2003 wrangler TJ sahara. stereo amp and sub. - JeepForum.com
post #1 of 4 Old 08-06-2011, 08:37 PM Thread Starter
BadKarma1701
Hello. HELP !!!!!!!!!!!!!!!!!!! I have searched the net high and low for the stats on the stock 7 speaker system amplifier that feeds the sub. I also cannot find any info on the sub itself. If anyone has any info on the ratings of these items please respond.
Thank you
HONOR, TRUTH, LOYALTY, JUSTICE. DEEDS, NOT WORDS.
"I came into this world kicking, screaming, and covered in someone else's blood and I'm damned sure going out the same way!"
Sienna Jeep Owners Member #56
BadKarma1701 is offline
post #2 of 4 Old 08-06-2011, 08:44 PM
scs2016
It is a low power, 33 watt (if I recall) amp that's triangular (buried inside the stock console). I'm still using it to power a little 6.5" Kicker sub that I put in the stock enclosure and put inside a Tuffy console. I didn't want to have to put an amp under one of the seats and then have it flood...
scs2016 is offline
post #3 of 4 Old 08-07-2011, 11:57 AM Thread Starter
BadKarma1701
Thanks. was able to find wiring guide here
http://crutchfield.custhelp.com/app/...h3NFlBaw%3D%3D
if anyone knows more specs on sub speaker or more on amp that woud be great
thanks
post #4 of 4 Old 08-07-2011, 12:03 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
If you want real bass,add a Sony 6.5" sub and quality amp.I bought a $30 box that fit behind the rear seat.I added two 8" subs/two tweeter - midranges and a 300 watt amp and it sounds great.You can't even hear the soundbar or dash speakers and it's super clear.
TheBoogieman is offline
2003 Wrangler Sahara Tires HELP eforst Wrangler General Discussion 0 06-20-2011 02:02 PM
Help on top for 2003 Sahara TJRich TJ Wrangler Technical Forum 16 05-20-2010 10:37 AM
2003 Wrangler/2007 Stereo Swap barrylshapiro TJ Wrangler Technical Forum 3 07-26-2009 05:35 PM
Removing Stereo 2003 TJ driftgirl TJ Wrangler Technical Forum 12 02-24-2009 10:26 PM
Two questions for my 2003 sahara smasson TJ Wrangler Technical Forum 1 04-15-2006 09:16 PM
