2001 TJ Wont Start - JeepForum.com
post #1 of 21 Old 07-19-2011, 09:47 PM Thread Starter
mauch1
2001 TJ Wont Start
For the past few weeks my Jeep has been having some issues starting. When i turn the key nothing happens. I can hear a click sound in my steering column and another click that sounds like its coming from the interior fuse box or close to it. When it first happened i would try it a couple times and then my starter would go and it would start no problem. The past couple days though its started in the morning but when i go out after work it wont start. I have to get push-started.
So far ive changed some relays around to see if it was that but it didnt make a differance. I took my starter in to be tested and everything tested out ok there. Ive tried to cross the two bolts to get the starter to manually engage but it just spins and wont turn over the engine. I have yet to check the neutral start switch or the ignition switch but i was curious if anyone else has had this problem. Seems to happen mostly when its hot outside (lately its been 100 degrees here).
Any advice would be much appreciated. Thanks everyone!
PS: my jeep has the 2.5L in it if that makes any differance.
mauch1 is offline
post #2 of 21 Old 07-19-2011, 09:55 PM
alex211
1995 XJ Cherokee
You need a starter if it spins without engaging to the flywheel/flexplate.
95 xj bone stock for now
alex211 is offline
post #3 of 21 Old 07-20-2011, 06:20 AM Thread Starter
mauch1
Yeah, but it only does that if i use a screw driver on the solenoid. It never happens if it actually works when i turn the key and ive never had it not engage on the flywheel when i use the key. My problem is that the majority of the time the starter wont do anything when i turn the key. All i get is one click every time i turn the key. Seems to do it mostly when its hot outside or after i have driven it. Ive tried givin it a few smacks with a tire iron but that didnt do much either lol. But the starter seems to work just fine whenever it actually decides to turn over. So im stumped. Like i said in my previous post i have yet to check the neutral start switch or the ignition switch and ive checked everything else.
mauch1 is offline
post #4 of 21 Old 07-20-2011, 09:23 PM Thread Starter
mauch1
Well, 4 hours of checking fuses, checking to see if i had power and chasing wires we find that the little arm that turns the ignition switch broke so its not turning my ignition switch all the way to start my engine. Anyone have any ideas as to where i can obtain one of these parts without going to the dealer? the parts store doesnt have anything and no junk yards around here have any wranglers in them. Anyone know maybe what other jeeps use this system so maybe i can find another jeep in the junk yard i can steal parts from? Any help would be great. Thanks
Here are a couple pics of the part:
mauch1 is offline
post #5 of 21 Old 07-20-2011, 09:33 PM
merkchop
Is it in your key lock cylinder that is broken (can't really make out the pics good on this computer). If it is Summit Racing sells the cylinder for $50. I will attach a link to it, in case it is, that shows other vehicles that use the same one.
http://www.summitracing.com/parts/RN...ry=Make%7cJEEP
merkchop is offline
post #6 of 21 Old 07-20-2011, 09:51 PM
Cuder
I have been there and done this. That POS pot metal rod breaks on alot of Jeeps. You can get one off of alot of Dodges and Chryslers. I got one off a Cherokee. Here is another thread about it, and in my post in it there is a few more threads I posted about the problem.
http://www.jeepforum.com/forum/f9/je...start-1228196/
My Build Thread:
Cuder is offline
post #7 of 21 Old 07-21-2011, 07:35 PM Thread Starter
mauch1
Can any of you guys tell me what the little brown colored rod in the pic is for?
mauch1 is offline
post #8 of 21 Old 07-22-2011, 09:48 PM
Cuder
I think the brown rod is what pushes the buzzer switch inside the ignition switch to tell you the keys are inserted when you open the doors. On some of the assemblies of different models that plastic rod is white.
My Build Thread:
Cuder is offline
post #9 of 21 Old 07-23-2011, 08:20 AM Thread Starter
mauch1
Fantastic, thanks a lot Cuder, you have been a lot of help during this whole mess
mauch1 is offline
post #10 of 21 Old 07-23-2011, 01:47 PM Thread Starter
mauch1
Well, finally made it to the junk yard this morning and pulled this part out of a couple of cars in a matter of 15 mins . One was a 98 Dodge Stratus and the other was a 2000 Sebring i believe.
Thanks for all the help guys, you saved me a lot of $$$!
mauch1 is offline
post #11 of 21 Old 07-23-2011, 07:07 PM
Spaceball
Thank you so much mauch1 for posting this! I've been having the SAME EXACT issues for the last week. Been push starting in the late afternoons when it's hot. Took my ignition switch off and that little pot metal piece was broken the same as in your pics. Tomorrow it's off to the wrecking yards! I'm assuming I'll have to take the ign cyl out to get that thing out?
This forum is awesome, I just found it a few days ago after trouble free Jeepness for 11 years.......... "major" trouble I should say ha!
Spaceball is offline
post #12 of 21 Old 07-24-2011, 07:26 AM Thread Starter
mauch1
Good to hear it helped . But yeah i removed the ignition switch first and to remove the key switch on the other side i just used a vice grips and turned it like you would be turning it to accessory until i heard kind of a snapping and after that you can turn that key switch to any position so just turn it to the on position and push in that little push button on the bottom and it comes right out. To get the actual "ignition switch pin" there is just two tamper proof screws holding it to the steering column, same set up really as on your jeep. Needless to say i wasnt too gentle on the junk yard cars lol. But i got the piece i needed everytime
mauch1 is offline
post #13 of 21 Old 07-24-2011, 07:42 AM
Cuder
That's why I'm a JF supporter. I like helping people and I can do it from my recliner.
I found this site searching why my A/C blower wouldn't work. I found all the info I needed pretty fast because Jeep people had posted their problem and fixes.
I have learned alot the last 2 years and had some good laughs reading the BS in the general section.
My Build Thread:
Cuder is offline
post #14 of 21 Old 07-24-2011, 05:04 PM
Spaceball
Thanks for the great info cuder and mauch1 ! I made a run to the boneyard this morning, and pulled one of those parts out of a 00 Caravan, got it home, but it was a little different, it had an extra little arm on it. I sawed the little arm off and filed it down, installed it, and woops! Let's just say, make sure the one you get looks exactly like the old one, lol. Went back to boneyard took two out of 97 and 99 Neons. Keeping a spare! Neons have the same part, the Caravan is definately different.
Everything is just fine now!
Thanks fellas!
post #15 of 21 Old 07-24-2011, 09:37 PM Thread Starter
mauch1
Yeah, i run around Ford Forums all the time and i got to thinkin, there has to be a jeep forums too and sure enough, here it is lol. But yeah, i learn a lot and throw in my 2 cents if i have anything worth sayin.
Good to hear Spaceball, i know i was pretty excited to get my jeep goin again too lol.
mauch1 is offline
battery , ignition , ignition pin , solenoid , starter
2001 Jeep TJ 4.0 turns over but wont start. MOTOWNTJ TJ Wrangler Technical Forum 6 05-13-2015 01:36 PM
jeep wont stay running, now wont start 89General YJ Wrangler Technical Forum 5 02-11-2011 06:57 AM
HELP!! 2001 Wrangler wont start! adrianmartin TJ Wrangler Technical Forum 6 07-06-2010 10:11 AM
Jump start = Volt Meter spikes while driving then wont start AWILD TJ Wrangler Technical Forum 5 02-21-2010 06:37 PM
Starts, Idles, Dies, Wont Start, Wont Start, Pump Pedal, Starts... REPEAT inniett YJ Wrangler Technical Forum 2 04-08-2009 05:13 PM
