2005-06 Jeep OPDA_CPS_Distributor Failure - Page 106 - JeepForum.com
 10Likes
post #1576 of 5527 Old 07-11-2011, 01:20 PM
element981
Originally Posted by willydigger
Anyway long story short, I have the start-up tick that others were describing. I'll be going back to 5w40 for the next change. The synthetic VR1 was 10w30.
So you will no longer be using the VR1?
Chris
2005 LJ Rubicon w/Savvy Under Armor
Jarhead Jeep Club member #17
Colorado Jeep Club member #119
July 14, 2008
RIP Danny Dupre SSgt/USMC
element981 is offline
post #1577 of 5527 Old 07-11-2011, 01:46 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Originally Posted by willydigger View Post
The hole for the crown gear is at a different height than the gear from the OPDA. So if you install it using the OPDA shaft hole the gear will not be in the same location. I haven't seen this as a fact, but it's been reported in the original cam thread.
The hole in the 04 CPS uses a smaller roll pin on some models. Tkki reports his 04 gear being a direct swap. The 04 CPS I purchased used a smaller roll pin. You can open those holes and used the existing shaft hole in the 05 OPDA.
With regards to the gear size, the OPDA gear looks smaller from the image. You are right about the speed though so they should share the same revolutions. I'll edit my posts so others don't get the wrong idea. Thanks for the clarity.
I don't doubt clearance issue as a factor either. I wouldn't say it is the definitive factory though. I'll mic the bushings I have from the 04 and 05 and see if there is a difference. Something makes me think tkki would have mentioned if there were. I don't recall. I can mic shafts too. I think I have a few spares lying around.
Willy,
You know you are information central & I appreciate that you take all of our input in the spirit it is intended. The reason I questioned the Crown gear info is because I havenít installed it & any new info will be considered. My plan is to drill the gear if the height is not correct for the pre-drilled hole. I do have a drill press so that will be the way I will do it. As for the gear sizes, the cam gear does have a larger diameter. But they both have 13 teeth. The dizzy arrangement is deceptive. You are still correct about the sacrificial aspect of the driven gear (OPDA). Of course that depends on the quality control of the 2 surfaces. Iím not sure where we stand on that given the excessive wear many of us have experienced. Another aspect is by having a larger dia. the teeth on the cam gear are longer than the OPDA gear. That makes for more surface contact area which distributes the wear better than the OPDA gear.
As for the clearance issue, I agree that nothing is definitive yet. No doubt though that lubrication is lacking.
Keep up the excellent work!
Rubi4MyMrs is offline
post #1578 of 5527 Old 07-11-2011, 01:46 PM Thread Starter
willydigger
Doubt it. The 5w40 is quieter. I can still get it reliably at Walmart for $25 a gallon. I'll hunt for sales as required. Your results may very of course. Not everyone has a start up tick with VR1. It's the same Mopar filter I've always used. I suppose I could have a got a lemon.
willydigger is offline
post #1579 of 5527 Old 07-11-2011, 01:47 PM
unlimitedlj
I would use the conventional VR1 it is 1300 PPM of Phos and 1400 PPM of Zinc its only 4.75 at Napa. Mine purrs with it.
unlimitedlj is offline
post #1580 of 5527 Old 07-11-2011, 01:50 PM Thread Starter
willydigger
Originally Posted by Rubi4MyMrs View Post
...The reason I questioned the Crown gear info is because I havenít installed it & any new info will be considered. My plan is to drill the gear if the height is not correct for the pre-drilled hole. I do have a drill press so that will be the way I will do it. As for the gear sizes, the cam gear does have a larger diameter. But they both have 13 teeth. The dizzy arrangement is deceptive.
...Another aspect is by having a larger dia. the teeth on the cam gear are longer than the OPDA gear. That makes for more surface contact area which distributes the wear better than the OPDA gear.
As for the clearance issue, I agree that nothing is definitive yet. No doubt though that lubrication is lacking...
I can't comment for certain on the crown gear since I haven't messed with it personally. I'll try to dig up some old comparison shots showing the hole in the gear being different than the gear for the 05 OPDA.
Excellent point on the cam gear teeth surface.
post #1581 of 5527 Old 07-11-2011, 01:51 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Originally Posted by GMBNT42 View Post
Yeah the tooth center on the camshaft side looks pretty thick still, a bit of wear, but not much really......I ordered up the OPDA assembly anyway while its a reasonable price($120)and in stock. These things were in the 3-400 range just a few weeks/months back? Holy cr@p I would have had a heart attack at that price
Understand that the new OPDA will have completely dry bushings. They should be lubed or better yet FOGMod it.
post #1582 of 5527 Old 07-11-2011, 02:03 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
OK but don't go to any trouble. There seems to be no consistency in these things. When the time comes I'm going to pull the OPDA & give the Crown gear a try. If it requires drilling I will. I know the hole size is the same & Tkki has found the '04 gear to work while some earlier ones have a smaller one so who knows. I'm still monitoring my oil consumption so I'm not sure when I will be pulling it. I will of course report my findings.
post #1583 of 5527 Old 07-11-2011, 02:05 PM Thread Starter
willydigger
Found it. In this thread wouldn't you know. I'll have to update the Q&A later.
Originally Posted by liljpy View Post
Below is a side by side comparison. Note first that the pin holes are off. The difference in pin location is way more than the amount of play between the old gear and the thrust washer. Put another way, there's no way that new gear will fit without modification.
Here's another pic, notice the new gear doesn't have a second hole for the pin to go through...
Below is a pic with the gear pushed up as far as possible to show how little play there is. There's no way the new gear will go far enough up to allow the pin to go in.
Below is a bottom comparison. The picture isn't that great, but you can get a good look at the tooth profile. Note two things here. First, the tips of the teeth on the new gear are thicker than the tips on the old gear. At first I thought maybe the old gear was a bit worn, but it doesn't appear so. I came to that conclusion because the backside of the teeth on the old gear don't make contact with the cam gear and thus, shouldn't be worn. The second thing to note here is that the lip is more rounded over on the inside edge. That's probably not a big deal, but still worth pointing out.
Below is a top comparison. Again, the flash washes things out a bit, but provides us with a good look at the profile.
I also noticed that the new gear fits much, much tighter on the shaft. I got it on about 1/4 of the way and knew if I went further I wouldn't be able to easily pull it off. In fact, I had to heat it with a blow torch to take it off when it was just 1/4 of the way on. This is troubling to say the least!
post #1584 of 5527 Old 07-11-2011, 02:07 PM Thread Starter
willydigger
Tkki's gear from the 04 was factory. The unit I got was a Dorman unit that runs $45 from Rock Auto. Tkki's fit perfectly with no modification, the Dorman required drilling to open the holes, but the height was correct.
The Crown gear hole as pictured about is not useable and a new hole in the gear or shaft has to be drilled.
post #1585 of 5527 Old 07-11-2011, 02:27 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Thanks Willy. I went back to that post & the next couple. It seems that the hole is about 0.010" off. Ironically that is about the same difference I found on my "E05" replacement gear between the 2 sets of holes. Not sure what that means unless the replacement gears were left over '04 gears. Anyway, thanks again.
Yes, I was thinking the smaller hole might have been from the Dorman gear but was not sure.
post #1586 of 5527 Old 07-11-2011, 04:03 PM
mpotoczny
OK, our collective voices have been heard! I'm not saying that this will cause any action, but 'they' know. We came face to face with about a dozen Chrysler Jeep engineers testing the new v6 in JKs on the Rubicon Trail this past weekend. I could not help but throw out a barb about my 05 opda, and 'when are we going to get a fix?' I got 'sorry' and an offer for me to buy a new jeep... I disrespectively declined - something about "its not that there is a problem/design flaw, but rather how it's handled, Jack the price on the unfindable part and still no proper replacement available...' The look on their faces told me they know, and are ashamed.
Does this help/change anything? No. But I thought I would share this for all of you out there who did not have the same opportunity I did to say something directly to the people involved.
mpotoczny is offline
post #1587 of 5527 Old 07-11-2011, 04:21 PM Thread Starter
willydigger
I had an opportunity to get some measurements today. I was working on a FogMod and grabbed some measurements. I also bought a Dorman CPS for an 04 and took some measurements. I couldn't get anything consistent but I took several measurement and would tend to think the median is the closest to accurate.
2005-06 OPDA Measurements:
Shaft 0.531
Bushing 0.533
Gear 0.533
Dorman Aftermarket 2004 CPS Measurements:
Shaft 0.5305
Bushing 0.532 - 0.5315
Gear 0.533
Shaft
Bushing (I could only get the lower, I assume upper is the same?)
Gear
Dorman Shaft
Upper Bushing
Lower Bushing
Gear
post #1588 of 5527 Old 07-12-2011, 03:36 PM
flying_bosun
Originally Posted by 06RubiconBlue View Post
Im sure they wont go as far as replacing a cam and lifters but i may get a free OPDA?
Does that mean im stuck flipping the bill?
Also, the camshaft gear itself looks OK(or at least it doesnt seem to have as much wear on its gear as the gear on the OPDA assembly), but while the engine is apart, how much is a camshaft itself? CHeapest place to get a stock replacement just in case?
........also do you think I should be replacing the camshaft as well? $180 for an OEM one.
Do you think the camshaft itself is OK?
I hope this post addresses the quotes above and, in turn, can help me decide how to close this story of woe. Forgive the length, please. . .
As with many (but certainly not ALL) of us, my saga began with the dreaded Laughing Monkey. It was there on each cold start up, then went away with a quick rev of the engine. This was Monday, May 9th. I'll spare you the details other than to say that I initially thought it was a bad alternator bearing, tension pulley or idler wheel. When all three had been excluded thru inspection of the former and replacement of the two latter, I had resolved to drive it no more until I could properly diagnose the source. . . after one quick trip to the bank. Then it happened; complete shut down at 65 mph.
For the first time my Rubi was at the wrong end of a winch going onto a trailer to get home. After much hair-pulling, gnashing of teeth, and searching on JF, I recalled a thread I'd briefly read last year about the OPDA. (At the time, I'd said "glad I don't have that problem" and burried my head in the sand.) So I found the thread, pulled the OPDA, and obviously, I found my culprit. Taking advice I'd read in this or another OPDA thread, I spoke to the service writer at the nearest dealer and explained the situation. He hadn't (nor had any of his techs) heard of the problem, but he vowed to push Chrysler on my behalf. So, I brought it to them to replace the OPDA, inspect the cam, and make a formal recommendation. Result: bad OPDA and observed premature cam wear, replaced OPDA, and recommended cam replacement due to probable eminent failure.
I've opened a case with Chrysler, and based on the service writer's insistence, they've agreed to cover a certain percentage of the repairs. I've got two estimates from the service writer for the repair/replacement; one for OEM, and the second for aftermarket. The tech recommends a 505Performace cam. I've talked with Zach at 505 and determined that the Stage 1 Cam kit, which will actually be about 30% less expensive, is what he recommends. Other searching has turned up Hesco as an alternative. Based on what I've learned thus far, I'm inclined to add a few horses with the aftermarket option. [Edit: based on what I've now learned, I will be replacing with OEM]
505's Stage 1 Kit including gasket set is about $413, Hesco's would be about $600, but will require additional machine work (extra labor $) on the head.
Thanks to all, especially Willydigger
Originally Posted by Ron Paul
ďLiberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.Ē
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #1589 of 5527 Old 07-12-2011, 06:46 PM Thread Starter
willydigger
Updated/cleaned up the Q&A section. It was a little weird. I tried to separate things into main topics and I added links for some answers. Turns out the gear question was already referenced in the Q&A. I included links to several images of the crown gear and the 2004 aftermarket CPS.
Please do me a favor and offer up any other questions that aren't covered or maybe should be clarified.
post #1590 of 5527 Old 07-12-2011, 07:11 PM Thread Starter
willydigger
Also I need some results! The last update was back in April. Anyone have any pics to offer? FogMod, alternate Mod? I'm really curious about Rubi4MyMrs and the oil lube.
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
