2005-06 Jeep OPDA_CPS_Distributor Failure - Page 15 - JeepForum.com
 10Likes
post #211 of 5534 Old 01-25-2011, 07:01 PM
TJXTWO
If you replace the stock 4.0 in an 05/06 TJ/LJ with a strocked 4.0 from one of the reputable builders it will still have to use the same OPDA because of the computer right? I would think the answer would be yes, but was wondering if there was a way around it with a motor swap minus changing the computer?
03 TJ Sport, 4.5" RE SuperFlex short arm lift, Tereflfex ST swaybar, 33" MTR's, Body Armor bumpers @ sliders, 5 speed manual... 06 TJ Rubicon, 4.5" RE long arm lift, Currie Antirock front and rear , OR Fab bumpers @ sliders, K@N intake, custom exhaust, 1" BL , 1" motor mount lift, 35" MTR's on Pro Comp Alloys, 6 speed manual.
TJXTWO is offline
post #212 of 5534 Old 01-25-2011, 07:27 PM
lope
lope's Avatar
For you guys waiting on back-ordered OPDA's, I found this to maybe get you by.
http://cgi.ebay.com/ebaymotors/JEEP-...Q5fAccessories
lope is offline
post #213 of 5534 Old 01-25-2011, 07:33 PM
ChaseB
Good find! Not a bad price if it's in good shape!
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #214 of 5534 Old 01-25-2011, 07:38 PM
lope
lope's Avatar
FogMod it!
lope is offline
post #215 of 5534 Old 01-25-2011, 07:43 PM
ChaseB
FogMod it!
I'm already out some cash waiting for my new unit, they definitely charged my card too. So I better be high up on the list when it comes to mailing those new units out
1984 CJ-7 Renegade
ChaseB is offline
post #216 of 5534 Old 01-25-2011, 08:47 PM
lope
lope's Avatar
If no one else wants it, I may go ahead and buy it, mod it and then sell or loan it to one of you guys until you get yours fixed up.
lope is offline
post #217 of 5534 Old 01-25-2011, 09:32 PM
Xlr8n
1967 JK Wrangler
Well here's an update on another rig.
61,000 miles. Mobil 1 10w-30 High Mileage for about 50,000 of those miles. The initial 10,000 of those were with dino oil. This wear may have occured early on and then been kept from failing by the use of the Mobil1, or it may have been gradual. I'll never know.
Anyway, following the very helpful instructions provided on this great thread, I pull mine tonight and it was, shall we say, 'well worn'.
The gears are nearing a razor edge and it needs replaced asap. I'll be making an appointment tomorrow as I'm still under the 7/70 warranty.
Rev. B unit. OPDA Shaft has no resistance at all. Spins freely. Never had any issues. OPDA has no abnormal vibrations when feeling it with engine running.
Luckily The cam gears didn't appear to show nearly the wear of the OPDA gears, but I was only able to inspect a couple teeth that were visible. They looked very minimally worn.
I'm still skeptical about the lifespan of a new OPDA as even if it spins freely like mine has, it still may wear down just as easily as this one did unless they make some improvement to the gear itself. Why all the wear even with no visible drag on the shaft?? After reading these threads, I was under the assumption that the shaft resistance was the cause of the gear wear, but now I'm not so sure. Especially after seeing the difference in wear between the OPDA and the cam itself. Perhaps the OBDA gear was inferior metal.
In any case, I caught it before it blew apart in the motor, and for that I am truly thankful.
Funny thing is I haven't been on this forum in quite a few months and had no idea this was even an issue until I popped in a few weeks ago.
Without this forum, I would never had the heads up to check on this. Thanks much fellow Jeepers!!!
I'l post back after I speak with the local service dept.
Xlr8n is offline
post #218 of 5534 Old 01-25-2011, 09:41 PM
ChaseB
Im left wondering the same thing, as in my OPDA shaft has no resistance whatsoever. I can't imagine it causing the amount of wear shown. Maybe there is something else going on here, but I was under the impression the gear was of the same design as previous non-defective models?
1984 CJ-7 Renegade
ChaseB is offline
post #219 of 5534 Old 01-25-2011, 09:52 PM
Xlr8n
1967 JK Wrangler
It may have been of the same design, but the gear itself may have been farmed out to be made by the cheapest source available overseas. The metal could have been crap, the tolerences of the die could have been off, perhaps it wasn't properly hardened....the list goes on.
When a manufacturer like DC farms out a part to a third party like this, you never really know what the longevity will be until it's too late.
Xlr8n is offline
post #220 of 5534 Old 01-25-2011, 10:14 PM
ChaseB
Very interesting points made. This could very well be a contributing factor to the problem, it would be interesting to see the new gears analyzed and compared to older gears. As in are there different materials present as well as thickness and hardness.
1984 CJ-7 Renegade
ChaseB is offline
post #221 of 5534 Old 01-25-2011, 10:31 PM
Xlr8n
1967 JK Wrangler
Well there was obviously an initial recall of a run of drive gears in the '05's (which mine was not part of), in which DC found the gear was not properly hardened, but it seems that the scope of bad gears was much broader than they indicated.
Seem this is in fact a two-part problem:
1) you may have a bad gear which will wear prematurely.
2) you may have a bushing in the unit which is not sufficiently lubricated which may kill the gear by creating too much drag regardless if the gear is a good or bad variety.
Xlr8n is offline
post #222 of 5534 Old 01-25-2011, 10:45 PM
lope
lope's Avatar
That's a lot of wear. Looks like it goes the whole length of the teeth. What is your build date? Does it fall into the E05 TSB but the gear was never replaced by chance?
I'm not sure we've completely solved this problem yet. I don't feel 100% confident we know the whole story on the gear wear issue. It's like for one reason or another, the gears on some don't mesh well with the camshaft and get eaten up pretty quickly. Does anyone know if the camshaft changed at all after '04 or is the '05-'06's exactly the same?
Xlr8n can you measure the up/down play in the shaft?
EDIT: I see you answered the question about gear replacement before I got this posted
lope is offline
post #223 of 5534 Old 01-25-2011, 10:51 PM
lope
lope's Avatar
I hope there was just a bad batch of gears out there and replacing with a new gear will resolve it. We'll just have to wait and see.
lope is offline
post #224 of 5534 Old 01-26-2011, 06:28 AM Thread Starter
willydigger
I don't think the camshaft gear changed. I think the engine is pretty much the same.
There were allegedly bad gears which prompted the recall. While no change was made to the OPDA bushing.
The Rockwell was tested on old and new gears and the RC was 27, so while there still may be bad gears floating around I think the gears are okay.
Also factor in heat. As the engine runs it gets hot which transfers to the OPDA and the shaft decreasing the clearance between the shaft and bushing. While some OPDA's on the way out show binding at ambient temperatures others may not develop problems until they get hot.
So the current consensus is high ZDDP oil will help reduce the wear on the gears, while improving the upper bushing lubrication will prevent unnecessary resistance on the gears themselves.
After all is said and done, we as a group are making educated guesses. The up/down play may be a factor. There could be differences in the camshaft gears. At this point I'm satisfied with the FogMOD in theory.
willydigger is offline
post #225 of 5534 Old 01-26-2011, 06:43 AM
NextJeep
With the OPDA shortage, are some people still just replacing the gear? I feel like Crown had a gear that fit, but now I can't seem to find the part. Wouldn't it make sense to do the FOGmod and change the gear out, or is there another reason to replace the whole shebang?
Thanks again to FOG, Willy, and all that are doing so much work on this.
NextJeep is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
