2002 4.0 Rough/High Idle When Cold - JeepForum.com
post #1 of 12 Old 11-10-2008, 02:00 PM Thread Starter
peeweeXJ
My TJ has about 100k miles on it. And the Idle/startup blows compared to my 200k XJ.
No codes
It usually has the poor idle when it has been sitting for 15 hours+ (the length of time I am at work)
I will start it up and it will stumble/misfire on it's way to it's high idle.
It will idle at 1k rpms, until it warms up. The engine will occasionally try to idle down, but then it starts to stumble over itself, and goes back up to 1k.
If I start driving when it's cold, I will push in the clutch, and the RPM's will hold at what they were, or even go up slightly, then slowly start going back down to 1k.
I did clean the TB/IAC after this all started, but nothing changed.
Plugs are perfect.
Have run a couple tanks through it, with different octanes, from different stations.
I also have a related/unrelated? ticking noise that comes and goes when cold.
The ticking will increase with RPM's, and seems to quiet down (not disappear) when the engine gets to running temperature.
I will cruise down the road at 1500 rpms and the ticking will vary in loudness.
You can hear the ticking at idle in the cab with the radio off. You can hear the ticking at high RPM's with radio on, which is really annoying.
If I start the engine up cold, and the ticking is not there, it will show up if I rev it really high.
It has also been the other way around, where I start it cold, and it's ticking, and I'll rev it up really high, and the ticking will go away.
It has the correct/right amount oil, and I have run Rislone and ATF through it. Clean Mopar filter too.
I have also checked exhaust bolts.
I have taken a automotive stethescope to the engine and could not locate the ticking. Sounds like valvetrain though.
Could the idle problem be caused by a bad TPS or IAC? Maybe CKP?
Thanks for the responses
btw- this is not normal for a Jeep, if that's all you have to say.
peeweeXJ is offline
post #2 of 12 Old 11-10-2008, 02:18 PM
PJL
I had a similar problem with my idle. No ticking, though. I replaced the TPS and the IAC and it was fine after that.
It's not enough to bash in heads, you've got to bash in minds.
- Captain Hammer
PJL is offline
post #3 of 12 Old 11-11-2008, 01:45 PM Thread Starter
peeweeXJ
So you replaced both of them at once? So you really don't know which one fixed it?
peeweeXJ is offline
post #4 of 12 Old 11-12-2008, 11:34 AM Thread Starter
peeweeXJ
I will try and get a video soon.
peeweeXJ is offline
post #5 of 12 Old 11-12-2008, 11:56 AM
Wif
Wif's Avatar
No codes
Plugs are perfect.
What the hell do you do for a living to be working 15+ hours
First thing ..
The crap idle and revs holding up does sound like IAC.
Secondly ..
The ticking does sound like tappet noise .. and this one is normal for a Jeep
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #6 of 12 Old 11-12-2008, 12:09 PM Thread Starter
peeweeXJ
First thing ..
Secondly ..
I work at a mine, and I have a 13hr. shift + 3 hrs. on a coach bus to get there.
A tappet noise is consistent, it is not like a wristpin where it quiets down as it heats up.
It might be normal noise if people didn't look at me when I started it up.
Thanks
peeweeXJ is offline
post #7 of 12 Old 11-12-2008, 12:24 PM
Wif
Wif's Avatar
Thanks
Hydraulic tappets do this .. they can tap when cold due to oil starvation or incorrect viscosity oil, or tap when hot due to low oil pressure or incorrect viscosity oil.
Sometime noisy tappets can be caused by a faulty oil filter .. the anti-drainback valve letting all the oil from the oilways drain back into the sump.
Formally 88Jeepster
Who's in front ?
Wif is offline
post #8 of 12 Old 11-12-2008, 12:44 PM Thread Starter
peeweeXJ
That doesn't sound like a normal condition to me? Key words like low, starvation, incorrect, faulty.
peeweeXJ is offline
post #9 of 12 Old 11-12-2008, 01:09 PM
Wif
Wif's Avatar
Normal doesn't mean correct .. most of the 4.0's do it. I was giving you examples of what can exaggerate the problem.
I'll wait for someone else to jump in here ..
Formally 88Jeepster
Who's in front ?
Wif is offline
post #10 of 12 Old 11-12-2008, 01:16 PM
grinwa
grinwa's Avatar
Is it possible you have an exhaust leak? Check for one. If it get louder under a load and less when coasting, it could be an exhaust leak. That could cause problems with the O2 sensor, too.
'99 TJ
Experience is something you don't get until just after you need it.
grinwa is offline
post #11 of 12 Old 11-12-2008, 01:35 PM Thread Starter
peeweeXJ
I have thought about an exhaust leak, but I checked as good as I could visually, and tried to tighten all the bolts that I could. They were all good n' tight. I'll go check again.
BTW- I ran it with the IAC unplugged and it made no difference. Still idled high, and tried to come down but stumbles.
peeweeXJ is offline
post #12 of 12 Old 11-12-2008, 02:25 PM Thread Starter
peeweeXJ
Haha, well I believe to have found my ticking problem. Had my stethescope out and was scoping around the engine. Could not tell where the ticking was coming from. Put my hand on the EVAP purge solenoid, and hole e crap does it ever tick. Could it actually be the really loud thing I hear when I start it up on cold mornings (4-6 LOUD ticks)?
Anyhow- Still not sure on the high idle/slight stumble. Seems like a rough spot, not exactly stumbling.
Thanks
peeweeXJ is offline
Low Idle Cold, High Idle Warm Lon33 YJ Wrangler Technical Forum 13 10-29-2014 10:24 PM
Rough Idle when cold firefighter1 TJ Wrangler Technical Forum 1 04-22-2013 09:25 PM
Rough Idle when Cold Titleistprov21 TJ Wrangler Technical Forum 3 11-05-2009 11:54 AM
Rough Idle on Cold Start rugbynut YJ Wrangler Technical Forum 15 03-13-2008 01:37 PM
Rough cold idle ckcarr TJ Wrangler Technical Forum 1 11-10-2004 04:45 AM
