> Models
> Jeep Wrangler Forums
> TJ Wrangler Technical Forum
2005-06 Jeep OPDA_CPS_Distributor Failure
09-12-2011, 09:31 PM
#2086
Originally Posted by Rubi4MyMrs
Lope, what does the pump end of your old distributor shaft look like? I think I remember seeing it but would take forever to find it.
Here's the comparison pic from the other thread I had. The one on the left is the old distributor. The shaft from the '05 unit has a more steeper wear pattern, wearing almost right on the edges, indicating to me that it must not be as snug a fit in the oil pump slot. By contrast, the old distributor shaft end's wear is very shallow, almost 1/3 across.
09-12-2011, 10:29 PM
#2087
Watching Big Brother?
Attachment 278268
Is the tab thicker? Is the thinner tab is changing the contact angle driving centripetally on the shaft's center and warping the shaft? It's not that simple, is it?!
I just looked at both my original with 60K and the second with 2K; the heavy wear on the upper bushing is approximately 180 degrees from the most heavily worn tab. Can anyone look at theirs or measure an '04?
(Edit: Are the shafts from the different versions the same OD?)
Gear-Calculator Stu Can Help You Part Names and Numbers Dealer Supplied Parts and ask for "Jeep Club" Prices
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
09-12-2011, 11:07 PM
#2088
Originally Posted by flying_bosun
Ia the tab thicker?. Is the thinner tab is changing the contact angle driving centripetally on the shaft's center and warping the shaft? It's not that simple, is it?!
Anything is possible.
I've wondered how straight the late model cam bore and distributor bores are in the casting/machining of the block.
2013 JKU Rubicon
09-13-2011, 11:54 AM
#2089
Thanks all for the help. Pulled the old OPDA and it looks completely worn. Jeep has 155000 km on it. No problems pitting the new one in, I will start it later on today. Don't anticipate any problems. Engine and OPDA are both TDC. I will try to post pics later as well.
Ps. The cam shaft gear looks pretty bad. Looks like I will need a rebuild soon.
09-13-2011, 02:11 PM
#2090
Dead end, I'm afraid. Just got the '04 distributor tab measurement from another member and it's narrower by .001".  Why the difference in the contact patch between the two versions?! They use the same oil pump according to what I've found.
― Ron Paul
09-13-2011, 02:39 PM
#2091
undercoverfab
Could be a difference in the hardness of the shaft...
09-13-2011, 05:16 PM
#2092
Tks 4 the upgrade MoodyJP
That is my opinion based only on what is happening to these shafts & also based on the experience I had installing my Crown gear as referenced earlier. I think tkki might have some input on this. I know he had one hardened & it did not show an improvement but I don't know how hard it started out or how hard he got it to.
09-13-2011, 05:56 PM
#2093
The hardening that I did was only a surface kind of thing. The nitriding treatment only penetrated in a thousandth or so.
09-14-2011, 02:49 PM
#2094
A bit off topic but interesting...
2000-2008 Ford Vulcan 3.0 engines have the exact same problem with their OPDA. It dries up, starts to seize and doesn't let the engine rev above 3000. I'll take a closer look next time I replace one, but I'm positive that it had a decal on it from the same parts supplier. I haven't taken one apart, but I wouldn't be surprised if it had the same crappy design. At least Chrysler only used it for 2 years, ford kept using it for 8 years.
09-14-2011, 07:46 PM
#2095
do we have a head count from this thread on how many here have experienced this problem? this thread is quite long, but i'm not sure how many individuals have had an actual problem.
09-14-2011, 08:03 PM
#2096
October 2012 TJOTM
Let's find out.... http://www.jeepforum.com/forum/f9/po...es-no-1265072/
09-16-2011, 05:43 PM
#2097
Finally pulled and swapped my OPDA. 62K. Symptoms: rough idle, "chirping" from OPDA, valve tick.
Did the upper bushing throw???
I will be taking the POS apart ASAP, I'll post pics of the target wheel, ect.
I'll fix it after the lift and tires. Really.
2005 White LJ= Daily Driver
1987 Black XJ= In Jeep Heaven
09-16-2011, 06:10 PM
#2098
Did the rough idle, chirping and valve tick go away?
09-16-2011, 08:58 PM
#2099
Well it looks like the upper seal killed itself. Maybe made it last longer??
burnt upper seal up on the shaft:
Willydigger- next time your in Idaho, the beers are on me
09-16-2011, 09:00 PM
#2100
Well it still idles rough, I'm thinking IAC. But yes, the chirping was from the fried opda for sure, and the valve tick went away as well.
