2004 Rubicon drives like dog crap - JeepForum.com
post #1 of 41 Old 08-09-2011, 10:01 PM Thread Starter
aaron-jeep
I have a 2004 Rubicon that drives like dog crap.
I know nothing about suspensions, but mine feels totally shot.
How I can get a better driving jeep without putting in a lift kit?
Can anyone recommend a good all-inclusive kit, or brand of shocks to use?
My jeep is stock except I added a Warn 9.5 si winch.
aaron-jeep is offline
post #2 of 41 Old 08-09-2011, 10:02 PM
kashoggio
How many miles are on the jeep? Auto or stick?
2004 TJ RUBICON~ LIME GREEN
"Some desire is necessary to keep life in motion."
kashoggio is offline
post #3 of 41 Old 08-09-2011, 10:03 PM Thread Starter
aaron-jeep
55,000 Auto
post #4 of 41 Old 08-09-2011, 10:04 PM
Jrob05
Did it drive fine before the winch?
Jrob05 is offline
post #5 of 41 Old 08-09-2011, 10:05 PM Thread Starter
aaron-jeep
yeah, but I put the winch on in 2005. It has been fine until the last year, year-and-a-half that it has got really bad.
post #6 of 41 Old 08-09-2011, 10:07 PM Thread Starter
aaron-jeep
now it feels like there is no suspension at all. every time i go over a bump *bang* the whole jeep raddles. Id really like to getting riding nice again.
post #7 of 41 Old 08-09-2011, 10:12 PM
Jrob05
Are you typing this out as your driving? Because it went from bad to none in 6 minutes.
Jrob05 is offline
post #8 of 41 Old 08-09-2011, 10:17 PM Thread Starter
aaron-jeep
lol, no. No suspension may be a little bit of an over exaggeration, but it's really bad.
do you have any ideas on what a I could do to fix it? Is it enough usually to just get new shocks?
do you change the springs too? I heard someone say something about a steering damper.
post #9 of 41 Old 08-09-2011, 10:26 PM
stwilson74
stwilson74's Avatar
It's probably a combination of the firmer Rubicon springs with worn out shocks, worn out control arm bushings, and load range D or E tires that are over-inflated. Replace your shocks and bushings and air your tires down and it should make things drastically better... of course if your going to tear into it that much then you are already doing most of the work involved in doing a lift. As far as recommending a lift, that all depends on what you are doing. Personnaly I went with a Currie 4" on my 2005 Rubicon LJ and it rides better than stock now.
"Betsy" 2005 Unlimited Rubicon Sahara Edition #603 of 1000
Originally Posted by Necromancer_tat View Post
I like having my panties in a wad though, because when I get DW they rub me in just the right way! :D Wadded panties plus DW equals Jeepgasm! :D :kiss:
stwilson74 is offline
post #10 of 41 Old 08-09-2011, 10:27 PM
Jrob05
Well welcome to the forum, and you should fill out your profile so people can help you out. But to answer your question it sounds as though you have some worn out parts. How is the front end sitting compared to the back? Check center of flare to to ground to get an idea. With a winch on the front it can accelerate wear on components, and with the roads in NJ stuff wears out even faster.
Jrob05 is offline
post #11 of 41 Old 08-09-2011, 10:46 PM Thread Starter
aaron-jeep
Hey stwilson74, Thanks for the advice. I will replace the shocks and bushings. Do you have any recommendations on what brand to use? How does that 4" lift affect your gas mileage? I was considering the 2.5 OME lift, but as you know the Rubicon doesn't get the best gas mileage to begin with the lift and bigger tires i was afraid I wouldn't want to travel to far from home.
post #12 of 41 Old 08-09-2011, 10:50 PM Thread Starter
aaron-jeep
Jrob05, I will update it now. haha. I guess you know these roads well. They are especially bad after those storms we had over the winter. My jeep is a 2004 rubicon totally stock except the winch. I will check the heights.
I am going to look around for the best brands of shocks. Please let me know if you have any part suggestions. Do you get offroad much?
post #13 of 41 Old 08-09-2011, 10:54 PM Thread Starter
aaron-jeep
seems like Rancho RS9000XL is the most expensive at $105 each. do you think thats the best
post #14 of 41 Old 08-09-2011, 11:21 PM
MayRoll
Please tell us your tire pressure.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #15 of 41 Old 08-09-2011, 11:38 PM Thread Starter
aaron-jeep
They are a little below the 44 lbs suggested.
jeep , lift , rubicon , stock suspension , suspension
2004 Jeep rubicon seats the same as 2004 wrangler x Zjs21 TJ Wrangler Technical Forum 4 04-14-2011 08:43 PM
2004 rubicon should i buy it or not??? bcheung30 Wrangler General Discussion 10 12-24-2010 07:23 AM
Still Drives like Crap samcarroll TJ Wrangler Technical Forum 8 08-23-2007 11:14 AM
Drove my freinds 2004 x yesterday and i drives sooo much better then my 97 sport why? chaznad TJ Wrangler Technical Forum 23 09-18-2005 11:21 AM
Aye Caramba!!! My electrical crap has returned! (and Rubicon question) CoriolisSTORM TJ Wrangler Technical Forum 4 04-12-2005 08:45 PM
