2005-06 Jeep OPDA_CPS_Distributor Failure - Page 119 - JeepForum.com
 7Likes
post #1771 of 5510 Old 07-31-2011, 08:35 PM
biffgnar
biffgnar's Avatar
Originally Posted by snobank View Post
Will this happen to ll 06 tjs
There are plenty that it hasn't happened to yet. Doesn't mean it isn't going to happen though. All we really know is that it happens to some a lot faster than others. 99K and counting here on a 06. If a proper solution ever comes along though I'll be in line with everybody else for it.
Romney in 2020!
biffgnar is offline
post #1772 of 5510 Old 07-31-2011, 11:32 PM
bonza
it's inevitable.
grease that was initially on the top bearing eventually dries up leaving a carbon remnant causing it to squeal then seize. it's impossible for the grease thats in the reservoir to get to the spindle as the fool who designed the opda forgot to include an interconnecting gallery
do yourself a favour. fogmod it
"I like a man who grins when he fights"
ó Winston Churchill..
bonza is offline
post #1773 of 5510 Old 08-01-2011, 11:14 AM
njseifrick
I would wait until warranty expires. If you mod it before and it goes bad chances are that you will void the warranty.
njseifrick is offline
post #1774 of 5510 Old 08-01-2011, 11:47 AM
biffgnar
biffgnar's Avatar
Well, on our 06s we got a 3/36 so wouldn't worry about that anymore. 05s did a bit better but I believe even they are beyond warranty now also.
Romney in 2020!
biffgnar is offline
post #1775 of 5510 Old 08-01-2011, 12:41 PM
keithert
keithert's Avatar
Mine is still under 7/70 for at least another year. I have a Chrysler warranty on top of that. That is why I'm leery of doing the FodMod.
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #1776 of 5510 Old 08-01-2011, 03:27 PM
Brainwashed2566
Maybe you could keep a new one handy for a spare until the warranty is out.
2005 White LJ Mild Build = Fun Rig
2003 Ram 1500 5.9 Mag = DD
1997 Green XJ Bone Stock = SOLD
Brainwashed2566 is offline
post #1777 of 5510 Old 08-01-2011, 03:34 PM
keithert
keithert's Avatar
I currently am running my original. I'll check it again for wear this week. I have a new unmodified one in case I need it.
keithert is offline
post #1778 of 5510 Old 08-01-2011, 04:42 PM
bonza
if you do nothing, one morning when you start up it will squeal without warning and maybe bind up even if you regularly check it for wear. ask me how I know. lucky for me as soon as I heard mine squealing I shut it down and didnt restart until I fogmodded it and no damage to the gear was done
if you are going to pull it out to check for wear, at least dismantle it and polish off the built up crap on the spindle and oil it up. that should buy some time until you fogmod it
bonza is offline
post #1779 of 5510 Old 08-01-2011, 05:04 PM
Fusco
2016 JK Wrangler
so the upper area of the OPDA, when it comes from the manufacturer, does it have any lubrication at all?
the hole where the FogMod is placed, that is a manufacturer lub point...
any idea? maybe someone with a new unit can answer?
2016 Jeep JK 2D Sport S
2006 Jeep TJ Rubicon Impact Orange - SOLD :-)
Fusco is offline
post #1780 of 5510 Old 08-01-2011, 05:12 PM
ChicagoRod
Well, I just ordered a new OPDA from Mopar Parts Online so that means that there should be a new version released by DC any day now for half the price.
With the 1700 mile vacation coming up the end of this month I can't chance being stranded in the middle of nowhere because of a $140 (with shipping) part. My current OPDA has only squealed twice on really cold mornings but my gear is worn. I'm not sure how the new gear will take to the cam but it will be a better set up than what I have. I'm not sure if I will FogMod it or not. I need to look at the directions and see how complicated it actually is.
Rod
05' LJ
ChicagoRod is offline
post #1781 of 5510 Old 08-01-2011, 05:17 PM
Benderff
Benderff's Avatar
Dude! Go to the first page and read.
Benderff is offline
post #1782 of 5510 Old 08-01-2011, 05:28 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Some have reported having some lube while others have found theirs dry. You need to check all new ones. There is never a better time than when it is already out. Be sure to mark the gear & put it back on the same way. It isnít reversible.
The FOGMod is explained on page 1. The supply hole through the bushing is from the factory opening. The zerk hole is tapped where it will be accessible for greasing when installed. Be sure to grease it when warm & the engine is running to maximize grease distribution.
Rubi4MyMrs is offline
post #1783 of 5510 Old 08-01-2011, 05:30 PM
Fusco
2016 JK Wrangler
Yes I'm aware of that Sir. I was referring to the OPDAs that were recently shipped in the last few months.
I apologize and moving forward will clarify my questions in detail...
Fusco is offline
post #1784 of 5510 Old 08-01-2011, 05:48 PM
Brainwashed2566
I wouldn't count on it.
post #1785 of 5510 Old 08-01-2011, 06:09 PM
Benderff
Benderff's Avatar
They are exactly the same as the old ones, and are made by the same company.
Benderff is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
