2001 TJ Fog Lights - JeepForum.com
post #1 of 5 Old 09-30-2011, 09:34 AM Thread Starter
MPT125
2001 TJ Fog Lights
Here is another question for the experts out there. This jeeps does not currently have fog lights however it has the multifunction (turn signal) stalk WITH fog lights. So I looked up front to see if there was any wiring near where fog lights would be mounted and there are what look like extra connectors bundled up out of the way in each fender where the running/parking (orange) lights are. Is it safe to assume this is the hookup for the fog lights?
MPT125 is offline
post #2 of 5 Old 09-30-2011, 09:44 AM
biffgnar
biffgnar's Avatar
Yep
Romney in 2020!
biffgnar is offline
post #3 of 5 Old 10-02-2011, 08:31 AM
chucktoons
should be easy to confirm with a volt meter or test light
chucktoons is offline
post #4 of 5 Old 10-02-2011, 01:58 PM
hughes278
they are, you are correct
hughes278 is offline
post #5 of 5 Old 10-02-2011, 02:02 PM
Jeffro06
Jeffro06's Avatar
KC makes a set that plug right in.
Jeffro06 is offline
Post 2001 to pre 2001 manifold swap ? wayfastwhitey44 TJ Wrangler Technical Forum 6 12-05-2010 01:55 PM
2001 wrangler sport factory driving lights jack1018 TJ Wrangler Technical Forum 2 04-06-2010 01:28 PM
2001 2.5L - No Brake Lights, Keeps Blowing Fuses JoshMD TJ Wrangler Technical Forum 0 06-03-2009 10:51 PM
dash lights out on my 2001 wrangler! 4Scott4 TJ Wrangler Technical Forum 6 03-18-2008 07:35 AM
Area lights = Fog lights? Directional lights = driving lights? Marn TJ Wrangler Technical Forum 2 07-10-2006 01:46 AM
