2000 TJ w/ Rough Country 4" Lift, 2" Spacers, 35" MT BAJA MTZs - JeepForum.com
post #1 of 23 Old 02-04-2011, 07:42 PM Thread Starter
roughskinjrz
Hey just wanted to share that last weekend i installed a 4" Rough Country lift with 2" Spacers. I also put on Bar Pin Eliminators, Shock Relocation Kit, Slip Yoke Eliminator, CV Driveshaft ( VERY NICE ), 2.2 Shock Upgrade, 2.2 Steering Stabilizer, and 35x12.50x15 Mickey Thompson BAJA MTZ's.
The 35" Tires would not have fit my jeep without the spacers, but because of the spacers i had to drill holes in different locations for the panhard bar in the back on the new track bar relocation bracket, just widened it a bit, the front track bar it said i had to drill a hole 3/4" from the stock hole, but it ended up being further away obiously.
Also the shifter bracket i had to use with the kit was kinda ****ty had to custom fix that because i couldnt get into the lower gears, and at first couldnt get into Neutral or 4 LOW on the 4x4 lever but fixed that. Here is a picture of my jeep now i think it looks great.
roughskinjrz is offline
post #2 of 23 Old 02-04-2011, 07:47 PM
viperbluelx
35's work with 4" of lift pretty easily.
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #3 of 23 Old 02-04-2011, 07:50 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Install an adjustable track bar...IMO
Knuckelhead is offline
post #4 of 23 Old 02-04-2011, 07:54 PM
Imped
Imped's Avatar
6" of lift on short arms? Great idea. What do you mean the tires wouldn't have fit without the spacers? You would have more than enough room with 4" springs. Your wheelbase is sorely lacking and you look awkwardly tall. What's your question?
OlllllllO
IndyORV
Imped is offline
post #5 of 23 Old 02-04-2011, 07:54 PM Thread Starter
roughskinjrz
i didnt think about an adjustable track bar until i was at that part of the job, i asked around on the site and noone really recommended it but i might buy one now.
and for the 35s with my fender flares they wouldnt fit i tried so i just put the spacers on.
post #6 of 23 Old 02-04-2011, 07:57 PM
2006_Sport
Imped above you is running 35s on much less lift than you and they fit fine. The fit before he did his hi-line too when he was running the RC 2.5 and 1.25 inch BL on stock fenders with trimmed flares. Hell, my bud Tony (flatlander757) is running 40s on 4.5 inches of lift....but that's a COMPLETELY different story
Ditch the spacers man, you'll be a little happier.
2006_Sport is offline
post #7 of 23 Old 02-04-2011, 08:17 PM Thread Starter
roughskinjrz
yeah i dont like the spacers idea much, i just installed them cuz when i cut the wheel the tires were hitting the fender flares which i didnt like, so i slapped them in. but maybe ill take them out and try again when i have more time.
Imped you dont have to be a donkey i was just sharing, if you read what i wrote my question or statement had nothing to do about what my wheel base looked like or how akwardly tall it looks. your telling me noone else jeep looks the same as mine, or you just feeling like a donkey tonight.
post #8 of 23 Old 02-04-2011, 08:20 PM
Imped
Imped's Avatar
So.what's your question? You're right, I'm a donkey.
OlllllllO
IndyORV
Imped is offline
post #9 of 23 Old 02-04-2011, 08:25 PM
viperbluelx
At ride height the 35's were hitting your flares with just the 4" springs? Something doesn't sound right.
post #10 of 23 Old 02-04-2011, 08:26 PM
2006_Sport
He has a rough country kit...remember?
post #11 of 23 Old 02-04-2011, 08:28 PM
Imped
Imped's Avatar
That certainly wasn't the case. It sounds like he needs to learn about bump stops.
OlllllllO
IndyORV
Imped is offline
post #12 of 23 Old 02-04-2011, 08:31 PM Thread Starter
roughskinjrz
Another problem, if i knew the kit was gonna give me the trouble it did i wouldnt have went with it, but i heard alot of good things about their kit on this site. It rides rough but nothing i didnt expect, i really like the slip yoke eliminator and the cv driveshaft those parts looks top notch.
I think i'll take out the spacers though and just run the kit, because i guess it does look akwardly tall like Sped said, maybe the front drag link will fit right and the rear panhard bar. I thought the 35's would fit no problems but maybe i was just too tired to see what was really going on, I'll try this again in a few weeks i just wanted to share about 13 hours of work that i put into this thing.
post #13 of 23 Old 02-04-2011, 08:33 PM
viperbluelx
Running 6" of lift on a short arm is going to ride rough regardless of what brand the lift is. The geometry is screwed. Remove the 2" spacers and just run the 4" springs. You'll probably need 2.5-3" of bump stop in the front and around 2" in the rear to keep the tires from hitting the fenders when flexing.
post #14 of 23 Old 02-04-2011, 08:50 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Well, take it easy on him, he has no idea what bumpstop extensions are, what coil bind is, what shock length is supposed to be, or what suspension geometry means
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #15 of 23 Old 02-04-2011, 09:01 PM
EricsGreen98Tj
It sits too high in the back man. Mabey ditch the rear 2" spacer and put a 3/4" one on instead? that would probably level it up.
OR, take all the 2" spacers out and put some 3/4" spacers in just the front to eliminate the rake.
Buy YES 6" of lift is ALOT for short arms.
BTW: Way to go man! Its good to see someone proud of the work they put into their ride. Experience with a wrench and ratchet is irreplacable. Now you just need to "fine tune it" a bit
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
Anybodry running the Rough Country 2.5" lift with .75" spacers front and rear? viperbluelx TJ Wrangler Technical Forum 5 01-26-2011 05:05 PM
Have a rough country 4" lift with da "gangsta lean" jeepguy85 YJ Wrangler Technical Forum 19 05-25-2010 07:11 AM
Rough Country 2.5" spring & 3/4" spacers extended sway bar links? drewtj05 TJ Wrangler Technical Forum 24 11-04-2009 01:18 PM
Rough country 6" lift or 4" with 2" BL? RockinJK YJ Wrangler Technical Forum 4 06-30-2008 06:30 PM
4" rough country w/ 2" spacers????? tjwhlr00 TJ Wrangler Technical Forum 17 11-07-2006 11:58 PM
