2005-06 Jeep OPDA_CPS_Distributor Failure - Page 102 - JeepForum.com
 10Likes
post #1516 of 5534 Old 06-28-2011, 06:21 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
For those of you using M1 TDT, I just got my O'Reilly's ad - $19.99 a gal. Good price??
Rubi4MyMrs is offline
post #1517 of 5534 Old 06-28-2011, 07:59 PM
-JD-
Originally Posted by -JD- View Post
FWIW, my local NAPA is running a $4.99/qt sale on Mobil 1 Oils (I think through June). That included the TDT last time I bought.
IIRC, last time I saw it at Walmart it was closer to $25/gal.
Bought 3, 6qt cases at NAPA @ $4.99/qt - $19.96/gal a little over a week ago.
$19.99/gal seems on the money.
2006 Rubicon Unlimited 6-Sp Manual - 285/75/16 Cooper ST MAXX/stock Moab wheels, Savvy Under Armor BL/MML, Savvy Step-Rocker/Sliders, Savvy/Currie Ultimate Steering, Savvy UCAs, Currie LCAs, TBs and BSs, Nth/AEV 3" Springs, Rancho 9000XLs (255s/256s), ARB D44 Diff covers, Savvy/Tom Woods HD Rubicon Rear drive shaft, Genright Safari 31gal Tank Soon: Savvy LED Lights, new engine :-(
-JD- is offline
post #1518 of 5534 Old 06-30-2011, 04:28 PM
Night Wolf
The new OPDA arrived. Same POS as before, REV-E. But, it's new.
This is the same price I paid for one the first time before it became big news. Then it went up to nearly $400 now back to $135 shipped? I wonder if they are trying to get rid of the remaining stock for the supposed July update about this problem? Either way, much more peace of mind having another new new. It'll sit around until needed.
-Rick
-1987 BMW 528e 5spd e28 - personal Panzer for the daily driven battlefield, just broken in at 300k
-1990 BMW 325i Convertible 5spd e30 - extensive overhaul in progress
-2005 TJ Sport - stuff
Night Wolf is offline
post #1519 of 5534 Old 07-02-2011, 07:05 PM
Onetype
My brother bought an 05 LJ yesterday and drove it from IN back to wheres hes stationed in KS. About 150 miles in his check engine light came on with a p0344 code. I found this thread and told him about it. This is what his OPDA gear looked like when I told him to check it. This is what he sent me.
Onetype is offline
post #1520 of 5534 Old 07-02-2011, 11:59 PM
cologc46
cologc46's Avatar
I am glad I found this thread. I just changed my oil, and did not get the right stuff. Oh well, my TJ is very low mileage, so I will run out this oil and put in the VR1.
This thread documents some excellent hard work, thanks to all who have contributed.
cologc46 is offline
post #1521 of 5534 Old 07-03-2011, 12:12 PM
Onetype
Onetype is offline
post #1522 of 5534 Old 07-04-2011, 02:56 PM
unlimitedlj
Opda
I have a 2005 Unlimited with a build date of October 2004. I have read on here and other places that 05/06 models have premature oil pump failure as well as camshaft problems and I know the earlier models with the distributorless ignition systems had a slightly different set up but, mine is set up just like what I see here. I have 85k on mine and haven't had any problems and show no TSB or recalls I was just wondering if I should be worried or not? I have been using the Valvoline VR1 10w-30 with the ZDDP levels the flat tappets need thinking that it will be my safest bet but, I just wanted to know everyones thoughts on all this?
Thanks,
Ej
unlimitedlj is offline
post #1523 of 5534 Old 07-04-2011, 03:36 PM Thread Starter
willydigger
Thanks,
Ej
You will know for sure when you pull it. There is a video on the first page using the sharpie method. In 20 minutes you'll know for sure what shape you're in. In my experience, the norm is premature wear. There are instances of OPDA shaft binding (that the FogMOD eliminates or at least substantially reduces), however the time frame of failure is not consistent. Some times you get a warning squeal, some times you toast an engine. It can happen at 12K, 50K, 100K there is no rhyme or reason for the delay that we have identified here. Maybe oil type, driving habits, break-in, we just don't know.
The concensus here is to complete the FogMOD and change the oil to VR1 or M1TDT. Again everything is outlined on the first page. Doing nothing is not advisable. There are some who have had no problem and some who need a new engine. I would recommend having a preventative outlook.
1. Check it for wear (highly likely at 85K). Free.
2. Replace with a new unit at a minimum. $120ish, link on first page.
3. FogMOD is highly advisable since shaft binding has been seen and can cause catastrophic failure. $40-60 ball park for tools, or having someone do it. If you're not good with machining PM me.
4. Run VR1, M1TDT, or ZDDPlus additive. $40 Oil cost
Whatever you do, don't do nothing.
Good luck.
willydigger is offline
post #1524 of 5534 Old 07-04-2011, 06:29 PM
Brainwashed2566
I heard somewhere Chrysler is going to fix this problem by making a fixed unit available to the public this July? is this true?
Brainwashed2566 is offline
post #1525 of 5534 Old 07-04-2011, 06:43 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Wait, that can't be true. According to a few in this thread, that problem is caused by a lack of ZDDP in the oil so therefore the problem cannot be fixed by anything except by having more ZDDP in the oil.
Jerry Bransford is offline
post #1526 of 5534 Old 07-04-2011, 06:50 PM
JeepScrap
I don't believe anyone in this thread or any opda thread thinks that Jerry. Obviously its a poorly designed unit. And we know you believe zddp is pointless and you know everything about everything.
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline
post #1527 of 5534 Old 07-04-2011, 06:53 PM
biffgnar
biffgnar's Avatar
Originally Posted by willydigger
It can happen at 12K, 50K, 100K there is no rhyme or reason for the delay that we have identified here. Maybe oil type, driving habits, break-in, we just don't .
I check in on this thread from time to time. 06 with 97K+ here and no symptoms so far. Still interested if there is an ultimate resolution here.
biffgnar is offline
post #1528 of 5534 Old 07-05-2011, 08:49 AM Thread Starter
willydigger
This rumor was started in this thread. I'm in the "I'll believe it when I see it." If I were you I'd plan as if it were not true. The risk is too great and the mod is too cheap not to do it.
post #1529 of 5534 Old 07-05-2011, 09:02 AM
Fusco
2016 JK Wrangler
...or wish in one hand and poo in another....see which one fills up first. haha.
ok kinda foul, but u get the idea, d'oooh
2016 Jeep JK 2D Sport S
2006 Jeep TJ Rubicon Impact Orange - SOLD :-)
Fusco is offline
post #1530 of 5534 Old 07-05-2011, 09:27 AM
Xlr8n
1967 JK Wrangler
When a faulty component design puts undue resistance on a moving part and as such puts more pressure on a gearset, the gears will obviously wear much faster than intended.
Using a lubricant with known higher anti-wear properties would likely help to diminish the effect of gear wear until a solution is available that would eliminate the source of resistance.
Not rocket science....
Xlr8n is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
