2005-06 Jeep OPDA_CPS_Distributor Failure - Page 118 - JeepForum.com
 10Likes
post #1756 of 5534 Old 07-29-2011, 12:50 PM
lope
lope's Avatar
Originally Posted by Fusco View Post
So with this info.....do I still FogMod?
I would. The gear looks pretty good but at some point the upper bushing will run out of lube. FogMod will insure against that and may last you the life of the jeep.
lope is offline
post #1757 of 5534 Old 07-29-2011, 12:51 PM
Brainwashed2566
The tech that did the inspection is a Jeep gear head and did explain there was a recall of 16k Jeeps with a certain VIN (not mine) that were effected with poor design OPDAs in mid 2005. Now he said there was an OPDA for '05 Wranglers prior to the REV-B and REV-E. Those are the OPDA's that were part of the 16k recall back in early 2005. He states the original OPDA were NOT made by LDI, another company, but does not recall the name......
That would be interesting if it were true. If there was another manufacturer of OPDA in early 2005, I would ask someone post a pic of it. Having said that, I think that the general consensus is that all 2005-2006 models are affected with this problem regardless of companies/ brands/ models. The OPDA is just crap, no matter what lol.
Your gear looks good though. It is up to you what you want to do, but most people will recommend the FOGMOD I would think. Good luck!
2005 White LJ Mild Build = Fun Rig
2003 Ram 1500 5.9 Mag = DD
1997 Green XJ Bone Stock = SOLD
Brainwashed2566 is offline
post #1758 of 5534 Old 07-29-2011, 02:03 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
You are correct, that tech was completely mistaken. I have an early '05 that was part of the infamous E05 TSB. It is an LDI rev B. I don't want to further the creditability that the E05 somehow fixed the problem or that those were the only bad units but somewhere I have the # range of the E05s. That is the 4 digit # preceding the "Rev B".
I'm not agreeing that the gear looks that good. I would like to see the other half. From that one view it looks like the pattern is getting longer on the lower teeth. If the pattern is uneven as mine is, I don't think it is good.
Here is my OPDA
Rubi4MyMrs is offline
post #1759 of 5534 Old 07-29-2011, 05:04 PM
Heath
2014 JK Wrangler
My s/n on my 05 TJ was in the recall range, and it was a rev B.
2013 JKU Rubicon
Heath is offline
post #1760 of 5534 Old 07-29-2011, 06:20 PM
90FORDF150
I was about to buy a used 2006 LJ with 62k miles on it. Should I pass and get a JK instead?
90FORDF150 is offline
post #1761 of 5534 Old 07-29-2011, 06:31 PM
badtux
Depends on your goals. You can build a LJ into an awesome offroad vehicle especially for climbing where the longer wheelbase keeps your front wheels on the ground much better than the short-wheelbase Jeeps yet it's not so long that it's cumbersome like the new 4-door JK's, but the new 2012 JK's are better daily drivers due to the better mpg and 100 more horsepower. I do know I'm not selling my LJ. Even if I end up having to rebuild my LJ's engine early because of this problem (unlikely, but it could happen), it's still cheaper to do an engine rebuild than to take the $15K hit to buy a new JK, and there just isn't a JK with the right wheelbase for what a LJ is good for (the 4 door JK is too long, the 2 door JK is too short).
badtux is offline
post #1762 of 5534 Old 07-29-2011, 07:34 PM
keithert
keithert's Avatar
Yes. Or get an 04.
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #1763 of 5534 Old 07-29-2011, 08:35 PM
lope
lope's Avatar
Same here.
lope is offline
post #1764 of 5534 Old 07-30-2011, 05:23 AM
Rubi4Us
Originally Posted by keithert View Post
Yes. Or get an 04.
I don't agree that you should pass on the 05 or 06. The LJ offers the perfect wheelbase in my opinion. If you have any mechanical abilities, keeping an eye on your OPDA after the fogmod at each oil change interval is not a big deal. I'll never sell my 05 LJ.
LJ 2005 Rubicon Unlimited "Sahara" Limited Edition #0146 of 1000
35 inch KM2's with 5.5 inch Rock Krawler Long Arm
Rubi4Us is offline
post #1765 of 5534 Old 07-30-2011, 06:31 AM
element981
Yes. Or get an 04.
I disagree as well. I previously had an 07 JK Unlimited. It did just fine off road (3" lift on 34s); however, I prefer my LJ in every way except one- it is not modded yet.
Chris
2005 LJ Rubicon w/Savvy Under Armor
Jarhead Jeep Club member #17
Colorado Jeep Club member #119
July 14, 2008
RIP Danny Dupre SSgt/USMC
element981 is offline
post #1766 of 5534 Old 07-30-2011, 10:37 AM
Heath
2014 JK Wrangler
Same here. I had two JKUs, one on 35s one on 33s, both with nice lifts, a Sahara, and a Rubicon. I prefer my LJ.
2013 JKU Rubicon
Heath is offline
post #1767 of 5534 Old 07-30-2011, 11:55 AM
90FORDF150
Thanks everyone. I spoke to a mechanic friend who told me that this issue isn't a reason not to get the vehicle. Just have to keep an eye on it. Seems to be the consensus so far. Of course, I respect keithert's opinion too. I think I'm going to go for the LJ. Thanks again.
post #1768 of 5534 Old 07-31-2011, 09:07 AM
Peterpsc
You won't regret the decision. Of course fogmod.
Peterpsc is offline
post #1769 of 5534 Old 07-31-2011, 04:43 PM
Baseplate
I wrote to Chrysler Australia about my 2006 TJ with OPDA and Cam wear (30,000 miles), I sent them pictures and explained that they charge around $600 USD for the same OPDA I can source from Mopar Wholesale for half that and that the part Australian's are supplied does not even include the CPS.
This is there response - in a nutshell - we dont give a rats
Good Morning Mr XXXX
I have been advised after talking to our District Field Manager for QLD and our technical manager that your vehicle is not affected by the bulletin that was released.
The failure to your vehicle is unfortunate however the bulletin was purely a proactive measure whilst the vehicle was still in warranty for our Chrysler dealerships to follow the steps on any affected vehicles.
As the vehicle is outside of the Manufacturer warranty Chrysler is unable to assist in any compensation or reimbursement for the repairs.
If at the time of failure your local Chrysler dealership was approached to discuss goodwill we may have assisted with special pricing on the part. If any failure occurs in future I can only suggest prior to the repair being done you can either contact the Chrysler dealership or Chrysler Australia to discuss if there is anything we are able to assist with.
Thank you for bringing this matter to our attention.
Kind Regards
XXXXXX
Customer Relations Executive
Chrysler Australia Pty Ltd
Baseplate is offline
post #1770 of 5534 Old 07-31-2011, 07:29 PM
snobank
Will this happen to ll 06 tjs
snobank is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
