2001 Jeep TJ alternator upgrade help. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2001 Jeep TJ alternator upgrade help.
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 08-29-2010, 04:48 PM   #1
Canfourjeep
I have a 2001 Jeep TJ with a 4.0 engine. I am looking for an alternator upgrade for it. The alternator sits up high on the passenger side and has the top bracket offdet almost to the muddle of the alternator. The alternator from a 99 Grand Cherokee will not bolt on as the bracket positions are not right. Anyone made this change? If so what alternator did you use?
Canfourjeep is offline   Reply With Quote Quick reply to this message
Unread 08-29-2010, 06:50 PM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I used one out of a 2000 JGC, It bolted right in...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 08-29-2010, 09:16 PM   #3
Guardian7
Good upgrade article, see link;
BC4x4.COM four wheel drive, 4x4, offroad and fourwheeling site.
Guardian7 is offline   Reply With Quote Quick reply to this message
Unread 08-29-2010, 10:07 PM   #4
Canfourjeep
If you look at the alternators in the BC article they are totally different
The alternators in the article are like the 99 Grand Cherokee and are totally different from my 2001 TJ. The one I have the top anchor point is offset about 2 inches towards the middle. Also the reply that you used a 2000 Grand Cherokee what year TJ did you put it in?
Unread 08-29-2010, 10:30 PM   #5
Guardian7
Jeep moved the alternator up higher in 2000 and used P/N 56041685AA
I would do some more research on the P/N:56041693AC or P/N:56029914AA, I hear there is an extra bracket on the 160A model which your don't use but it still bolts up.
136 amp alternator*:
1996-1998 Dodge B.Series Van - (PN:56027913 Reman:R6027913)
1996-1998 Dodge Dakota 3.9L, 4.7L, 5.9L - (PN:56027913 Reman:R6027913)
1998-2000 Dodge Dakota - (PN:56027913AB Reman:R6027913AC)
2003-2005 Dodge Dakota 3.9L, 4.7L, 5.9L - (PN:56041693AC Reman:R6041693AC)
1998-1999 Dodge Durango - (PN:56027913 Reman:R6027913)
1996-1998 Dodge Ram Pickup - (PN:56027913 Reman:R6027913)
1998-2000 Dodge Ram Pickup - (PN:56027913AB Reman:R6027913AC)
1991-1998 Jeep Grand Cherokee - (PN:56005685 Reman:R6005685)
2000 Jeep Grand Cherokee 4.7L - (PN:56041324AC Reman:R6041324AC)
2001-2005 Jeep Grand Cherokee 3.9L, 4.7L, 5.9L - (PN:56041693AC Reman:R6041693AC)
150 amp alternator*:
1993-1998 Jeep Grand Cherokee - (PN:56041394AA Reman:R6041394AA)
160 amp alternator*:
2001-2005 Dodge Dakota - (PN:56029914AA Reman:R6029914AA)
2001-2005 Dodge B.Series Van - (PN:56029914AA Reman:R6029914AA)
Unread 08-30-2010, 06:25 AM   #6
Knuckelhead
AFSOC Retired
A 2000 Sport...
Unread 08-30-2010, 11:45 AM   #7
Canfourjeep
Jeep Alternator
The original factory alternator number is 56041864AA. Bottom Brackets are 2 5/8 inches between them. Sitting on it's side on the floor, the top bracket touches the floor and the bottom brackets touch the floor at the same time. My top bracket is broken so I wanted to upgrade when buying another one.
The one from the 99 Grand Cherokee i have are straight across from each other, and about 1/2 inch closer together.
I just wanted an upgrade ,higher amp to install a winch.
Thanks
Unread 08-30-2010, 12:33 PM   #8
nwiTJdave
Thank you for that link. I knew that certain models were very able to bolt in and that sums it up nicely.
www.militaryjeepers.com
This is for fighting, this is for fun.
nwiTJdave is offline   Reply With Quote Quick reply to this message
alternator , upgrade
