Quantcast 2003 Wrangler pro comp adjustable front trac bar - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2003 Wrangler pro comp adjustable front trac bar
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 10-27-2008, 05:10 PM   #1
forneyjeeper
Just wanted to know what is the proper way to adjust the front trac bar and if there is any tip i should know before i get into it.
forneyjeeper is offline   Reply With Quote
Old 10-27-2008, 05:15 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Without the trackbar in place, the coil springs will pretty much self-center the front axle without you doing much. Stepping up onto the bumper to bounce the suspension will help further self-center it. Then adjust the trackbar length so its mounting hole lines up with the bracket hole and you should be good go go. If by measuring it's still not exactly centered, turning the steering wheel a bit without the trackbar connected will move the axle slightly to the side to get it more perfectly centered.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Glock Forum
