2004 California TJ idle speed fluctuates - JeepForum.com
post #1 of 3 Old 01-28-2011, 05:46 PM Thread Starter
hobigusn
My 2004 tj has an intermittent problem. At idle the rpm fluctuates. It will drop to 1 1/4 dot on the tach (400-450rpm I think). It will stay that low until you tap the gas. Idle speed goes to about normal rpm but flucuates by a needle width. I've been chasing this problem for awhile. I found a piece of metal (wire rope strand about 1 inch long) stuck to my crankshaft sensor. I remove it and replaced the sensor because I already bought one. Before changing Crankshaft sensor the jeep would stall in stop and go traffic. Now it doesn't stall but it doesn't have a smooth or steady idle. I've done a tune up, camshaft sensor, speed sensor, idle air controll module, map sensor, throttle postion sensor and up stream O2 sensors. Any idles?
hobigusn is offline
post #2 of 3 Old 01-28-2011, 06:02 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
When you replace all of those items did you give the throttle body a good cleaning?I mean like taking it off the intake manifold?Check all you vacuum hoses and fittings for looseness,cracking,etc.
GOLENJEEPTJ is offline
post #3 of 3 Old 01-28-2011, 06:17 PM Thread Starter
hobigusn
I cleaned the throttle body really good. But idk about the vacuum hoses. Where are they and what are they attached to? I did't think fuel injection had vacuum hoses.
hobigusn is offline
2004 Rubicon 5 speed wont go into gear when running oif03vet TJ Wrangler Technical Forum 11 11-01-2010 08:32 PM
2004 Rubicon highway speed runs badly Armymitch TJ Wrangler Technical Forum 14 08-11-2010 08:14 AM
2004 TJ 4.0 5mt off idle hesitation iamadam1122 TJ Wrangler Technical Forum 1 06-16-2009 05:38 PM
2004 TJ - Low Idle Speed JFiorentino TJ Wrangler Technical Forum 1 02-25-2007 06:18 PM
****! I drove to California and on the way my 6-speed went to crap... JeepinYahoo TJ Wrangler Technical Forum 17 06-12-2006 01:19 AM
