2002 vs 2003 frame - JeepForum.com
post #1 of 5 Old 08-05-2010, 11:43 AM Thread Starter
BillDog103
2002 vs 2003 frame
Does anyone know what changed between 02 and 03 to make the frames incompatible?
BillDog103 is offline
post #2 of 5 Old 08-05-2010, 11:44 AM
BriansCJ
1994 XJ Cherokee
The skid plate bolts and one on the drivers side moved back a little. I think there was another crossmember added around the gas tan area.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #3 of 5 Old 08-05-2010, 11:57 AM Thread Starter
BillDog103
So is it an easy fit into an older TJ? Anyone looked at this?
post #4 of 5 Old 08-05-2010, 12:40 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
skid plate bolt pattern is different, power steering box is different. it'll probably be easier to fit an older body on the new frame, using the newer frame components. i'm pretty sure theres somebody on this forum that swapped to a newer frame for rust reasons or something..LSU_TJ i think...
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 5 Old 08-05-2010, 01:33 PM Thread Starter
BillDog103
thanks unlimited04... I pm'd LSU_Tj for info. I will post back anything I find for others who want to know.
frame , swap , 2002 , 2003 , differences , dimensions , tj , wrangler
Difference Between 97-2002 TJ and 2003-2006? blt4rox TJ Wrangler Technical Forum 15 01-25-2014 03:33 PM
2003 to 2002 soft top compatability? linexrandy TJ Wrangler Technical Forum 9 04-22-2008 07:50 PM
1997-2002 changes 2003-2006 Materdaddy TJ Wrangler Technical Forum 4 03-08-2008 09:33 PM
will a 2002 winshield frame work on a 2003 2003.wrangler TJ Wrangler Technical Forum 1 09-10-2005 04:03 PM
Will a 2002 Dana 44 bolt up to a 2003? mking7 TJ Wrangler Technical Forum 9 10-11-2003 08:56 AM
