2000 wrangler wont idle - JeepForum.com
post #1 of 9 Old 09-22-2010, 10:28 AM Thread Starter
babybrudder
need help 2000 sat for a couple weeks and now wont idle....starts and runs with my foot on the accel but no idle. i was wondering if theres a sensor that controls the idle??? and if so where it may be located???
babybrudder is offline
post #2 of 9 Old 09-22-2010, 11:13 AM
pfifer
The IAC, which is the Idle Air Control Valve's probably your problem..if its not that sensor going bad, it could be your TPS or Throttle Positioning Sensor. Is it throwing any codes?
pfifer is offline
post #3 of 9 Old 09-22-2010, 11:16 AM
canyon47
Did the battery die? I had this happen to me a few times after I completely killed the battery. I had to drive it for a while very carefully until the battery had enough charge to hold an idle.
canyon47 is offline
post #4 of 9 Old 09-22-2010, 11:56 AM Thread Starter
babybrudder
yes the battery did die...i left the lights on and did not know it for several days, but i did recharge it completly and still no idle.
have not checked codes yet (waiting for my son to bring the reader over).will repost as soon as i read the codes.
post #5 of 9 Old 09-22-2010, 12:35 PM
DevilDogDoc
If you charged and it won't idle the battery is probably bad. The Jeep needs a good strong battery to idle right. Take the battery for testing and I'll bet it's crap.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #6 of 9 Old 09-22-2010, 12:52 PM Thread Starter
babybrudder
yea your probably right , the battery is goung on 3 years, ill change it soon as i get some time off work and then run the codes and keep evryone informed of the progress.
post #7 of 9 Old 09-22-2010, 01:32 PM
Bills03tj
1992 XJ Cherokee
A lot of Chrysler built vehicles need to relearn idle after a battery dies or is replaced. Start it up and slowly take your foot off the gas pedal and try to keep it running. I've seen them sit and idle for up too 30 min before the idle starts acting normal. If you have ac, make sure it's off.
Bills03tj is offline
post #8 of 9 Old 10-06-2010, 08:13 PM Thread Starter
babybrudder
just wanted to let everyone know it was the battery...thanx again for all the help.
post #9 of 9 Old 10-06-2010, 08:42 PM
fishinjeeper
try cleaning your TPS. Battery is a good idea also
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
wont idle unless I shim against the idle actuator rain-gler YJ Wrangler Technical Forum 7 07-23-2010 07:04 AM
4.0 wont idle and wont rev above 3000 rpms millersjeeps TJ Wrangler Technical Forum 4 01-15-2009 07:23 PM
1990 Wrangler 258 6 cylinder...will crank but wont idle blakecampbell72 YJ Wrangler Technical Forum 10 11-06-2008 02:27 PM
2001 wrangler wont idle? harleymikemo TJ Wrangler Technical Forum 3 12-15-2007 04:05 AM
Using a Soft-Top From a 2000 Wrangler on a 1998 Wrangler? Nighthawk TJ Wrangler Technical Forum 3 06-05-2002 05:02 PM
