2004 LJ Precat Failure - JeepForum.com
post #1 of 23 Old 08-10-2013, 07:09 PM Thread Starter
jermeyg
With a P0420 code. I removed my cat system and saw that one of the precat honeycomb was missing. Since everything seemed okay I ordered a new eastern cat system (20379) off rock auto put everything back together and kept driving.
http://www.rockauto.com/catalog/rafr...&parttype=5808
Well eventually on my way back from Moab on the I-70 I lost power and couldn't go over 50mph. It continued to get worse because the exhaust was clogged. So after some gracious jeepers got our Jeep home I removed the exhaust and made this little video to show what I found. Hopefully it helps
*disregard the welds on the pipe near the flange I was setting the welder for the new cat system.
jermeyg is offline
post #2 of 23 Old 08-10-2013, 09:36 PM
ckspeed
Linky no worky....
ckspeed is offline
post #3 of 23 Old 08-11-2013, 01:16 PM Thread Starter
jermeyg
Originally Posted by ckspeed View Post
Linky no worky....
I am sorry about that. I think I finally got it fixed!
jermeyg is offline
post #4 of 23 Old 08-11-2013, 01:28 PM
1982cj8
You always have to replace all 3 cats together. I purchased the eastern cats and removed the rear one when I did it, only the front cats are monitored so no check engine light and it runs better.
Always bring a compass, it is awkward to have to eat your friends.
4X4XNORTHWEST.COM
1982cj8 is offline
post #5 of 23 Old 08-11-2013, 02:21 PM Thread Starter
jermeyg
Yep I replaced all three myself although I didn't remove the third one. I imagine it probably run a little better and cooler.
jermeyg is offline
post #6 of 23 Old 08-25-2013, 08:13 PM
BMorrNH
No way! I have a 2004 LJ, my dealership is trying to get $875 plus 2 hours for all 3, one piece. I have a local shop that wants $600 + 2 hours. Where can I buy my own one piece front pipe with all 3? It's rattling, I've noticed loss of power and poor gas mileage. Nothing alarming, but the front is rattling and check engine light is on and off every now and again.
BMorrNH is offline
post #7 of 23 Old 08-25-2013, 09:04 PM
ckspeed
Rockauto has them for around $300+/-
'04 TJ-6 - Work in progress....always
ckspeed is offline
post #8 of 23 Old 08-26-2013, 04:06 AM
clayduster71
Ebay $327.18
I bought the whole thing from Midwest Auto for $327.18 delivered on Ebay the other day.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=350860795660
clayduster71 is offline
post #9 of 23 Old 08-26-2013, 07:31 AM Thread Starter
jermeyg
I got mine at rockauto as well. So far so good!
jermeyg is offline
post #10 of 23 Old 08-26-2013, 08:41 AM
gtospeeding
why not remove the cat material (gut it) and bolt it back up?
gtospeeding is offline
post #11 of 23 Old 08-26-2013, 10:52 AM
vishrb
just installed the eastern cadalytic as well. Purchased from Rock Auto also. Just one day out so no real thoughts yet. Initial quality seems good.
vishrb is offline
post #12 of 23 Old 08-26-2013, 11:49 AM
J03_TJ
So I'm just curious, are you guys talking about a one piece item that contains all three cats and is bolt on? Or do you have to do some welding?
J03_TJ is offline
post #13 of 23 Old 08-26-2013, 01:51 PM Thread Starter
jermeyg
The eastern cat is a two piece bolt on setup. They give you an exhaust clamp to tighten the precat to the third cat. You can choose to weld them together if you choose. Adjustments need to be made if you are running a raised skid plate of course.
jermeyg is offline
post #14 of 23 Old 08-26-2013, 04:27 PM
vishrb
Mine did not come with clamp. I had to buy one. but yes had all three cats. So far so good.
Can you diggit it, suckas!!!
vishrb is offline
post #15 of 23 Old 08-26-2013, 10:44 PM
J03_TJ
Thanks. I have never been lucky enough to have a vehicle last long enough for cats to go out. Just thought I'd ask. Got another question for those that have experience with clamps. I cant help but go off of stories of clamps on exhaust coming loose, but don't really know if its hype or incorrect install reports. Does it matter that the clamps are up near the engine and probably the portion of the exhaust that gets the most vibration? Just wondering if clamps tend to work or they don't?
J03_TJ is offline
