2004 Wrangler - Metric & American Mix? - JeepForum.com
post #1 of 7 Old 08-22-2017, 11:26 AM Thread Starter
ENIGMACODE
Hi Gang
Sorry guys I know this question has been asked many times before. It seems the best answer is this one from the forum:
"You'll absolutely need both SAE and metric to work on your TJ"
I have both sets of sockets including Torx - Guess it all depends what you're working on?
Thank You
Mike
ENIGMACODE is offline
post #2 of 7 Old 08-22-2017, 01:03 PM
mukluk
If you're asking whether a TJ has a mix of metric and SAE, the answer is yes. My experience has shown metric tools are needed far more often than SAE though.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #3 of 7 Old 08-22-2017, 01:14 PM
TJnBC
welcome to Jeeps ! they did it just to **** with us and they added Torx for icing on the cake
2006 LJR...the madness begins again
TJnBC is offline
post #4 of 7 Old 08-22-2017, 08:18 PM Thread Starter
ENIGMACODE
Ha Ha - That's fer sure!
I just recently had to drill all the 'Hinge Bolt Torx Heads' out of the tailgate.
Thanx Guys!
post #5 of 7 Old 08-23-2017, 08:10 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Depends on which part you are working on. Most of the fasteners that go into the block are SAE. Most of the fasteners in the 97-02 frame are SAE. Most of the fasteners in the 03-06 frame are Metric. Most of the Suspension fasteners are Metric. The tub is a mix biased more towards Metric. Torx Head can be either Metric or SAE thread.
Accessory drive is mostly Metric.
If you working on the suspension of the later frame, you'll walk away wondering why you own SAE tools.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #6 of 7 Old 08-23-2017, 09:07 AM
JEK3
JEK3's Avatar
...Then you put on a lift, which can shift things back towards SAE.
Could be worse. A friend of mine had an old MG. He also needed a full set of Whitworth wrenches.
JEK3 is offline
post #7 of 7 Old 08-23-2017, 05:53 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Depends on the kit. I've seen a lot of Metric bolts included in kits, I've seen them all converted to SAE.
Given how I've seen folks describe bolts around here, I don't know that calling out a wrench based on shank size is a bad way to go. At least if the Metric folks stuck to it, we wouldn't get so many 12mm bolts with 18 and 19mm heads.
I am Savvy
