2002 Wrangler gas tank skid plate bolt problem - JeepForum.com
post #1 of 5 Old 08-29-2010, 12:42 PM Thread Starter
Relyks
I have a 2002 Wrangler Sport with a bad fuel pump. I sprayed all the bolts with crc. The front bolts were very rusted. When trying to unbolt the front gas tank skid plate bolts in order to lower the tank, two of these bolts broke loose at the top (apparently the CRC didn't work). They just spin in place. Are these carriage bolts that sit in a seat or hex bolts and also, any suggestions at all on how to get these bolts out. Thanks!
Relyks is offline
post #2 of 5 Old 08-29-2010, 01:10 PM
biffgnar
biffgnar's Avatar
Been a little while since I had tank down, but I thought they were carriage bolts.
biffgnar is offline
post #3 of 5 Old 08-29-2010, 02:15 PM Thread Starter
Relyks
Ok. Thanks. Any suggestions on how to get these bolts out?
Relyks is offline
post #4 of 5 Old 08-29-2010, 02:20 PM
biffgnar
biffgnar's Avatar
I'd have to go out and look at how much room you have to work, but maybe you could cut the nuts off with a dremel. Or if you could hold the nut to keep it from spinning maybe you could drill the bolt. Once its loose the bolt comes right out over the top of the bracket. I replaced mine with new hardware when I did Savvy skid.
biffgnar is offline
post #5 of 5 Old 08-29-2010, 03:19 PM Thread Starter
Relyks
Sounds like the dremel is gonna have to be the way to go. Thank you!!!
Relyks is offline
gas , tank , skid , plate , bolt
Gas tank skid plate bklynsal YJ Wrangler Technical Forum 1 07-19-2010 09:34 PM
1987 Wrangler 20 gallon Gas tank straps /w skid plate? Chris Aunchman YJ Wrangler Technical Forum 0 08-31-2009 08:31 AM
skid plate bolt problem slackerme TJ Wrangler Technical Forum 2 06-19-2009 07:58 PM
Gas Tank Skid Bolt Problem..... 19OlllllllO41 TJ Wrangler Technical Forum 3 05-05-2008 10:45 AM
Gas tank skid plate help J13760 YJ Wrangler Technical Forum 1 04-13-2006 11:55 AM
