2000 Wrangler Altinator replacemnt problem - JeepForum.com
post #1 of 4 Old 01-25-2014, 01:44 PM Thread Starter
ArtWirgau
I just replaced the alternator in my 2000 Wrangler. After I was finished I got in and started it. Started right up. Then the check engine light came on so I shut it off & opened the hood and noticed that I had not plugged the sensor in that is above the belt tension screw. So, I plugged it in and tried to restate it. NOTHING???? Anyone have any thoughts?
ArtWirgau is offline
post #2 of 4 Old 01-25-2014, 01:46 PM
wwch99tj
Check your battery connections
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #3 of 4 Old 01-25-2014, 08:07 PM
JStMarie
JStMarie's Avatar
Not starting is probably not related to replacing the sensor plug. I assume it was the temp sensor on the thermostat?
It is more likely the vibration of the engine when you first started it caused a bad connection or you blew a fuse.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
post #4 of 4 Old 02-01-2014, 06:50 AM
JStMarie
JStMarie's Avatar
JSt.Marie
JStMarie is offline
