2004 TJ Sport Oxygen Sensor? - Page 2 - JeepForum.com
post #16 of 19 Old 03-29-2011, 03:17 AM
Night Wolf
Originally Posted by neon22 View Post
Currently I have approximately 129,000 miles, and my gas mileage has decreased to around 10mpg even thou I shift at 1250rpm. I dont know the reason but mpg dramatically increased when I cleaned the throttle body and is now around 15mpg. Occuasionly the check engine light will come on, and I receive the codes P0159 P0153. I dont know if it is normal or not but, it at rpms above 2500 the engine sounds rough. For whatever reason, when it rains the engine smooths out. A buddy has a 97 TJ Sport and he says his does the same. Is this normal? If not I was thinking it might be the belt.
Please explain your logic on this...
-Rick
-1987 BMW 528e 5spd e28 - personal Panzer for the daily driven battlefield, just broken in at 300k
-1990 BMW 325i Convertible 5spd e30 - extensive overhaul in progress
-2005 TJ Sport - stuff
Night Wolf is offline
post #17 of 19 Old 12-01-2013, 06:12 AM
Chuck59
I don't know but am just asking, does an 04 Wrangler have downstream O2 sensors? I thought downstream sensors on Wranglers began in 2005?
I agree with others on NO Bosh sensors. I have seen them go bad within weeks of install.
Chuck59 is offline
post #18 of 19 Old 12-01-2013, 07:42 AM
bthompson
My 02 TJ has both upstream and downstream, so I'd expect that an 04 would as well.
bthompson is offline
post #19 of 19 Old 12-01-2013, 06:38 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
All TJ's have upstream and downstream O2 sensors...
Knuckelhead is offline
bosch auto parts , fuel economy , oxygen sensor , repair
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
Very confused! banck two sensor two oxygen sensor imnotaniceboy TJ Wrangler Technical Forum 5 03-12-2010 04:22 AM
what Oxygen Sensor for a 2004 sahara 4.0? imnotaniceboy TJ Wrangler Technical Forum 4 02-03-2010 08:37 AM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 01:29 PM
Oxygen Sensor for '97 2.5L Sport Nynni TJ Wrangler Technical Forum 3 06-25-2008 08:49 AM
