2004 Unlimited Pinch Weld Rocker Rust? - JeepForum.com
post #1 of 2 Old 08-28-2013, 04:07 AM Thread Starter
IndridCold89
1991 XJ Cherokee
A year or so ago I noticed I had the tiniest rust spot starting to come through the metal on the lower rocker portion of my passenger side where the pinch weld bumps are. I assumed a chip had got to it and sanded it down and repainted. The rust came back. Did this 2 more times yet the rust kept coming back. To my horror I discovered the rust had started from the other side on the inside of the Jeep by the pinch weld on the floor connecting to the rocker wall. Not sure how to tackle this or how bad it could be. Opening it up made it worse. I tried to POR-15 the area on the exterior after using an angle grinder. It's almost as if there was a thin layer of real metal before reaching the rest of the metal underneath which was nothing but orange. It rusted from the inside out yet the metal still feels solid. Anyone else have this issue or have seen this issue?
Present :
1991 Jeep Cherokee Laredo @ 183,100 : 01/2016
1997 Jeep Wrangler @ 153,200 : 01/2016
IndridCold89 is offline
post #2 of 2 Old 08-28-2013, 08:03 AM
Zombi
I've seen it from time to time.
The only way to fix rust is to cut it out entirely.
You have to remove 2-3" beyond the visible rust bubble to make sure you got it all.
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
