2002 TJ Wrangler with 97/98 engine - Page 3 - JeepForum.com
post #31 of 155 Old 07-12-2010, 08:23 PM
PFM
What transmission does it have? AX15, NV3550?
PFM is offline
post #32 of 155 Old 07-13-2010, 05:28 AM
browning
2007 KJ Liberty
4.0L I-6 242 cu in - 2000-2006
* 190 hp @ 4,600 RPM
* 235 ft/lbs @ 3,200 RPM
* OHV
* Sequential port fuel injection
* 2 valves per cylinder
* Compression ratio = 8.80:1
* Distributor-less ignition
* Redesigned cylinder head
* Redesigned 2 piece exhaust manifold
it has to be a 97 or 98 tj sahara ...if it has sparkplug wires and distributor ...also looking at the motor it is the origional motor for that year ..i don't see a coil pack .also the door sticker, rivets on the dash are untouched but they are very easy to change ....AX-15 - 1997-1999
transmission .i still say u got ROBBED
bone collector
browning is offline
post #33 of 155 Old 07-13-2010, 07:08 AM
SFT2
Originally Posted by Silmar View Post
So I did some research but cannot find where the VIN is stamped on the frame. I find a lot of descriptions for a CJ but nothing on the TJ. So where can I find it on the frame?
On my 2000 it's on the right side of the frame under the door.
Mine- 2k TJ, RC 2.5 lift, .75 spacers, Soft 8s, 33" KM2s, winch, lights, and so on
Hers- 06 WK, bone stock until she leaves it and the credit card with me for an unsupervised weekend
You're the retarded offspring of five monkeys having butt sex with a fish-squirrel.
SFT2 is offline
post #34 of 155 Old 07-13-2010, 07:50 AM Thread Starter
Silmar
@ browning & PFM
I do not know how to check that. I'll need to read deeper into this forum...
@ browning
I'm sure you know exactly what you are talking about but... How do I prove it in court?
I went to Galeana Jeep in Fort Myers this morning. Don't want to disclose the whole argument but:
1) They cannot provide me with the build sheet (because they are not the manufacturer)
2) They cannot check the VIN on the frame, because it's hidden and they don't know where it is (because they are not the manufacturer)
3) Checking the engine, it is "probably" not a '02 but they cannot put anything in writing because they do not want to involve the dealership into some legal battle.
Also, I receive the following from the DMV this morning:
Thank you for your e-mail regarding an engine change in your car.
The department should be informed about an engine change in a motor
vehicle only if the motor vehicle was manufactured prior to 1955. There
is nothing in Florida law that requires a motor vehicle dealer to
disclose the engine change and there is nothing you need to do to be in
compliance.
If we can be of any other assistance, please let us know.
Sincerely,
Division of Motor Vehicles
The way I see it, one way or the other, I'm screwed.
Silmar is offline
post #35 of 155 Old 07-13-2010, 07:53 AM
Andy-WhiteTJ
It's the same on my 1998 as well. It's lightly stamped (engraved) on the outside of the frame right under the passenger door.
1998 White TJ with a whole lotta stuff...
Just another member of:
(a 501(c)(7) Not-for-Profit Corporation)
Member:
(Northeast Off-road Vehicle Alliance)
Andy-WhiteTJ is offline
post #36 of 155 Old 07-13-2010, 07:57 AM
-dirt-
You need to check to see if the VIN on the frame matches the VIN on the body.
Then you'll know if you have a 1997/8 with a 2002 body -or- a 2002 with 1997/8 engine and maybe drivetrain.
Subscribed!
-dirt- is offline
post #37 of 155 Old 07-13-2010, 08:05 AM
highlander4x4
Subscribed!
That is what I was thinking as going through the thread and I surprised it took that long to mention. Also if the VIN does not match you can get a VIN decoder and see what year the motor is. Take the guesswork out of the game.
highlander4x4 is offline
post #38 of 155 Old 07-13-2010, 10:07 AM
mschviuz
Curious....do you have the round knobs for your climate control or do you have the 2 sliders?
By the way...have you been ripping up those curves at deals gap in the jeep?
mschviuz is offline
post #39 of 155 Old 07-13-2010, 10:08 AM
-dirt-
The steering wheel looks like the newer style (non-round piece in the middle), so I bet he has knobs.
-dirt- is offline
post #40 of 155 Old 07-13-2010, 11:13 AM
browning
2007 KJ Liberty
Sahara - 1997-2004
* 4.0L I-6 engine
* Body colored fender flares that are 1" wider than standard TJ flares
* Body color rocker sills
* Optional Dana 44 rear axle
* 16" wheels for 2000-2004 models
* 30" tires
* Full steel doors
* Unique seats and interior trim
* Sahara decals
if it's a 2002 it should have 16"wheels ...
i should note that i live in CANADA if something like that happened to me i would go to the provincial police . they would send the TJ for inspection and in a matter of minutes i would get a readout what year the TJ is ..the police then go to the dealer and NAIL his *** on the wall ..and return my money ..
if you paid for a 2002 and got a 1998 it;s fraude ...and is punishible ...
bone collector
browning is offline
post #41 of 155 Old 07-13-2010, 12:07 PM
Jonny Jeep
Jonny Jeep's Avatar
The code you could read - 903MX12 - means that the engine is a 4.0L engine with 8.8:1 compression ratio (MX) built 1999 (9) march (03) 12th (12). No way a 2002 engine.
Under the number five spark plug or thereabouts there is another flat surface on the engine. Etched there, and VERY hard to read, is the last eight digits of the vin from the Jeep it was originally fitted to.
Jonny Jeep is offline
post #42 of 155 Old 07-13-2010, 12:12 PM Thread Starter
Silmar
@ Jonny Jeep (excellent by the way)
Can you please advise where you got the information from? Can you PM the source?
Top of my head, I recall there is an XP number on the engine (I have the complete number at home). Which will make sense, since X is for '99 Jeeps.
OK, so tonight I will try to find the VIN on the frame (following above posts for the location) so we can clear it (or not) for sure.
I'll let you guys know...
Silmar is offline
post #43 of 155 Old 07-13-2010, 12:35 PM
Robert J. yates
2 things... it has a late model intake manifold on it not a 97/98. You can tell the difference as the early model intake is squared off at the corners, not rounded as shown in the pictures. You also have a late model PCM... completely different in comparison to my 98 PCM.
As for the DMV... you need to find out how they classify the vehicle, ie does it have a clean title or is it a salvaged title or reconstructed title vehicle. The answer they gave you is an answer to a different question.
You are not screwed, you have been defrauded. You need a lawyer.
Robert J. yates is offline
post #44 of 155 Old 07-13-2010, 12:36 PM
SFT2
There's also a difference in the water pump. I discovered this while trying to find a block to rebuild a couple months ago (and failing utterly).
SFT2 is offline
post #45 of 155 Old 07-13-2010, 12:46 PM
Robert J. yates
I've already covered the accessory drive difference.
I will say, the late model intake swap is a piece of cake... I have one on my rig so that a late model intake is there is not surprising to me. I am still perpelexed by the PCM though.... something weird going on there.....
All of that aside, it is very very difficult however, to get an early model motor to work in a late model truck due the accessory drive amongst other things.
My take it is a rebodied Jeep.... not a true 02. More like a crashed or theft recovery 97/98 and rebodied/rebadged to pump up the value.
1997 , 1998 , 2002 , coil rail , distributor , engine swap , year
check engine light 2002 wrangler sandbaggz TJ Wrangler Technical Forum 4 01-09-2010 03:47 PM
2002 or newer engine in a 99 wrangler?? Goondock TJ Wrangler Technical Forum 5 12-09-2009 09:15 AM
2002 wrangler TJ greg61 TJ Wrangler Technical Forum 6 02-08-2009 01:42 PM
Will A 2002 4.0l Engine Bolt Into An 88 Yj??? Help!!! LCDized YJ Wrangler Technical Forum 3 01-12-2004 08:00 PM
2002 wrangler X xxx-ray TJ Wrangler Technical Forum 4 08-29-2001 07:09 PM
