2005-06 Jeep OPDA_CPS_Distributor Failure - Page 100 - JeepForum.com
 6Likes
post #1486 of 5484 Old 06-20-2011, 08:29 AM Thread Starter
willydigger
Originally Posted by 06RubiconBlue View Post
agreed! I May put 100 miles on it in a month. I hear a TSB will be out in July, should i wait and see what Chrysler is going to do or go ahead and get a new one. Im sure they wont go as far as replacing a cam and lifters but i may get a free OPDA?
I would put no value in that rumor or the Skinny Petal rumor. You'll hate yourself if you blow up your engine hoping for a better fix. That timing will have to work out on it's own. Also with the price fluctuation, buy now while it's relatively low.
Originally Posted by element981 View Post
WIlly, first off thanks for all the help over the last two weeks. Anyways, my shaft is actually tapered. My punch by itself will only go half way through the shaft and that was it. Other than that the gear and the shaft lined up as good as can be.
I can't understand why they would do that. It serves no purpose to taper a roll pin hole.
willydigger is offline
post #1487 of 5484 Old 06-20-2011, 09:05 AM
element981
Originally Posted by Rubi4MyMrs View Post
That IS interesting. Any photos? Shaft, gear, pin? Is it still rev.E?
Yes, my new one is Rev E.
Chris
2005 LJ Rubicon w/Savvy Under Armor
Jarhead Jeep Club member #17
Colorado Jeep Club member #119
July 14, 2008
RIP Danny Dupre SSgt/USMC
element981 is offline
post #1488 of 5484 Old 06-20-2011, 09:25 AM
JeepScrap
Originally Posted by TJJP77
Based on my experience, a new OPDA/OPDA gear will quickly pick up the same wear pattern your existing gear already has. The only real fix is a new cam and OPDA gear. You can buy yourself perhaps a lot of time just switching OPDA gears, but eventually the cam will have enough wear on the gear that it will exceed the window of error that the computer can tolerate even with a new-ish OPDA gear.
How is the new cam holding up TJJP? I would assume that if your opda gear is wearing, so is the new cam. I'm wondering if a new cam is really the ultimate fix or a big waste of time and $$$. Keep us posted.
Sent from my Droid using JeepForum
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline
post #1489 of 5484 Old 06-20-2011, 09:41 AM Thread Starter
willydigger
Do you have any pics of the punch? What did you use to punch the pin out? If it was tapered you wouldn't have been able to punch it out with same punch.
post #1490 of 5484 Old 06-20-2011, 12:35 PM
element981
No I do not. I purchased the punch the day a did the mod. It has a flat tip and it goes throught the old one with no issues. Part of me feels I should mod the old one and put it back in my Jeep because it seem all around the same as the new one, but spins way better.
Chris
July 14, 2008
post #1491 of 5484 Old 06-20-2011, 01:39 PM Thread Starter
willydigger
Some of the new ones are tight. Maybe it's a correction of tolerance issues. Maybe it's just not worn down yet. There is no harm in modding the old one.
post #1492 of 5484 Old 06-20-2011, 05:22 PM
GMBNT42
OK, I got a question. A while back I bent a pushrod(due to frozen valve), I was able to unfreeze the valve and install a new pushrod, so far it seems to be working ok, but now I have an obvious tick in the engine. Could the valve have fozen up because of the oil pump gear going bad?
Im about to take the head out and have a valvejob done to make sure there wasnt any major damage. I havent done a compression check yet, but when I pull the head Im going to replace all the pushrods and lifters. I am also going to put in a new waterpump too while Im at it. I have a 2005 4.0L motor with just under 90k on the odometer. Should I be thinking about replacing the cam as well or the oil pump gear? I have no clue why the first pushrod bent in the first place but Im wondering if the top end got starved for oil. ANy tips or suggestions appreciated.
Also if I do replace the OPDA, should I replace with an 04' model with the "grooves" on the shaft or am I stuck with an 05'-06' model?
GMBNT42 is offline
post #1493 of 5484 Old 06-20-2011, 05:32 PM
jkp
You should check the cam and OPDA gears while you're in there.
Yes, you are stuck with an '05 - '06 OPDA.
If the failure was due to the OPDA you would have lost all oil pressure when the OPDA gear failed. So, I don't think the valve issue is related to the OPDA.
'92 Islander
'06 Rubicon
jkp is offline
post #1494 of 5484 Old 06-20-2011, 06:48 PM
GMBNT42
No the oil pressure guage still reads normal, but I will pull and inspect the cam and OPDA gears and shaft while im there and will replace if showing any significant wear. Thanks!
Also, if the camshaft is showing wear or damage on the lobe, do I need to pull the engine to replace cam? How expensive is the cam itself?
GMBNT42 is offline
post #1495 of 5484 Old 06-20-2011, 07:07 PM
jkp
You don't have to pull the engine to replace the cam, but you will have to remove the radiator, condenser, grill, etc in front of the engine. I believe someone has posted a thread with pics on this. I think they also listed the cost of the cam and lifters, but I don't remember what it ran.
'92 Islander
'06 Rubicon
jkp is offline
post #1496 of 5484 Old 06-20-2011, 07:32 PM
TJJP77
TJJP77's Avatar
So far so good. Last time I had it apart, I had a nice narrow wear pattern on the OPDA gear, which is what you want - the gear on the cam still had not "burnished" in yet and basically looked the same as it did when I took it out of the box it shipped in. Unfortunately, someone hit me on the way home from work a week and a half ago, so now I'm dealing with that. When I get the Jeep fixed, I'll pull the OPDA again and have another look-see.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #1497 of 5484 Old 06-20-2011, 08:32 PM
snobank
Will this happen to all 06_05 jeeps----if soWTF...will an 04 motor bolt right in place
snobank is offline
post #1498 of 5484 Old 06-20-2011, 08:39 PM
JeepScrap
Glad to hear about the cam and sorry to hear about the fender bender. Good luck.
post #1499 of 5484 Old 06-20-2011, 09:38 PM
TJJP77
TJJP77's Avatar
Yeah, I'm still pretty angry about it - my Jeep was about as perfect as a Jeep can be - low mile (12,700 currently) 2006 Rubi LWB, 6-speed and I added a NAV radio, Comp/Temp mirror and sentry key.
Woman was coming to a stop as I was making my left turn on a green arrow and she decided to gun it and go for it. Thank goodness for the two witnesses who were nice enough to stop and support my story to the police.
Fortunately no major dents, but the body guy doesn't think paintless dent repair will work based on where the dents are - he thinks he's going to have to crack into the paint which I was hoping to avoid. I've never had much luck with proper match of the metallic flake size and pattern, but he does show vehicles for GM when they can't handle it in their own facilities or need it on a tight timeline, so his work is pretty good. I guess we'll see. I'm also going to need a driver's side flare and fog lamp and they authorized a new bumper since the powdercoat was scuffed off of mine and I guess it's just cheaper to get a bumper than strip and refinish.
I just want it back the way it was before the accident - back to being as close to perfect as any vehicle I've ever owned.
Chris
'02 Sahara
TJJP77 is offline
post #1500 of 5484 Old 06-20-2011, 09:39 PM
TJJP77
TJJP77's Avatar
Sure it will, but the cam sensor on an '04 won't provide a proper signal to an '05 or '06 computer.
Chris
'02 Sahara
TJJP77 is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
