2001 top on a 97? - JeepForum.com
post #1 of 10 Old 07-09-2006, 01:46 PM Thread Starter
buckydano
2001 top on a 97?
Will a 2001 top fit on a 97? I need to replace my top, and someone has one for sale locally. I know this has been answered before, but I can't find the thread.
buckydano is offline
post #2 of 10 Old 07-09-2006, 01:48 PM
Rocky529
Rocky529's Avatar
Yes, it will fit.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 10 Old 07-09-2006, 01:51 PM Thread Starter
buckydano
Do I have to use the hardware from one top on the other or is it all the same?
post #4 of 10 Old 07-09-2006, 01:59 PM
buddastrat
I'm wondering if an '06 top will fit on a '98?
buddastrat is offline
post #5 of 10 Old 07-09-2006, 02:12 PM
Rocky529
Rocky529's Avatar
It will fit, all of the hardware is interchangeable from year to year. The only think you have to watch out for is the top itself and the windows. In 2003, the male/female ends changed location, therefore you won't be able to zip your windows in. As long as it is a COMPLETE top (soft top and windows), then you are ok. The hardware is the same from '97-'06.
Rocky529 is offline
post #6 of 10 Old 07-09-2006, 03:39 PM
Raxmar
The early 97 (manufactured in late 96-Jan 97) Wranglers used different hardware at the tailgate from subsequent models. I found that out after purchasing a soft top from an 00 Wrangler. There are two exterior brackets which mount to each side of the tailgate, and the retaining bracket that holds the top into the two exterior brackets is different than newer models.
Raxmar is offline
post #7 of 10 Old 07-09-2006, 06:03 PM
ncb76
ncb76's Avatar
True. I ran into the same problem, but the old bar worked with the newer top. They both attached the same way.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #8 of 10 Old 07-09-2006, 08:23 PM
Raxmar
I was converting from a hardtop to a soft top, so I did not have any retainer bar. The retainer bar that came with the newer top will not fit in the exterior brackets of the early 97 Wrangler. JeepWorld.com lists the early 97 retainer bar as a different part than later editions.
Raxmar is offline
post #9 of 10 Old 07-11-2006, 01:25 AM Thread Starter
buckydano
thanks for all the info! it was one of the first off the line so i'm guessing it has the old style retainer.
post #10 of 10 Old 07-11-2006, 07:33 PM Thread Starter
buckydano
Took a look at the top - she wants $320 and there is a broken tooth in the back window zipper. Apparently the top was only on for summers, which are pretty short here, so she is going to use the hard top year round. I offered $150, and she laughed, so I left. She said "At $150, I'd be giving it away". This is the same person who was trying to sell this jeep, a 2001 Sahara with 70,000 miles, for $17,000
RB1 in a 2001? 79CHKCHK TJ Wrangler Technical Forum 4 05-09-2009 07:04 PM
2001 2.5 tj tjbuckeye TJ Wrangler Technical Forum 1 01-26-2008 07:36 PM
2001 TJ SE value? exc911ence TJ Wrangler Technical Forum 25 07-18-2004 03:57 AM
2001 Tj FutureJeepOwner TJ Wrangler Technical Forum 1 07-06-2004 08:59 PM
2001 se DrewC2333 TJ Wrangler Technical Forum 2 03-14-2002 03:25 PM
