2003 Unrolled (pics) - Page 9 - JeepForum.com
post #121 of 694 Old 08-29-2008, 07:52 AM
jeepwrnglr92
2015 JK Wrangler
wow that is a lot of work. Looks great
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #122 of 694 Old 08-29-2008, 10:35 AM
BaystateTJ97
you ****in suck....
'97 TJ Sport SOLD!
'90 YJ Laredo
Vote for your freedom back on November 6, 2012.
BaystateTJ97 is offline
post #123 of 694 Old 08-29-2008, 01:53 PM
omninate
Amazing turnaround! Great work!!
"It is NOT a mall-crawler. Did you not see me park on that snowbank in front of the food court?" - my friend Bill
omninate is offline
post #124 of 694 Old 08-29-2008, 10:10 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Got the control arms, frame and axle mounts mocked up. Also welded the knuckles up. Got one of the knuckles and unit bearing almost fitted up. They are really a tight fit.
I have to redo the upper control arm bracket on the diff. It needs to point further back so as not interfere with the track bar.
Tip: when welding up the frame mount upper tab leave the JJ in as the heat sucks the tab down. Bending 1/4" steel is not easy. I had to file it down a little so the JJ would go back in.
Here is the massive knuckle and E350 unit bearing
Better angle of the control arms. I set the upper to vertical and will rework tomorrow.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #125 of 694 Old 08-29-2008, 10:31 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I have a piece of tube that the bolt slides through that I use so I don't smoke the races in the JJ. You want to cut it to just over 2 9/16's so you have some slack to drop the JJ down into. 1/4" is not very forgiving if the welds move the tabs.
You're moving right along. I wish I could get stuff done that fast.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #126 of 694 Old 08-29-2008, 10:35 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Thanks Blaine! You make it easy for me!
Another great idea on cutting a tube to 2-9/16" (I think I can find a piece of tube somewhere. ) I'm going to use that when I final weld all of the control arm brackets.
Like us on Facebook
Savvy is offline
post #127 of 694 Old 08-30-2008, 08:20 AM
4x4Mudmonster
Dude... That thing is sick!!! And I also admire how you Build everything yourself!!
-Anthony-
4x4Mudmonster is offline
post #128 of 694 Old 08-30-2008, 08:35 AM
BigSki
No vibe with the RE SF kit. I really liked the kit. I did put in a SYE (in the 231) then 241 TC with the SYE.
I just can't leave things alone! MrBlaine has alot to do with it!
so the SYE kit made for the 231 TC also works on a 241 TC?
Thanks for the great documentation of your build up, it looks like a first rate job! Does you shop normally do fab work like this, or did you make your own 'monster garage' work space? I'm jelious either way.
BigSki is offline
post #129 of 694 Old 08-30-2008, 11:37 AM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Monster Garage all the the way! Old man hobby! I wrenched at my brother shop for years after high school and during college.
The 241 has fixed output yokes so no need to install a slip yoke eliminator. Only the 231 needs the kit. It is sometimes less money, better lo gear and easier to install by getting a 241.
Thanks guys
Like us on Facebook
Savvy is offline
post #130 of 694 Old 08-31-2008, 09:44 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
This will keep you entertained for a bit.
I am Savvy
mrblaine is offline
post #131 of 694 Old 08-31-2008, 10:34 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Hopefully I get my steering arms Tuesday or Wednesday so I can start looking at the steering.
Is the above pic at full stuff?
Like us on Facebook
Savvy is offline
post #132 of 694 Old 08-31-2008, 11:06 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
3/4's of an inch from fully stuffed.
I am Savvy
mrblaine is offline
post #133 of 694 Old 09-01-2008, 12:23 AM
BomberJeep
2011 WK
Great build. I wish I was out west so I could ride some of the nice trails you have out there.
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
post #134 of 694 Old 09-01-2008, 10:03 AM
dbms95
Wow, I wish I had just 1/10th of your ability or time. Great build and write up.
dbms95 is offline
post #135 of 694 Old 09-04-2008, 10:15 AM
472cid
I read thru your both threads and i have to ask where does the surplus rubicon parts keep coming from? Both the 03 and the 06 had rubicon doghouses and you had rubicon axles for a while in the one? Where are all these rubicons? i want one
472cid is offline
rubicon? (2003 Rubi vs. 2003 Sport) Tom1 TJ Wrangler Technical Forum 10 09-08-2008 07:24 PM
2003 Tj Canfourjeep TJ Wrangler Technical Forum 5 03-02-2008 12:12 PM
replace 2003 skid plate with <2003 frankske_ TJ Wrangler Technical Forum 5 04-08-2007 06:00 PM
Pics of my 2 day old 2003 Sienna Pearl - Sahara u4ea TJ Wrangler Technical Forum 24 07-15-2003 06:03 PM
my 2003 Tj Sport (pics, as requested) :D dan58 TJ Wrangler Technical Forum 17 09-04-2002 08:21 PM
