2000 TJ oil pressure sensor - JeepForum.com
post #1 of 6 Old 08-26-2011, 02:31 PM Thread Starter
KKimble
Where is the oil pressure sensor/how do you change it on a 4.0? I was told it was right beside the oil filter but am not quite sure how to remove/replace it. Thanks!
KKimble is offline
post #2 of 6 Old 08-26-2011, 02:36 PM
purplepig
there should be an electrical connector to unplug and the sensor just unscrews
purplepig is offline
post #3 of 6 Old 08-26-2011, 02:37 PM
little_Jeep
This what it looks like on my 2000 WJ with the 4.0L
little_Jeep is offline
post #4 of 6 Old 08-26-2011, 02:40 PM
purplepig
^^^^^ looks the same on the TJ
post #5 of 6 Old 08-26-2011, 02:42 PM Thread Starter
KKimble
So it's right beside the oil filter? My friend looked at it and said it was close to the ground? :S
KKimble is offline
post #6 of 6 Old 08-26-2011, 02:56 PM
plowboy1970
plowboy1970 is offline
Need Help with 2000 Wrangler I6 02 sensor Wishmaster22 TJ Wrangler Technical Forum 15 08-22-2010 02:05 PM
2000 TJ Cam sensor baldeagle1 TJ Wrangler Technical Forum 5 05-10-2010 02:33 PM
2000 tj with o2 sensor question BigBlackTJ2010 TJ Wrangler Technical Forum 2 04-19-2010 04:23 PM
2000 Cam sensor in a 98 motor ... HELP! mxracer513 TJ Wrangler Technical Forum 10 10-19-2008 06:50 PM
2000 TJ exhaust/O2 sensor complications FloridaTJ TJ Wrangler Technical Forum 6 09-20-2008 11:01 AM
