2005-06 Jeep OPDA_CPS_Distributor Failure - Page 155 - JeepForum.com
 7Likes
post #2311 of 5510 Old 11-28-2011, 09:47 AM Thread Starter
willydigger
Originally Posted by Rubi4MyMrs View Post
So with such a good pattern on your gear riding on the old cam makes me feel a lot better & pretty much dismisses the idea that the only way to get proper wear on the new gear to replace the cam.
You and me both. I was holding off check due to fear. I was pleasantly surprised. To be clear I wasn't redlining either. I take it pretty easy on the RPM's.
willydigger is offline
post #2312 of 5510 Old 11-28-2011, 01:58 PM
ChaseB
Hoping mine looks the same way! Close as you can get to "problem solved" with the factory OPDA!
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #2313 of 5510 Old 11-28-2011, 05:37 PM
jutgin
Originally Posted by BillR View Post
Who are these members...?
Yes who are these members willing to mod the OPDA? For a price ofcourse, anyone?
Justin
2013 Wrangler Sport
Chattanooga, TN
jutgin is offline
post #2314 of 5510 Old 11-28-2011, 05:55 PM Thread Starter
willydigger
PM sent.
post #2315 of 5510 Old 11-28-2011, 07:27 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Willy,
Up & running with your oil cup mod?
Rubi4MyMrs is offline
post #2316 of 5510 Old 11-28-2011, 07:42 PM Thread Starter
willydigger
Willy,
Yeah. Today was the first day. I didn't check for oil overflow. I'll check tomorrow. Otherwise no issues. I did get my "just changed the oil" tick.
post #2317 of 5510 Old 11-28-2011, 11:42 PM
ChicagoRod
That has to be the most baffling thing I've ever seen on a combustble engine. Fresh oil = ticking at start up. It makes me not want to change my oil!
Rod
05' LJ
ChicagoRod is offline
post #2318 of 5510 Old 11-28-2011, 11:51 PM
98xjroks
Amen to that! I was originally concerned with this simply because the previous owner reinstalled the OE OPDA with 45k in the new engine. I was deeply relieved when I saw that the cam gear still looked new.
One thing that I would recommend to everyone is to coat the OPDA gear with engine assembly lube prior to reinstalling it.
98xjroks is offline
post #2319 of 5510 Old 11-29-2011, 12:03 AM
Brainwashed2566
It might just be the "you own a 4.0 tick"
2005 White LJ Mild Build = Fun Rig
2003 Ram 1500 5.9 Mag = DD
1997 Green XJ Bone Stock = SOLD
Brainwashed2566 is offline
post #2320 of 5510 Old 11-29-2011, 12:41 AM
ChicagoRod
No, I know exactly what he's talking about. A loud tick at start up that occurs more commonly for about the first 250 - 500 miles after an oil change.
Rod
05' LJ
post #2321 of 5510 Old 11-29-2011, 01:23 AM
Heath
2014 JK Wrangler
What exactly do you think this will do? Plus there are several types of "assembly lube" from oils to pastes, each with a different purposes. They are all either for torquing, protection during installation or assembly, or for initial lubrication. All of which are not needed when reinstalling a used OPDA.
No trying to bust your balls, but it would be nice to keep this thread/process clean and simple and stuck to the facts, without any extra Chicken Little induced processes.
Thanks
2013 JKU Rubicon
Heath is offline
post #2322 of 5510 Old 11-29-2011, 11:51 AM Thread Starter
willydigger
I received the half coupling today. I'll try to get pics up tonight with a mock assembly. It's raining here so I'll have to wait a few days to install.
post #2323 of 5510 Old 11-29-2011, 02:16 PM
ChaseB
I get a tick for only a few seconds right after the oil change. Also no tick with Mobil 1 TDT, but a lot more ticks with the Valvoline VR1
1984 CJ-7 Renegade
ChaseB is offline
post #2324 of 5510 Old 11-29-2011, 04:36 PM Thread Starter
willydigger
Well the half coupling didn't work. Not without some modification. It literally is a half coupling. So the one side will thread normally. The opposite side is threaded in the same direction so it would require a left hand thread nipple. I'm going to see it I can "retrain" the opposite threads tomorrow by chasing it with a right hand tap. Although I suspect it will be mangled it just has to be good enough to be tight and not leak. I think since it's aluminum I might get lucky.
The only other alternative to adapt the FogMod is to shorten the nipple and normal coupling so everything mates well. I don't have the tools for that without it looking like Frankenstein.
Update again tomorrow.
post #2325 of 5510 Old 11-29-2011, 06:57 PM
dustinweller
Hello to all.... after reading the hunderads of posts and looking over the wonderful photos everyone has taken I'm still left with 1 question. Is the new sensor P#CDC0E051AB (Cam Sensor and Oil pump Drive Gear Package) that my dealer has informed me will be used on my 2005 TJ due to a recall going to be a "GOOD" replacement part. currently I have around 77K miles and have no problems with whats in there. Went to the dealer today, jeep was placed on a DRB III scan tool and was told that I had 1deg of "SLOP" in relationship to the cam/oil gear. Was told that they were still going to replace it due to the recall but would take about 3-4 days for the part to show up.
After reading all this information and being put into information overload I'm left wondering "Is the new part there puting in going to be good"?????
dustinweller is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
