2000 TJ nightmare!!! HELP - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2000 TJ nightmare!!! HELP
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Ring & Pinion's, Lockers, 4340 Axles, Install Kits, Ba~Artec JK 1 TON SWAP~
Unread 03-29-2014, 03:06 PM   #1
hickamwrangler8
alright so here is where im at... i recently suffered from the cylinder head crack on my jeep. i was experiencing overheating and low oil pressure. so i bought new cylinder head, new lifters, new push rods, new rocker arms, new radiator, and a new oil pressure switch. i got everything put back together and running today and i am still experiencing oil pressure issues. im out of options. not sure what else to do and im loosing my mind trying to figure this stuff out on my own. any ideas?
hickamwrangler8 is offline   Reply With Quote Quick reply to this message
Unread 03-29-2014, 03:11 PM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
How long was the motor run with the cracked head ? Coolant in the oil is harmful to the bearings and crankshaft.
If a mechanical oil gauge confirms low oil pressure, you can either drive it till it dies, swap in another used or new motor, or rebuild the motor you have.
Between 2009 when Obama took office, and 2013, median annual household incomes have fallen by more than $2,100.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 03-29-2014, 04:47 PM   #3
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Yep check with a mechanical. You might have very well needed too have rebuilt the bottom end also...
GOLENJEEPTJ is offline   Reply With Quote Quick reply to this message
Unread 03-29-2014, 05:20 PM   #4
hickamwrangler8
well i bought a cheep mechanical oil pressure gauge and still no luck. there probably isnt a chance in hell that im going to tear the whole thing apart again. im sooo upside down with this jeep that i feel like i might have to just leave the jeep family.... idk.... im out of options
Unread 03-29-2014, 05:39 PM   #5
JBTJ
JEEPer For Life
JBTJ's Avatar
You may need to rebuild the whole engine, not just half of it. Oil pump is probably bad. No need to leave th JEEP family, this can happen with any engine. Remember don't run the engine if it's too hot.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 03-30-2014, 07:35 AM   #6
ckspeed
Yup, bottom end is either shot or the oil pump is weak, or both.
How low is it? At idle and driving, say...2500rpm?
I had a 97 w/4cyl that had nearly 0 psi at idle and maybe 10-12 at rpm and I drove it for well over a year like that. I used a heavier oil, 15w40 as I recall, and that helped some.
ckspeed is offline   Reply With Quote Quick reply to this message
Unread 03-30-2014, 08:33 AM   #7
JStMarie
JStMarie's Avatar
Do you have any other symptoms other than the pressure gauge saying your oil pressure is low? Knocking? Burning smell?
You don't need much pressure for your engine to continue to run just fine, but you do need some pressure (obviously). The next step at this point is to make sure your oil pump is working properly and that you have a proper oil filter in place as I've heard (and experienced) these can sometimes cause low oil pressure.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline   Reply With Quote Quick reply to this message
Unread 03-30-2014, 11:45 AM   #8
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
That's why I'll never buy another 2000-2001 4.0L Jeep unless it's stamped tupy.My 2000 XJ cracked the head but didn't overheat or run bad.Coolant just vanished every couple of weeks and none was in the oil.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 03-30-2014, 03:42 PM   #9
hickamwrangler8
Well I'm not taking the engine apart again, I'm in the military and seldom do I get time off. I had to take a week of leave just to rebuild the top end. Ill probably take tje bottom pan off and check out the pump, if I see any issues with it ill replace it if not, ill drive her till she blows the jeeps only worth 7-8k and I've dumped well over 14k in it. I'm tired of dumping money into something that my wife doesn't even want me to have.
Unread 03-30-2014, 04:55 PM   #10
McLovin
Someone asked above, what is the oil pressure like at idle, and at 2500 rpms? Is it just low oil pressure or are you having other issues like coolant, poor running, burning oil?
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline   Reply With Quote Quick reply to this message
Unread 03-31-2014, 05:30 AM   #11
finsout
Im fairly sure your bottom end is toast. Had the exact same problem as you. Got a long block.
finsout is offline   Reply With Quote Quick reply to this message
Unread 04-01-2014, 07:40 PM   #12
hickamwrangler8
well when i first start it up my oil pressure is great, between 30-40psi. when she warms up its around 12psi at 2100RMPs and at idle its around 4-6psi. its not smoking, knocking or anything, just low oil pressure... i plan on dropping the pan tomorrow after work and taking the oil pump out and seeing how it looks. when i rebuilt the top end there was quite a bit of sludge so im assuming that as it was ok in the beggining and just got lower and lower as time went on im thinking/hope that there is just sludge in the pump so im going to take a look at it and ill let you guys know what i find out after tomorrow.... wish me luck
Unread 04-01-2014, 10:29 PM   #13
Stu Olson
Stu Olson's Avatar
Good luck....hoping it just the pump.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote Quick reply to this message
