2005-06 Jeep OPDA_CPS_Distributor Failure - Page 122 - JeepForum.com
 10Likes
post #1816 of 5527 Old 08-11-2011, 07:24 PM Thread Starter
willydigger
Originally Posted by Night Wolf View Post
I used "Green Grease". Seemed to be the best at Advance Auto. After researching it a bit, I think I'll just use it for all the grease fittings on the chassis.
http://www.greengrease.net/
No way would I use Green Grease in my OPDA. It is a perfect grease for ujoints and everything else underneath, but it is way to stiff and tacky for the OPDA.
The opposite is true for Aeroshell. It is very fluid to the point were I would highly recommend wrapping the grease gun in a big ziploc because it will separate and sweat lubricant. I don't think it would be a good idea to use underneath. Green Grease is perfect for that task. I use it myself, but I will never touch my OPDA.
I've done Mobilith 220 which I would consider a common mid-grade grease for most applications. I don't think it did well in the OPDA so I would default to tkki's Aeroshell results and FOG's initial recommendations.
willydigger is offline
post #1817 of 5527 Old 08-11-2011, 07:44 PM
Night Wolf
Interesting.... I guess that means I get to pull the OPDA again, oh joy.
At my prior job with the airlines, we used Aeroshell 33MS and yes, it seperates. Not used on the planes I currently work on.
I suppose I'll keep the green grease for "everything else" and order 33MS for the OPDA. Or I could pull the ignorance card - "but I haven't had any problems yet!11!!1!", lol.
-Rick
-1987 BMW 528e 5spd e28 - personal Panzer for the daily driven battlefield, just broken in at 300k
-1990 BMW 325i Convertible 5spd e30 - extensive overhaul in progress
-2005 TJ Sport - stuff
Night Wolf is offline
post #1818 of 5527 Old 08-11-2011, 09:13 PM
magnum629
Guys can u help me with a few things ? I tryed to read as much as I can but theres a few things I dont get....
1. I see guys saying they went with new lifters ,why did the lifters go bad ???
2. The shaft runs dry thats why the fogmod helps But why is the gear wearing? Im guess the added stress from the shafts lack of oil ??
Thanks all
khaki 2005 TJ 6 speed dana 30/35 4.10 gears 2 inch skyjacker BB lift 1 inch body lift 33 inch kumho mud TAs 15x8 mickey thom classic 2s wheels flowmaster 40 rear tube bumper
magnum629 is offline
post #1819 of 5527 Old 08-12-2011, 09:51 AM Thread Starter
willydigger
Thanks all
There is an oil/break-in/additive issue that has caused some lifter damage. While potentially related to the OPDA wear they aren't something we are focused on. There will be engine component wear but the problem is the OPDA failure rate.
I can't say for a certainty that the FogMod will fix the gear wear. We don't know the cause and apparently neither does Skinny Pedal, Chrysler, or Crown. We are all guessing. The FogMod will help with the upper bushing binding that can contribute to gear wear and premature/catastrophic failures. Wear could be a result of alignment, break-in, OPDA design, we don't know.
The FodMod is a relatively simple, cheap, do something fix. It will do no harm and should help the upper bushing tremendously.
post #1820 of 5527 Old 08-12-2011, 01:30 PM
magnum629
I can't say for a certainty that the FogMod will fix the gear wear. We don't know the cause and apparently neither does Skinny Pedal, Chrysler, or Crown. We are all guessing. The FogMod will help with the upper bushing binding that can contribute to gear wear and premature/catastrophic failures. Wear could be a result of , break-in, OPDA design, we don't know.
Thanks for getting back to me. The fogmod does seem like a good idea and Ill give it a try. The way the gears are wearing it looks like a axel thats set up to tight I often think about the alignment..
post #1821 of 5527 Old 08-12-2011, 01:32 PM
magnum629
my gear is starting to wear .....I called dealer they dont want to help me. I told them the truth the gears wearing and its still covered for 9 more mons...But they dont want to help since the jeeps running fine at this time...any tips what I can do to get the dealer to put a new opda in??
post #1822 of 5527 Old 08-12-2011, 01:36 PM
Heath
2014 JK Wrangler
Twist it in the block enough to set a code so they have something to go off of.
I'm not usually for "getting" the company's on warranty stuff, (technically your not anyway) but they are playing dirty with something they are well aware is a major problem.
2013 JKU Rubicon
Heath is offline
post #1823 of 5527 Old 08-12-2011, 02:38 PM
Boundless
I have been putting off reading this thread until now, thinking my Jeep was immune (Rev-e). I now know what I have to do next.
Thanks to all the guys that have contributed all the tech.
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #1824 of 5527 Old 08-12-2011, 04:53 PM
magnum629
I did the same....butt then i pulled mine and found its going bad..
post #1825 of 5527 Old 08-12-2011, 06:23 PM
cologc46
cologc46's Avatar
I didn't put off reading the OPDA thread, and so I did pull mine. It too was going bad, and my jeep only has 11K miles. The first owner only put 7700 miles on it in 5 years, but I suspect a lot of trail miles and he might have been trailering it??? He lived in Aspen (tough life ) and there are a lot of trail options right out the back door there, so who knows. All I know is that the mileage was low, the frame and body are perfect, the suspension shows some wear and tear, and the OPDA gear was definitely on the road to failure. I pulled it at 10K miles. I replaced my OEM OPDA with a fogmodded OPDA and will hope someone engineers a fix for this soon.
cologc46 is offline
post #1826 of 5527 Old 08-12-2011, 06:39 PM
rwh63
can someone in the know help me identify whether i'm in the good or bad opda group?
my build # is:9 064 5210
my sequence # is: 111441
it's a 2006 LJ with 73k miles.
rwh63 is offline
post #1827 of 5527 Old 08-12-2011, 06:44 PM
JeepScrap
Hehe you said "butt".
Sorry for this useless post...couldn't resist.
Now will someone really smart come up with a great design and solve all our opda problems already!
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline
post #1828 of 5527 Old 08-12-2011, 06:46 PM
JeepScrap
There is no good or bad group dude. They are all bad. Come to terms with it.
post #1829 of 5527 Old 08-12-2011, 08:39 PM Thread Starter
willydigger
Yup. You have a 2006. If you have a 2005 or 2006 you have an OPDA that has the potential for premature wear and catastrophic failure. Not all do, but don't be the guy with their head in the sand. Pull it (video on page 1) and check it. If it's fine (some are), you have a special one. If it's bad, replace it with new. FogMod the new one to remove any issue with the upper bushing. All the pics for the FogMod are on page 1. If you are uncomfortable doing it, send me a PM.
post #1830 of 5527 Old 08-13-2011, 06:31 AM
rwh63
willy(and others), thanks for all the hard work on this problem.
any updates on a corrected replacement, and is the current Jeep replacement still around $100. there is a lot of info here, but i take it that replacing one unit for another is straightforward?
rwh63 is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
