2004 TJ Wrangler--check engine light - JeepForum.com
post #1 of 16 Old 06-15-2008, 09:23 AM Thread Starter
bsfan1877
ok,,so I bought my TJ used with 60000 miles on her. It runs good, has a 5 speed manual,,and the dreaded check engine light came yesterday. Whats the usual cause for this?? If there is one. Perhaps the 02 sensor??
bsfan1877 is offline
post #2 of 16 Old 06-15-2008, 09:25 AM
htownjeep
What's that noise?
htownjeep's Avatar
Could be lots of things. Go to Autozone and they'll check your OBD for free and tell you what the code is.
Drink upstream from the herd.
htownjeep is offline
post #3 of 16 Old 06-15-2008, 09:32 AM
YUMgrinder
Yea Autozone, not that crappy advance auto or o'reilly's...
Laugh Out Loud.
YUMgrinder is offline
post #4 of 16 Old 06-15-2008, 11:12 AM
otisdog
2008 WK
turn your key on-off-on-off-on and it will flash the codes. Post the codes in here and we'll go from there.
jim
08 Grand Cherokee Overland
otisdog is offline
post #5 of 16 Old 06-15-2008, 11:26 AM Thread Starter
bsfan1877
OK,,I did that,,this is what showed P 0455 Any idea?
post #6 of 16 Old 06-15-2008, 12:17 PM
htownjeep
What's that noise?
htownjeep's Avatar
If you would have gone to the store 2 hours ago when I suggested it you'd probably have the problem fixed.
Check your gas cap.
post #7 of 16 Old 06-15-2008, 12:17 PM
LJameson
Taken from the Jeep Wiki...
"455 A large leak has been detected in the evaporative system! "
As htownjeep said, check the gas cap.
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #8 of 16 Old 06-15-2008, 12:39 PM Thread Starter
bsfan1877
thanks for the info,,,i would have gone to the store when you told me to, but i'm stuck at work until 5:30!!! oh well,,27 years down,,3 to go!!
post #9 of 16 Old 06-15-2008, 12:40 PM
2jhanna
x14 on the gas cap.
once you get a new gas cap on. disconnect a battery terminal for a few minutes to reset the light. should be good to go.
jhanna
denton county, tx
2jhanna is offline
post #10 of 16 Old 06-15-2008, 12:42 PM
htownjeep
What's that noise?
htownjeep's Avatar
haha....oh well. At least you know where to start looking. Hope it's just your gas cap.
post #11 of 16 Old 10-04-2010, 07:28 PM
Mhaddy
Sorry to necro this thread but I've got a P 0138, what am I looking at here?
Mhaddy is offline
post #12 of 16 Old 10-04-2010, 07:44 PM
biffgnar
biffgnar's Avatar
OBD-II Check Engine Light Trouble Codes
O2 sensor high voltage, bank 1 (closest to front of jeep), sensor 2 (downstream)
Romney in 2020!
biffgnar is offline
post #13 of 16 Old 10-04-2010, 07:48 PM
rnolloth88
You can go to Auto Zone Advance or O'Reilys.They are all ****ty parts stores at BEST.They will read the codes for ya.But they're code readers do only that.Hopefully a p0455 code is just the gas caP,which is normally the case.People think that Autozone or these places can fix your Jeep or car with just a code reader.They are sadly mistaken it takes alot more than a code reader to properly fix a vehicle...
rnolloth88 is offline
post #14 of 16 Old 10-04-2010, 07:53 PM
Jetscuh
O rly?
2015
A large leak is more than likely something other than the gas cap.
Jetscuh is offline
post #15 of 16 Old 10-07-2010, 09:45 PM
Mhaddy
Thanks a lot. I had a chat with my mechanic and he confirmed what you've noted above. While it's in the shop, I'd like to have the guys do a general tune-up on it as it hasn't had one in years. Aside from plugs, wires and looking at the throttle body, what ekse would you suggest?
Mhaddy is offline
97 Wrangler -Check Engine Light On Craig's Jeep TJ Wrangler Technical Forum 14 10-29-2014 05:33 PM
check engine light 2002 wrangler sandbaggz TJ Wrangler Technical Forum 4 01-09-2010 04:47 PM
Check Engine Light 2004 auto with 4.0 johnmre TJ Wrangler Technical Forum 2 12-29-2009 08:40 AM
03 Wrangler check engine light havasupar8head TJ Wrangler Technical Forum 5 06-15-2008 03:06 PM
2004 TJ help... (check engine light, erratic idle) spYder miKe TJ Wrangler Technical Forum 11 04-28-2008 06:16 PM
