2004 TJ Sport Oxygen Sensor? - JeepForum.com
post #1 of 19 Old 03-23-2011, 08:10 PM Thread Starter
neon22
Does anyone know what the oxygen sensor numbers are to replace all four? I know their is two up stream and two down stream. I recently went to O'Reilly and was given a paper of the following: Bosch 15504 $24.99, Bosch 15505 $39.99, Bosch 13687 $72.99, Bosch 15506 $29.99. Do I need one of each or are some better than others. Money is tight and would like to purchasing the least expensive product(s).
neon22 is offline
post #2 of 19 Old 03-23-2011, 08:10 PM Thread Starter
neon22
engine is 4.0l
neon22 is offline
post #3 of 19 Old 03-23-2011, 08:48 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
How many miles on your 04?Is it running poorly?Why do you want to replace all 4?Are you getting any DTCs?
GOLENJEEPTJ is offline
post #4 of 19 Old 03-23-2011, 10:20 PM
RogueSpear2023
I agree what is causing you to want to replace all 4? Are you getting any codes, the 2nd set of O2 sensors will usually through a code, the first set of O2 sensors sometimes won't, but if you aren't getting a code and think you need to change them I would just do one at time replacing the ones in front of the cats first. But give us your symptoms that make you think they are the O2 sensors.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #5 of 19 Old 03-23-2011, 10:50 PM Thread Starter
neon22
Currently I have approximately 129,000 miles, and my gas mileage has decreased to around 10mpg even thou I shift at 1250rpm. I dont know the reason but mpg dramatically increased when I cleaned the throttle body and is now around 15mpg. Occuasionly the check engine light will come on, and I receive the codes P0159 P0153. I dont know if it is normal or not but, it at rpms above 2500 the engine sounds rough. For whatever reason, when it rains the engine smooths out. A buddy has a 97 TJ Sport and he says his does the same. Is this normal? If not I was thinking it might be the belt.
neon22 is offline
post #6 of 19 Old 03-23-2011, 11:03 PM
Sundowner
Still doesn't explain why you want to replace all your sensors...
If you have an intermittent CEL, then you might just have a wire or connection that's faulty. If you do replace your sensors, then use Mopar units...no Bosch!
Sundowner is offline
post #7 of 19 Old 03-23-2011, 11:25 PM
Imped
Imped's Avatar
You're getting **** mileage because you're shifting at 1250 rpm.
OlllllllO
IndyORV
Imped is offline
post #8 of 19 Old 03-23-2011, 11:27 PM Thread Starter
neon22
Sorry I got a little off topic here.
neon22 is offline
post #9 of 19 Old 03-24-2011, 02:59 AM
Baseplate
Pretty sure the Mopar ones are NGK.
www.rockauto.com is where I buy mine.
Baseplate is offline
post #10 of 19 Old 03-24-2011, 04:19 AM
Neil F.
Don't do the Bosch. Bosch have worked fine for me on other vehicles but on the Jeep, I replaced all of mine and the up stream ones both triggered heater codes in the winter (they are fine in warmer weather). Reading other posts, other people have had the same with Bosch and the Jeep.
Neil F. is offline
post #11 of 19 Old 03-24-2011, 09:53 PM Thread Starter
neon22
Alright, but my main question is what fuel injectors do I need. eg number(s) ?
neon22 is offline
post #12 of 19 Old 03-25-2011, 12:57 AM
Zen
Fuel injectors?
I buy my Mopars o2 sensors at www.moparpartsamerica.com. The descriptions will tell you upstream or downstream. If not, it will say sensor 1 or 2. Sensor 1 in each bank is before the cat.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #13 of 19 Old 03-25-2011, 11:06 AM
Sundowner
Fuel injectors? Where'd that come from?
Oh, and I'm seconding the comment about lousy mileage because of your low shift point. You need to shift about 2,000 HIGHER than that. Otherwise, you're just throwing retarded amounts of fuel into an engine that's being driven in too high of a gear.
Notice that I said "higher"...as in, try shifting around 3,000 or 3,200.
Your stumble at 2,500 is another matter, and no...the Jeep suddenly running fine when it rains is NOT normal.
post #14 of 19 Old 03-25-2011, 11:14 AM
bthompson
x2 against Bosch. A friend of mine is a dealer service manager and has seen Bosch O2 sensors go out within months of replacement on Jeeps. I just had him pick me up 2 OEM O2 sensors for my 02 TJ. He said the same as someone else here did: Replace the upper (before the cat) sensors first and it should definitely help.
Edit: Call the dealership and give them your VIN and they can tell you exactly which part numbers to order (whether you get it through them or somewhere else).
bthompson is offline
post #15 of 19 Old 03-28-2011, 10:37 PM Thread Starter
neon22
Sorry oxygen sensors
neon22 is offline
bosch auto parts , fuel economy , oxygen sensor , repair
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
Very confused! banck two sensor two oxygen sensor imnotaniceboy TJ Wrangler Technical Forum 5 03-12-2010 04:22 AM
what Oxygen Sensor for a 2004 sahara 4.0? imnotaniceboy TJ Wrangler Technical Forum 4 02-03-2010 08:37 AM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 01:29 PM
Oxygen Sensor for '97 2.5L Sport Nynni TJ Wrangler Technical Forum 3 06-25-2008 08:49 AM
