2003 TJ - Moving fog light switch from MFS to toggle switch - JeepForum.com
post #1 of 11 Old 07-02-2009, 11:54 AM Thread Starter
TJeep_1999
2015 JK Wrangler
My Multi Function Switch crapped out and now my fog lights are stuck on even when the Jeep is off. I pulled the fuse for a short term fix, but would really like to set this up with a toggle switch like they had on the earlier model TJ's. I have a strong dislike for Jeep's MFS and would rather bypass it then replace it. I like the toggle better anyway.
I saw in another post where some one re-wired thier fog lights from the MFS to a switch in the dash. They didn't give any detail though. Is there a thread out there that details how to do this? What wires to splice and where? I must be search challenged b/c I could not find anything out there... Just as good would be if some one could post that info here... Pictures would be especially helpful, but I'll take what ever help I can get. Thanks!
TJeep_1999 is offline
post #2 of 11 Old 07-02-2009, 06:25 PM
2003RubiBlue
When you take off the column cover you will see a lot of wires with a large grey plug. One of the wires in this plug is white with an orange tracer. Take this wire from the connector and run it to your new toggle. Then connect the other pole of the switch to any ignition switched circuit i.e 12v when the key is on, or off if you prefer your lights to work with the key off. After all its just the trigger side of the relay you have to power. Then all of your factory stuff will still work, i.e. dash indicator lights. Hope this helps.
2003RubiBlue is offline
post #3 of 11 Old 07-03-2009, 07:37 AM Thread Starter
TJeep_1999
2015 JK Wrangler
Thank you! Will give it a try.
post #4 of 11 Old 11-25-2009, 05:42 PM
VegasMatt
Sorry, I'm pretty unskilled when it comes to electrical know-how - What wires, specifically, can I splice this end of the rocker panel to in order to have it switched or not switched? Like the radio power or something? Or could I jam a fuse and a wire into a slot on the behind the glove box panel? Any photos?
Thanks
08 JK Rubi (toy)
97 328i (DD)
01 TJ Sport (sold)
97 TJ SE (RIP)
97 R850R (sold)
98 CBR 600F3 (sold)
VegasMatt is offline
post #5 of 11 Old 11-25-2009, 07:22 PM
Brew461
Thanks
What are you trying to do matt?
Mine: 03 TJ
Hers: 01 XJ
Brew461 is offline
post #6 of 11 Old 11-25-2009, 11:42 PM
VegasMatt
I'm trying to migrate control of the factory fog lights from the MFS to a rocker panel switch. I remove the steering cover on the steering column, and the orange traced wire on the MFS goes into one prong of the rocker. The other end of the rocker connects to a switched or unswitched power source. My question is, where do I locate a source of either kind? Basically, just wondering where I can find a source of switched or unswitched power in the cab? Thanks!
08 JK Rubi (toy)
97 328i (DD)
01 TJ Sport (sold)
97 TJ SE (RIP)
97 R850R (sold)
98 CBR 600F3 (sold)
post #7 of 11 Old 11-26-2009, 08:14 AM
cyberiv
Easiest place i found is behind the radio. I have an aftermarket head unit, so i just use the switched wire on that harness for all my light switches (have like 4 all piggybacked off the same one, no issues). I would advise against using constant, as that is how i initially had my lights wired up, and on two different occasions, i had accidentally switched a pair on and not noticed, and came back to the jeep with not only a dead battery, but melted lights and covers as well. After the second time i rewired them to the ignition!
cyberiv is offline
post #8 of 11 Old 11-26-2009, 10:43 AM
VegasMatt
Cyber,
what do you think about maybe using this add-a-circuit and plugging into a switched circuit behind the glove box?
08 JK Rubi (toy)
97 328i (DD)
01 TJ Sport (sold)
97 TJ SE (RIP)
97 R850R (sold)
98 CBR 600F3 (sold)
post #9 of 11 Old 12-12-2009, 11:11 PM
sfcbaker
I guess the 03 had that problem.....mine just went out too, a little smoke behind the steering column.....and now it will not turn off......to the toggle switch fog lights myself.
sfcbaker is offline
post #10 of 11 Old 08-04-2015, 04:49 PM
csharp96
Sorry for the dumb question, I'm learning as i go with this. I hooked up the white and orange wire to the toggle switch. what other wires do i need to hook up?
csharp96 is offline
post #11 of 11 Old 08-05-2015, 04:07 PM
BigAl4102
you need electricity from somewhere, either the fuse box, or the back of the radio...etc.
BigAl4102 is offline
Replacing headlight switch with toggle switch? Randy77358 YJ Wrangler Technical Forum 32 07-08-2011 12:15 PM
toggle switch for d30 disconnect MAX_Xj YJ Wrangler Technical Forum 23 05-18-2010 06:06 PM
ABS toggle switch jeep2008 TJ Wrangler Technical Forum 3 04-17-2009 04:12 AM
Toggle switch for fog lights adp1906 TJ Wrangler Technical Forum 12 03-03-2009 10:56 PM
Missile Toggle Switch Slimer TJ Wrangler Technical Forum 12 06-10-2005 06:58 PM
