2004 TJ Turn Signal Craziness - Page 2 - JeepForum.com
post #16 of 17 Old 06-10-2012, 09:01 AM
1999TJRED85000
Originally Posted by justinlancaster
So... I replaced the Brake/Signal & Third Brake Light bulbs and it fixed the fast blinking... For a 1/2 day.
Yesterday it started again, same side. Plus the beeping & solid Left Signal light on the dash I mentioned in the OP.
Going to check my lights this morning to see if any more bulbs blew.
Thoughts?
Take a little sand/Emory paper and slip it back and forth in the slot where the bulbs go. It should shine up the surfaces so they make clean contact. The other post was probably right, it sounds like a loose connection or socket at the bulb.
F U
1999TJRED85000 is offline
post #17 of 17 Old 06-10-2012, 09:12 AM
umbra
2014 KL Cherokee
Originally Posted by justinlancaster View Post
I think I'm having the same issue.
Last week I noticed my Rt Front Turn Signal was out. Tapped on it and it came back on. Took it apart and it looked like the bulb was a little loose. Also, the socket had separated from the wiring harness a little. Couldn't get it to click back together though. Think it needs to be replaced?
I haven't yet, whenever it starts acting goofy, I pop it out and fool with it until it works. It will usually do okay for a few weeks, then go out again.
Just haven't gotten around to replacing it yet.
umbra is offline
blinker , electrical issue , turn signal
Broken turn signal lever, Need to turn OFF hi-beams Tulsachokehold YJ Wrangler Technical Forum 16 12-10-2014 12:39 AM
New turn signal switch, no left signal? sasquachYJ YJ Wrangler Technical Forum 4 01-25-2010 09:07 PM
Driver side rear turn signal -- no signal --chris-- YJ Wrangler Technical Forum 5 02-23-2008 07:43 PM
Turn signal does not click off after completeing turn vr6mole TJ Wrangler Technical Forum 1 05-12-2007 09:49 PM
Turn signal to fast, brake/turn fuses blowing and a gas gauge with an identity chrisi pyro9862 YJ Wrangler Technical Forum 3 06-29-2005 01:35 PM
