-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   2000 TJ leaning to the right? (http://www.jeepforum.com/forum/f9/2000-tj-leaning-right-1556576/)
wheelie387a 08-01-2013 12:41 PM
My new TJ(history since new) im 2nd owner, never wrecked never wheeled..... The Jeep was 3/4" lower in the right front than left so I assumed weak spring on that side (95 k miles).... But yesterday I installed a RC 2.50 lift kit , and when done remeasured all corners ( all went up 3")... So yes , now the right front is still 3/4" lower than the left... Any ideas what to look for. Its pretty obvious when looking at it ....
Moezer 08-01-2013 01:34 PM
look at your sway bar it might be bent or something, I know when I take my swaybar links off when I off road the jeep sinks about an inch or lower
czebley24 08-01-2013 01:39 PM
It is probably your sway bar.
wheelie387a 08-01-2013 01:53 PM
Bent??? One end lower than other?? I guess i could disconnect it and see if it levels up ...?
Sixbanga 08-01-2013 01:53 PM
I doubt the sway bar is bent enough to cause a problem but anything is possible.
You need to make sure you are parked on perfectly level ground. If it is not level and the slab it tilted to drain as most are it will weight that side of the jeep.
Look at the rubber fender to frame snubbers. Are they both touching the frame? Is one not touching or preloaded? Thats where my jeep is bent, one fender is a little higher and the grill sits crooked from a accident.
Iirc some rc lifts use left and right coil springs to fight settling after time.
Then measure to several diferent spots on both sides of the jeep. You are trying to find out where the difference is. Measure from the ground to each spring pad, if they are the same to the top spring pad. Keep doing this until you find the difference.
tyvanwie 08-01-2013 01:57 PM
Did you replace the shocks as well?
wheelie387a 08-01-2013 01:59 PM
Shop floor is perfectly level, so no issue there, nothing bent from any kind of wreck, RC says both springs identical ( and it was the same with factory shocks) , so I will check sway bar as well as fender itself , might have dropped or raised on one side for some reason ,
wheelie387a 08-01-2013 02:00 PM
Yes new springs and shocks, as well as sway bar links... Radiator support snubbers identical to frame
biffgnar 08-01-2013 02:01 PM
22 Attachment(s)
Have an adult sit in the driver seat and then measure it again.
tyvanwie 08-01-2013 02:01 PM
Question, did you measure the coils, or ground to fender?
Sixbanga 08-01-2013 02:02 PM
If someone replaced one sway bar link with a after market one it could be a different length then factory causing a problem.
wheelie387a 08-01-2013 02:03 PM
Ground to fender with new stuff as well as old... I wonder if a spring mount is 1/2" off from the frame somewhere?
wheelie387a 08-01-2013 02:04 PM
See above " same with new sway bar links as well as old ones"
tyvanwie 08-01-2013 02:09 PM
Psi all even? Seems odd, but you could have a flat...
wheelie387a 08-01-2013 02:17 PM
New tires/ wheels yesterday as well. , all at 25 lbs
The time now is 09:01 AM.
