2001 Jeep TJ 4.0 turns over but wont start. - JeepForum.com
post #1 of 7 Old 02-08-2011, 09:54 AM Thread Starter
MOTOWNTJ
My 2001 TJ turns over but will not start and run. Replaced the crank shaft positioning sensor and still nothing. Just topped off fuel before this started. When I turn the key on I no longer hear the fuel pump kick on. Checked fuses and relays they seem fine. Check the valve on the fuel line near the injector and no fuel comes out. Is there anythig else I should check before i go digging into the fuel tank to replace the fuel pump.
MOTOWNTJ is offline
post #2 of 7 Old 02-08-2011, 10:15 AM
j_niko
2009 JK Wrangler
Check to make sure there is voltage getting to the fuel pump.
2000 - Sahara
1997 - Sahara
j_niko is offline
post #3 of 7 Old 02-08-2011, 10:18 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Check for spark.
When spark is not present, the fuel pump will eventually be cut off.
Wheelin98TJ is offline
post #4 of 7 Old 03-14-2011, 11:00 AM Thread Starter
MOTOWNTJ
I have left the jeep sit a while. I just recently started to work it again. I jumped a wire from the fuse box under the hood at the fuel pump relay and the fuel pump kicks on and sends fuel to the fuel rail. However I am not getting any spark at the coil rail. I have replaced the crank shaft positioning senor and cam shaft positing senor. Do any of you think that the coil rail is bad or posibly the computer. I dont know what else could to check. I hooked the jeep up ot an OBD II scanner and it will not show any codes, just "no link." All my connctions look clean and no wires that i have found seem to be broke or exposed.
MOTOWNTJ is offline
post #5 of 7 Old 03-25-2011, 11:42 AM Thread Starter
MOTOWNTJ
Replaced the ingnition coil and still nothing, so I guess Iam going to further check all the wiring under the hood for any damage. If that does not turn up anything i guess its off to the dealership for diagnostic. Any other input would be appreciated.
MOTOWNTJ is offline
post #6 of 7 Old 05-06-2011, 05:20 PM
jkretzer
any results, i am having the same issue right now? thanks
jkretzer is offline
post #7 of 7 Old 05-13-2015, 12:36 PM
jeppmatt
any info?
having a similiar issue
will rank, got fuel pressure, assume no spark, with coil packs how to check, any ideas?
jeppmatt is offline
Yj turns over but wont start raymknuth YJ Wrangler Technical Forum 15 03-13-2014 03:40 PM
engine turns over but wont start silverwater TJ Wrangler Technical Forum 6 03-24-2011 09:10 PM
93 2.5 turns over wont start tilemike YJ Wrangler Technical Forum 0 04-11-2010 02:36 PM
Jeep died while driving, turns but wont start vtjeepguy97 Wrangler General Discussion 3 12-28-2008 10:45 AM
jeep turns over but wont start?? Goondock TJ Wrangler Technical Forum 3 10-10-2007 08:01 AM
