2004 LJ, auto, 4.0. Question: Is there an 02 Sensor 101 for Dummies? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2004 LJ, auto, 4.0. Question: Is there an 02 Sensor 101 for Dummies?
Engo winches available at www.rockridge4wd.com! Free shippDan's Old as Dirt Birthday Sale!Advance Adapters SYE Kits
Unread 04-18-2013, 07:55 AM   #1
wage
Hey Gang,
My 04 LJ now has about 82M miles on her. after spending too much time reading this Jeep Porn, I think I should be looking at replacing my 02 Sensors.
1_ I know there are 4, but where are they located?
2- How hard to replace?
3- Do I need any special tools?
4- Do I use an anti sieze goop on the threades?
Tahnk you in advance for your help.
wage is offline   Reply With Quote
Unread 04-18-2013, 07:58 AM   #2
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
1. two before the mini-cats in the manifold, two after the mini-cats, in downtube.
2. nope, easy
3. O2 sensor socket. basically has an open end so you can slide it on over the wire. http://www.harborfreight.com/3-8-eig...nch-97177.html
4. yuppers
Unlimited04 is offline   Reply With Quote
Unread 04-18-2013, 08:42 AM   #3
NotURMailman
82,000,000 miles?
Me thinks that was a typo...
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote
Unread 04-18-2013, 01:08 PM   #4
wage
does anyone have the following:
Part numbers for 02 sensors:
Front Pre cat
Rear Pre cat
Front Post Cat
Rear post cat
also what is the besy source for buying these?
Stealership quote:
Rear Pre cat $68.75
Front Pre Cat $74.25
Thank you in advance for your help.
Unread 04-18-2013, 01:50 PM   #5
Unlimited04
www.rockauto.com
NTK brand = stock
Unread 04-18-2013, 02:51 PM   #6
SKINUM
Front pre cat
rear pre cat
front post cat
rear post cat
Stealership quote:
Rear pre cat $68.75
front pre cat $74.25
thank you in advance for your help.
23158, 23159, 23160, 23018 NTK, BOSCH, DENSO....stick with the NTK's due to others experiencing problems with other brands.
Look at Amazon & Rockauto. Amazon had better prices on 59 & 18 the last I checked & Rockauto was better on 58 & 60.
SKINUM is offline   Reply With Quote
Unread 04-18-2013, 03:12 PM   #7
timberwolf0122
timberwolf0122's Avatar
I bought an O2 sensor socket and it was a waste of money and awkward to use, in the end I used an adjustable wrench.
Atheist Jeep Club Member #2
MacGyver Club Member #1
Doctor Who has died 10 times, is on his 11th regeneration and has a time machine, beat that Jesus.
I think he's calling his Jeep "Tardis," which is British slang for pimp mobile. - Dangfoo
timberwolf0122 is offline   Reply With Quote
