2004 Wrangler Sport 6cyl P0135 & P0432 error codes - JeepForum.com
post #1 of 4 Old 08-08-2012, 05:30 PM Thread Starter
Vertabreaker
Hey everyone, I've been searching for an answer and I've come across this forum before so I figured it was time to join. Unfortunately these error codes are the reason I was finally forced to join
I have a 2004 Wrangler Sport 6 cyl with 112k+ miles on it and the check engine light came on. I had the codes read and I got
P0135 O2 sensor bank1 sensor1
as well as
P0432
which says The O2 sensors monitor the Cat converter
A buddy of mine mentioned that the cat error was due to a bad O2 sensor. So my question is, is that possible? and if so, will both issues be fixed if I just replace the O2 sensor?
Thanks in advance.
Nick
Vertabreaker is offline
post #2 of 4 Old 08-08-2012, 06:34 PM
SlackJaw
baby jeep
SlackJaw's Avatar
It is possible that the cat code is due to o2 sensor, but doubtful that just replacing the 1/1 sensor will resolve all your codes.
I would check the flange bolts between yon exhaust manifold and the down pipes first.
If p0135 code is 1/1 sensor, I'm pretty sure p0432 is bank 2 cat. So you likely need to look at the entire system (ie, more than just the 1/1 sensor, likely the 2/2 as well) one way or another, that is if you don't just have loose flanges. Good luck, I have some experience with this on my same year model as you, if you have any questions.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #3 of 4 Old 08-08-2012, 07:10 PM Thread Starter
Vertabreaker
Dude, thank you so much for the advice. I'll have time tomorrow to take a better look at things. I'm not a huge Jeep person until lately so I'm trying to learn and do all this stuff on my own. I will definitely hit you up if I have other questions.
post #4 of 4 Old 08-08-2012, 07:17 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Its all good. You'll have to get under it to check the flange bolts, and a wobbly head socket would be nice for one of them, but certainly not necessary, a regular extension can get you there. I am hopeful and also suspect because of the both bank errors at same time, that its just loose bolts. Best wishes, let us know how you come along.
SlackJaw is offline
error code P0135 jcspencer01 TJ Wrangler Technical Forum 13 05-24-2016 08:42 PM
Coolant System Help. 99 Wrangler Sport 6cyl M600720 TJ Wrangler Technical Forum 33 03-07-2012 09:56 PM
4.10 gears in stock 6cyl 4ltr wrangler sport? claplante1 TJ Wrangler Technical Forum 31 12-04-2011 04:42 PM
05 Sport Error Codes Chris_W_2k5 TJ Wrangler Technical Forum 2 02-25-2009 12:48 PM
reset error codes on 93 wrangler??? REDMANYJ YJ Wrangler Technical Forum 1 04-09-2004 08:06 AM
