-30F in Baltimore last winter. I believe I was using a small amount of Aeroshell during that time.
I do agree that the oil cup eliminates all this doubt and confusion. It is also cheaper and the long run. I don't necessarily think you need to change from the grease method to oil if you use minimal grease and Aeroshell. For new FogModder's I would recommend the oil cup mod going forward.
post #2354 of 5510 Old 12-03-2011, 04:40 PM
ChaseB
So for us wanting to try oil cup with existing FogMod units, it would be advised to get as much of the aeroshell grease out of the unit before switching to oil?
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #2355 of 5510 Old 12-03-2011, 05:57 PM Thread Starter
willydigger
Chase, here are some tips for you and others I've done the mod for.
Below is a repost of the required parts to modify the FogMod I've done based on the 1/4-28 grease fitting thread design. If you haven't used a 1/4-28 thread, adjust the adapter to fit your thread pattern.
Do your best to get out the Aeroshell. If there is some Aeroshell in the reservoir I don't think there will be a big issue. Some degreaser should work fine. There is a possibility that the grease can block the hole in the bushing so you want to make some effort to remove it. Aeroshell is very good grease so if it mixes with the oil I don't think there will be a problem.
There may be some minor modification necessary to the adapter and coupling. For the most part I tried to center the grease fitting to the area provided so it may be tight to get the adapter and coupling to fit. I had to modify mine and I would expect most if not all the previous FogMod's to require the same filing. The McMaster parts are aluminum so they will file easily. It may also be easier to file under the target wheel housing instead. So you will need a file (there is a chance you won't, but unlikely).
*From here on, placement for FogMod's with the grease fitting will be a little lower so you don't have to worry about it.
I had to add a small washer as a spacer between the adapter and the threads. The adapter gets a little tight will a 1/16 space so I filled that with a tiny washer.
All said some minor (IMO) work is required. For those of you comfortable with greasing 1-2 a year with only a small amount I don't think there is a reason to change if the work described above to too difficult. People have different levels of expertise and comfort and I understand that. That said if you are savvy enough to pull it and install it the work should not be difficult. Two important things to remember.
1. Be careful with aluminum thread. Tight, but not too tight. If you think it's tight enough it probably is!
2. Degreaser may remove sharpie marks so be careful. Put the lid on before spraying and watch you LDI label. Those numbers can rub off.
I got the parts from McMaster Carr. The below images are for those with a 1/4-28 FogMOD'ed fitting.
44705K36 Low-pressure Aluminum Threaded Pipe Fitting, 1/8" Pipe Size, Coupling, 15/16"l (.93"), 19/32"od
1227K16 Threaded Elbow-style Oil-hole Cover, 1/8"-27 Npt Thread, 1/4" L Thread, 25/32" H O'all
9006T11 Grease Fitting Adapter, Stl, Straight, 1/4"-28 Taper Male X 1/8" Nptf Fem
44665K111 Standard-wall Aluminum Threaded Pipe Nipple, 1/8" Pipe Sz, Fully Threaded, 3/4" Length, Sch 40
The below images show fitment. They are not tightened.
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
