2005-06 Jeep OPDA_CPS_Distributor Failure - Page 146 - JeepForum.com
 6Likes
post #2176 of 5484 Old 10-21-2011, 02:12 PM
footypaul
Well on the advice of the guys here, im going to fogmod my new unit, assuming I can find all the thread taps and grub screw in this two bit town.
footypaul is offline
post #2177 of 5484 Old 10-21-2011, 09:30 PM
Bigbob
Bigbob's Avatar
To be quite honest the size of the grease zerk and plug can vary a bit. I had no metric taps and could not see dishing out the money for them. I used the 1/4" 28 grease zerk and a 1/4" screw for the plug. The 1/4" screw was put in with a dab of red loctite, but I don't think it was needed.
So use what ya got. I bought nothing.
And as far as grease goes, anything is better than what was in there. I'll get flamed for this, but all this high tech specific grease for a bushed shaft is sort of dum IMHO.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #2178 of 5484 Old 10-21-2011, 09:51 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Bigbob is right. Willy says that he used what he had. I think I used a 5/16 allen head set screw to plug the factory hole.
Rubi4MyMrs is offline
post #2179 of 5484 Old 10-22-2011, 08:39 AM Thread Starter
willydigger
I don't know how I feel about the grease. I'd love to say use what ever you find at the auto parts store and call it a day. Experience has show that the Aeroshell 33MS outperformed standard Mobilith 220 (which I would consider a generic all purpose grease). I can't say it was totally the grease's fault since I admit to over pressurizing.
I did change to Aeroshell and after inspection it was much better. I still think I put too much in. Also Tkki's results with Aeroshell were positive, so I have to side with caution and say spend the extra few dollars on the Aeroshell. If we get feedback with alternatives I have no problem linking to the first page.
All that said, the "what type of grease and how much" questions can all be ignored if Rubi4MyMrs oil cup works well. At this point I think during my next inspection I will swap to the oil cup. It will be much easier to manage since it won't require the grease element at all.
I would love to hear from anyone with pic and first hand results with alternate grease. Bob do you have any info and results? Pics preferred of course.
willydigger is offline
post #2180 of 5484 Old 10-22-2011, 10:52 AM
Bigbob
Bigbob's Avatar
No I don't. It's been almost a year since I did the mod though and I may pull it out at my annual oil change in December. I only drive 3-4K miles a year! My scoring was not bad when I did it. I only greased it when I installed it.
6 Speed, Hardtop
Bigbob is offline
post #2181 of 5484 Old 10-25-2011, 06:22 AM
paulyp
2014 JK Wrangler
Quick question guys.
After you drill through the top bushing how are you guys knocking off the burr inside the bushing?
I was thinking some rolled up sand paper?
Cheers
Paul
paulyp is offline
post #2182 of 5484 Old 10-25-2011, 08:43 AM
Bigbob
Bigbob's Avatar
Cheers
Paul
That's how I did mine, just don't go crazy and bore it out too much. I just wrapped some sandpaper on a screwdriver and hit the holes. Mine did not have much of a burr.
6 Speed, Hardtop
Bigbob is offline
post #2183 of 5484 Old 10-25-2011, 10:44 AM
paulpa
I am very sorry if I missed something here,I have been reading this for about an hour,I am new to this forum and do not mean any disrespect buy jumping in but I just have to know why we just cant use the older units that were on the earlier 4.0,,it maybe a stupid question but i can't seem to figure it out.Thank you all,very informative.
paulpa is offline
post #2184 of 5484 Old 10-25-2011, 11:38 AM
badtux
Read the prior 100 pages of this thread and you'll see. The new-style cam position sensor needed for the 2005-2006 ECU won't fit in the older unit. The older unit's cam position sensor is incompatible with the 2005-2006 ECU.
badtux is offline
post #2185 of 5484 Old 10-25-2011, 01:18 PM
paulpa
thank you,,,sorry should have known you guys would have a good reason.Thanks again
paulpa is offline
post #2186 of 5484 Old 10-25-2011, 01:52 PM
Benderff
Benderff's Avatar
No need to read all of that. The important info is all covered in the first pages, thanks to willydigger. The very first post lists topics, and has a link to this.
http://www.jeepforum.com/forum/f9/20.../#post10663481
Benderff is offline
post #2187 of 5484 Old 10-25-2011, 02:17 PM Thread Starter
willydigger
Badtux, I'll add that brief explanation to the Q&A later. I think it will sum up why mechanically the 2004 can fit, but is electrically incompatible. ECU = engine control unit.
http://en.wikipedia.org/wiki/Engine_control_unit
post #2188 of 5484 Old 10-26-2011, 03:19 PM Thread Starter
willydigger
To the FogModders. I got an email recently inquiring about greasing frequency and amount. I was unsure how to answer so I told him what I do, but thought it would be a good idea to get a general consensus of what we do currently.
What I did initially was use a poor grease choice and pumped it until the OPDA was tight. I spun it by hand until it relaxed a bit and then installed it. At around my first oil change, I pumped 2-3 pumps in while running and hot. After inspection I wasn't happy with the results and assumed too much grease. When I installed the Aeroshell 33MS I pumped it full again. Same procedure different grease. Again I wasn't happy. On the last installation I used one pump and haven't touched it since. This was early this spring.
Currently my suggestion included the following:
1. Warm up engine to operating temperature
2. Pump 1 squirt of grease (this is from a mini grease gun 3oz)
3. Do this twice a year
I really don't think it needs a pump every oil change. This is also assuming daily driver 10-12K a year.
Unfortunately I don't have any long term data, but I wouldn't recommend too much grease since it will hydraulically load the shaft and make it very hard to spin. Normally it would take 4-5 pumps (again of the mini gun) to fill the entire reservoir so I would think 1 pump would be fine. Again this is why I recommend the needle attachment. It is difficult to over pump with the needle since excess with push out from the ball check.
Please let me know your schedule of greasing and amount and any extra input you may have. I'd like to get as much info before updated the first page.
Quick bump for some feed back on the above greasing cycle. Can anyone provide some info on their greasing schedule?
post #2189 of 5484 Old 10-27-2011, 04:09 PM
jeffjeep1
jeffjeep1's Avatar
I grease the OPDA every oil change. That is about 3K miles, sometimes more. The most recent change was earlier, about 2200 since I am out of town at a contract job. I am living in a condo place where self performed oil changes are looked down upon.
I do not think I will exceed 3K miles before I get home. I am using M1 0-40 Euro car formula for the high ZDDP level and a Donaldson filter, MS33 grease.
I have pulled the OPDA each of the last two times to grease it. It is easier that way, and I can look at the gear teeth. I always spin the shaft after I grease it to assure no binding, then reinstall.
I have an "old" distributor wrench with the 1/2" box end and a right angle bend in it so I can use a ratchet to loosen the hold down bolt. I unbolt the actual sensor so I do not have to unplug the electrical connector. All bolts ahve never seize, so fingers work great for bolt removal/installation.
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline
post #2190 of 5484 Old 10-27-2011, 05:20 PM
bonza
Originally Posted by jeffjeep1 View Post
I grease the OPDA every oil change...
exactly same as what I do, every 5000 kilometers (3000 miles)
"I like a man who grins when he fights"
Winston Churchill..
bonza is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
